Old 08-26-2013, 01:26 PM   #81
E46 4m3
My Ride: 2003 M3
HPF E46 turbo Grassroots Support
Originally Posted by being3 View Post
On 40 pin black connector on BMW ECM pin 17 is output speed signal. I. Not sure if its from the transmission or wheel sensor. AEM VSS is B33 for Generation 1 ems. Other side shielded ground.
Thanks im gona take a look today
E46 4m3 is offline   Reply With Quote
Old 08-26-2013, 01:27 PM   #82
E46 4m3
My Ride: 2003 M3
Can anyone get ahold of a methanol activation switch?
Old 08-26-2013, 03:33 PM   #83
Commanderwiggin
My Ride: 900rwhp Turbo M3
I have one...what's it worth to you?
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 08-27-2013, 10:00 AM   #84
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Originally Posted by E46 4m3 View Post
Im wanting to connect my VSS sensor to my Aem my harness has VSS plug on aem harness. I was originally going to splice into actually sensor itself. But if someone could provide me with pin out of the DME. So i wont have to run the wiring so far. That would be great. Thanks. Im wanting to do this so i can have boost by gear. Thanks
FYI : boost by gear is not available in r AEM. R version of the AEM u can do by speed. There is a table u can define boost in accordance with road speed.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 08-27-2013, 10:15 AM   #85
E46 4m3
My Ride: 2003 M3
Yes i know. Im going to do according to gearing. For example my second gear tops out at 60mph i believe. So i would lower boost under 60mph so i can actually get traction. Lol
Old 08-27-2013, 10:55 AM   #86
being3
Modded ///Member
being3's Avatar
[QUOTE=E46 4m3;15669705]Yes i know. Im going to do according to gearing. For example my second gear tops out at 60mph i believe. So i would lower boost under 60mph so i can actually get traction. Lol
That's exactly how I have mine setup.... I have also been looking at autologic traction control...uses 4 wheel speed sensors and cuts fuel and ignition... Combine with boost speed control and use the SMG launch control and I think we would do good times
Old 08-27-2013, 12:16 PM   #87
Commanderwiggin
Or do a 6speed swap and switch to the Infinity which has a true wheel speed based traction control
Old 08-29-2013, 12:25 AM   #88
being3
Modded ///Member
being3's Avatar
I'm working on that option as well.... I had local low km trans lined up but he wants way to much... I have the parts list to do the conversion... Will need to modify my housing and looking who an do that for me...
Old 08-29-2013, 01:10 PM   #89
jstaylor
My Ride: 04 M3 HPF Stg2 vert
A bit off topic, but the spacer that mounts to the HPF intake manifold to hold the dip stick in place has broken on my car. Anyone have a good idea for an alternative?
jstaylor is offline   Reply With Quote
Old 08-29-2013, 03:49 PM   #90
being3
Modded ///Member
being3's Avatar
Mine did the same yesterday. I'm looking as well
Old 08-31-2013, 05:48 PM   #91
E46 4m3
My Ride: 2003 M3
Where is abs relay located? I bought smg salmon relay and abs relay. I changed smg relay. But cant find where the abs relay is there isnt even another relay the same color as the new abs relay. Im thinking i might have wrong relay in therr already
Old 09-11-2013, 12:57 PM   #92
GRK///M3
My Ride: LSB M3
Re: HPF E46 turbo Grassroots Support
Does anybody know where to get a silicone coupler for the 4 inch HPF intake?
GRK///M3 is offline   Reply With Quote
Old 09-11-2013, 07:50 PM   #93
being3
Modded ///Member
being3's Avatar
this looks close
http://www.siliconeintakes.com/produ...2e01348bd45de7
Old 09-15-2013, 07:07 PM   #94
thesull
My Ride: e46
Hey I need a replacement waste gate... anyone know which one was on our cars??
thesull is offline   Reply With Quote
Old 09-16-2013, 12:40 AM   #95
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
Guys my HPF gauge for the AFR isn't working. Where can i get replacement sensor for it?
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 09-16-2013, 02:51 AM   #96
Commanderwiggin
AEM my friend
Old 09-16-2013, 03:09 AM   #97
0-60motorsports
AEM my friend
LOL I know that bro, Any vendors easy to deal with and know about this should have been my question. Half asleep posts never help LOL.
Maybe LAB22?
Old 09-16-2013, 03:15 AM   #98
Commanderwiggin
Maybe LAB22?
That would be the first place I'd call... sales@lab22.com They will have it to you ASAP just hit them up!
Old 09-16-2013, 03:17 AM   #99
0-60motorsports
Cheers bud. Emailing them now
Old 09-16-2013, 01:07 PM   #100
being3
Modded ///Member
being3's Avatar
Tial MVR 44mm
http://tialsport.com/index.php/tial-...tegates/39-mvr
