Old 09-16-2013, 01:32 PM   #101
Commanderwiggin
My Ride: 1000rwhp Turbo M3
Originally Posted by thesull View Post
Hey I need a replacement waste gate... anyone know which one was on our cars??
Be very careful with this because the duty and wastegate springs have to stay the same otherwise it will need a retune.
Get the old wastegate and check the part number...there was a few different wastegates used over the progression of the kit. I have an old wastegate than the newer ones sold in the last 3 years.
Old 09-16-2013, 05:20 PM   #102
thesull
My Ride: e46
Ok which springs .7 & .3 ?? The red ones ??
thesull is offline   Reply With Quote
Old 09-16-2013, 05:36 PM   #103
Commanderwiggin
Depends what your car originally had.
Old 09-16-2013, 05:38 PM   #104
thesull
My Ride: e46
Guess I will be cutting this waste gate open lol
Old 09-16-2013, 05:40 PM   #105
Commanderwiggin
Yup
Old 09-16-2013, 05:40 PM   #106
Commanderwiggin
Did you smash the undercarriage really hard?
Old 09-16-2013, 06:02 PM   #107
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
HPF E46 turbo Grassroots Support
Yellow and green makes for 1bar on old Tial 44 purple top. Newer one has water ports and is black or blue and uses 3 springs to make 1 bar I believe. If u have ur old one like Kenton says is best. The springs r also different depending if its a stage 2 or 2.5 and up
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 09-17-2013, 01:48 PM   #108
dragosid
My Ride: HPF 2.5 M3
Originally Posted by jstaylor View Post
A bit off topic, but the spacer that mounts to the HPF intake manifold to hold the dip stick in place has broken on my car. Anyone have a good idea for an alternative?
It's an OEM rubber spacer. I ordered mine from the dealership.
Pulled the trigger! Built engine + 6766 Dual BB + Open Dump + 15/23 PSI - Holy F#@$ this build is insane!
HPF Stage 2.5 - 739rwhp & 581ft-lbs SAE
best 1/4 mile (ST2) 11.77'@123mph 1.9' R/T on Toyo R888 295/30/19
Porsche Cayenne Turbo S - stock
dragosid is offline   Reply With Quote
Old 09-17-2013, 08:47 PM   #109
being3
Modded ///Member
being3's Avatar
Do u have a part number?
Old 09-18-2013, 02:25 PM   #110
dragosid
My Ride: HPF 2.5 M3
Not really, just showed it to them and they brought one from the store...
Old 09-30-2013, 03:01 PM   #111
Jealous World
My Ride: 2001 BMW ///M3
What's the highest whp anyone's got on stock internals
Jealous World is offline   Reply With Quote
Old 09-30-2013, 03:27 PM   #112
Commanderwiggin
700rwhp you start to run into reliability problems.
Old 10-26-2013, 12:47 PM   #113
dragosid
My Ride: HPF 2.5 M3
HPF Methanol bracket filter
Would anybody know where I can source the methanol filter found on the HPF meth bracket as the lower fitting starter leaking badly and I had to stop using the methanol altogether?
Old 10-26-2013, 01:45 PM   #114
Cipri
My Ride: E46 M3 2002
Is it possible to setup in the AEM v1 the RPM drop when hiting rev limiter?
For example if I hit the rev limiter in first gear the RPM drop is way bigger with the AEM then it was on the stock ECU.
Cipri is offline   Reply With Quote
Old 10-26-2013, 10:36 PM   #115
being3
Modded ///Member
being3's Avatar
Aem has a replacement filter and has steal connectors.
http://www.aemelectronics.com/water-...ne-filter-1161
Old 10-27-2013, 01:48 AM   #116
dragosid
My Ride: HPF 2.5 M3
Nice! Thank you
Old 10-27-2013, 03:46 AM   #117
Cipri
Re: HPF E46 turbo Grassroots Support
I was looking at Setup -> Rev Limiters -> Main Rev Limiter -> Wizard, what should I choose to have the RPM not drop to much? The options are from Soft to Hard (11 stages to choose from).
Also it requests to change the target RPM for Fuel Cut (I have 8000), Ignition Cut (I have 12800), Retard Limit Rev (I have 12800) and Fuel Cut Load (I have 265.26 kPa).
Sent from my GT-I9505 using BimmerApp mobile app
Old 10-27-2013, 10:57 AM   #118
being3
Modded ///Member
being3's Avatar
I am not sure how the factory DME comes into play in this situation. if the DME has a rev limit at 8000 rpm it's going to cut throttles etc... Independant of the AEM. U could try to set the Aem rev limiter to let's say 7900 and see if it takes over and gives u more control with the Aem settings. Then u could have the DME flashed to raise the limit to 8100 and then have the AEM set to 8000 and dial it in the way u want it without interference from the DME... Just an idea to think about
Old 10-28-2013, 10:43 AM   #119
being3
Modded ///Member
being3's Avatar
U got me curious Cipri.... To me the different levels of cut soft, med ,and hard r as u said the amount of rpm drop from the rev limiter in rpm. Ranging from the largest drop 300 rpm to 0 drop... I believe this will work and is active with the HPF Aem setup... The only thing is do get the DME out of the picture by increasing the DME rev limiter as I said in the previous post and have the AEM take over below that at 8000. I'm going to try it out myself to verify and post back to u my friend later this week..
Old 11-13-2013, 12:09 PM   #120
JuniorGM
My Ride: M3
Anyone know how to wire in the serial port on a Gen 1 harness? Please send PM or jcj_01@hotmail.com.
Take care.
JuniorGM is offline   Reply With Quote
