Old 11-13-2013, 07:37 PM   #121
E46 4m3
My Ride: 2003 M3
HPF E46 turbo Grassroots Support
Does anyone know where i can buy molex pins that the aem uses. I want to wire in my 2step that is pre programmed on pin b40.
E46 4m3 is offline   Reply With Quote
Old 12-13-2013, 12:38 PM   #122
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
They are AMP pins....I previously thought they were molex and was my mistake. I'm looking at sourcing them and will let u know... There r literally thousands of types
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 12-14-2013, 12:08 AM   #123
being3
Modded ///Member
being3's Avatar
Working with another HPF fanatic here r the pins and connectors.
Old 01-05-2014, 04:43 PM   #124
being3
Modded ///Member
being3's Avatar
I'm working on something new with DME for HPF Cars.
I'm working on disabling the error codes in the DME that r specific to HPF AEM V1 Generation 1 & 2 cars. That way we can benefit from:
- Eliminate Dash led and when a real code comes up we can rely on dash led to indicate any other problem.
- allow GT1 / Autologic tools to run test routines without faulting because of error codes
- pass regular visual and scan based safety inspections which most require no engine led to pass (not including emissions test)
- remove all the factory 02 sensors to clean up and simplify the wiring and eliminate potential shorts etc...
I'll also have the dyno mode activated for 8000rpm, sport button recall last memory, shift lights for manual trans, speed limiter set to 200mph, sport button comfort and sport tables revamped for more aggressiveness.
Also able to modify DME for SMG to manual conversions.
I have modified my DME accordingly but need to test it... Cars apart for more mods at present so it will be a little while. I'll post back with results when verified. Pretty sure it's going to be a go
Old 06-16-2014, 10:49 AM   #125
being3
Modded ///Member
being3's Avatar
Jumperbox shorting problems
[ame="
