Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > UK
UK
Have you seen another BMW while driving around in your area? Find other members from your area in the E46Fanatics Garage HERE
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average.
Old 02-08-2014, 06:36 PM   #2641
dropbop
My Ride: 318i
Hey guys, how's things with you all. Been a while since I've been on. Up to my eyeballs. Hope the cars are still running smoothly. I am taking mine to my mates garrage during the week to store it so I can go up and work on it when i have time.
Hey, if you can get RTE2 on the tv, watch out for me this Thursday at 9:30pm..
Sent from my GT-I9300 using BimmerApp mobile app
My First BMW - E46 318i 1999
dropbop is offline   Reply With Quote
Old 02-09-2014, 06:44 AM   #2642
Tokyo Fro
My Ride: BMW 318ci
Just thought i'd pop my head back in here and say hello
I'm up for a meet if you guys sort one, seems like it would be a bit of a trek for some of us though
Dropbob, whatcha doing on TV??
Tokyo Fro is offline   Reply With Quote
Old 02-14-2014, 06:13 AM   #2643
dropbop
My Ride: 318i
Ah, just organising my wedding.
Not sure if you guys can get this in UK, but worth a shot
http://www.rte.ie/player/ie/show/10252721/
And yes, my Bimmer looks pretty good on TV!!
Old 02-14-2014, 07:31 AM   #2644
dropbop
My Ride: 318i
Just got some DVDs in the door from the production company, will pop online somewhere later and post a link
Old 02-20-2014, 05:05 AM   #2645
Shaun1970
My Ride: 318i SE 2000
Send a message via MSN to Shaun1970
awesome drop would like to see it!
Shaun1970 is offline   Reply With Quote
Old 03-16-2014, 11:39 AM   #2646
dropbop
My Ride: 318i
http://craftgo.com/dttb
Old 03-16-2014, 01:38 PM   #2647
Shaun1970
Thanks Drop, watched that you did a good job mate! Hope you have many more happy years together and Husband & Wife.
Old 03-18-2014, 04:51 AM   #2648
dropbop
My Ride: 318i
Yeah, I didn't do too bad if I do say so myself. Was great fun filming it. Cant go anywhere without someone coming up to me telling me they recognise me from somewhere, but you know well that they are dying to say... 'your the guy from the program on tv!'
Old 03-18-2014, 01:13 PM   #2649
kermitscompact
My Ride: e46 compact
need some help guys
hi guys i am looking for a little help with my 2001 1.8 318 ti compact.
it can run fine for days then suddenly dies on me... battery light comes on just b4 shuts down leave it 10 min and starts again sometimes runs fine for hours or 5 min... some say cam ensor some say coil pack system... i am not really sure... if anyone can help it would b very apreciated
kermitscompact is offline   Reply With Quote
Old 03-18-2014, 02:00 PM   #2650
kermitscompact
Old 03-18-2014, 02:28 PM   #2651
dropbop
My Ride: 318i
That sounds like it could be a number of things.
My suggestion would be to get it to a local garage and get it plugged into a diagnostic and see what errors are stored in the ECU.
Is the engine light on at all? have you loose plug leads maybe?
Could be a good idea to have a whip around the car and check the leads are all connected properly, check the plug leads and battery connections. Check for any corrosion around the battery. Also check if the alternator is charging the battery. Usually a battery light warning on the dash can be a faulty or worn out alternator.
Old 03-23-2014, 03:04 PM   #2652
Dave71
My Ride: 318i
just sorted the same problem on a friends E36 compact, same symptoms as that , found it was starving of fuel swapped out the fuel filter and all fine , may be a cheap fix before the garage gets there hands on it
Dave71 is offline   Reply With Quote
Old 03-23-2014, 04:41 PM   #2653
dropbop
My Ride: 318i
Having a sluggish time with my Audi A4, might check same on that. electrics all seem to be good and battery is fairly new.
On the up side, got my BMW running again, so hopefully I will get a few nice dry days to work on her. Need to replace the wishbones on the front and get that dam airbag light to go out.
Question: I know there are a couple of reaons why an airbag light would stay on, but I was thinking it might be the sensor on the passenger seat. I would presume if I got another seat from the local breakers it would have the sensor in it, and when plugged in to the car, it should fix the fault (It may not be the seat, but im willing to give it a try).. any thoughts on that?
Old 03-24-2014, 09:34 AM   #2654
Tokyo Fro
My Ride: BMW 318ci
Hey Dropbob,
I had the same thing, it was the sensor mat in the passenger seat, a secondhand seat might not have the sensor with it, just search ebay for the sensor alone! I eventually got a 2nd hand replacement mat from the breakers which did the trick.
Cos i'm lazy, before i replaced the mat i bought one of those airbag bypass switches, it makes the car think the seat is occupied so the airbag is active and the dashboard light goes off they plug into the mat sensor connection. i got mine in an auction for a couple of quid!
loads here: http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
Old 03-26-2014, 02:50 PM   #2655
Shaun1970
Poor car!! Had the following replaced:
  • Head Gasket
  • Rocker Cover Gasket
  • Timing Housing Gaskets
  • Timing Chain Tensioner
  • Manifold Gasket
  • Expansion Tank
  • Oil
  • Antifreeze
  • Temp Sensor
Now back to tip top condition! If anyone in Yorkshire I recommend "Robs Autos" awesome mechanic!
ID:	551470   Click image for larger version
ID:	551471   Click image for larger version
Old 03-27-2014, 05:14 AM   #2656
dropbop
My Ride: 318i
Hey Dropbob,
Had a look, thanks. Looks like there is a guy selling them on ebay from donegal so will get one from him and see if it does the trick.
He is selling the sensor mats too for around 35 pounds so if turns out to be the seat I will replace the mat.
Thank again Tokyo
Old 03-27-2014, 05:16 AM   #2657
dropbop
My Ride: 318i
  • Head Gasket
  • Manifold Gasket
  • Expansion Tank
  • Oil
  • Antifreeze
  • Temp Sensor
You just gave that engine another 100k miles! Nice job!
Old 03-30-2014, 05:31 AM   #2658
Shaun1970
Hopefully LoL we shall see, HG was pretty blown, but luckily she never once over heated so a bonus!
Old 05-19-2014, 03:45 PM   #2659
welshmark
My Ride: 318
newbie coming to say hi
Hi ive had mine for just over a week now. and im very impressed with it got a 99 318 swapped it on swapz for my l reg frontera. its had wishbones and suspension changed. only problem im getting is no matter what setting the heater is on it still blows out hot unless the aircon is on then its freezing.
one other my mrs never looked at the frontera since ive had the bm i have to hide the keys from her.
also had a e30 and an e36 loving this car
welshmark is offline   Reply With Quote
Old 05-21-2014, 01:47 AM   #2660
Shaun1970
Welcome to the forum Mark, think I just posted on another post about heating issues that your experiencing, I would try the water valve first, this is common if stuck "Open".
Rate This Thread
