///M3 Forum
Old 05-10-2013, 02:18 PM   #1
PiL
My Ride: 2006 | M3 | CBM
Need HELP please... Installed new battery and now car won't start.
Could it be I bought the wrong battery? It sounds like it starts for a second and then dies. Bought the Everstart Maxx at walmart.
2006 | M3 | CBM | 6MT | TEIN S Tech & Koni Sport | BMS Spacers 15mmF/10mmR
PiL is offline   Reply With Quote
Old 05-10-2013, 02:24 PM   #2
z00
Banned User
My Ride: E46 M3 Manual
Be sure you connected the battery correctly and have the right battery for the car.
If it's starting, it cannot be the starter. Check the alternator.
z00 is offline   Reply With Quote
Old 05-10-2013, 02:28 PM   #3
PiL
Confirmed with Walmart that it's the correct battery. Everstart Maxx H6 13.
Old 05-10-2013, 02:31 PM   #4
PiL
It was running fine, just a couple of hard starts - could it be alternator that it doesn't start now? Is it possibly a fuse? Found the box in glove compartment, but can't find a diagram for fuses.
Old 05-10-2013, 02:58 PM   #5
grkm3
My Ride: Money Pit
Send a message via AIM to grkm3
If it doesnt start after you swapped batteries, I suspect the new one has a bad cell or is partially discharged.
SOLD
03 Steel Gray M3 - Imola Red Interior - SMGII - Premium - HK Sound
Mods: VFE SC Stage 2, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe, TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R brakes
Coming Soon: Open to suggestions
grkm3 is offline   Reply With Quote
Old 05-10-2013, 03:07 PM   #6
PiL
Thank you! Charging it now
Old 05-10-2013, 04:57 PM   #7
PiL
Got it started with charger. Should I exchange new battery, or will it charge when driving?
Old 05-10-2013, 05:58 PM   #8
Slyde
My Ride: 2001 M3 TiAg
I say exchange it.
A new battery that does not work... that is simply wrong. After all, maybe it was discharged or maybe it is defective. If I am not mistaken, full discharge is not good for standard batteries (that is what deep cycle batteries are designed to do, but not regular car batteries).
The trunk tool kit can do the job, but you might bring a 13mm and 10mm socket (if I am not mistaken: battery terminals 10mm & hold-down 13mm?) to remove and replace the battery at the store. Assuming that you will not get stranded and the battery is the total cause of failure.
Slyde is offline   Reply With Quote
Old 05-10-2013, 06:08 PM   #9
RAZ M3
My Ride: 05 M3
Im pretty sure you need the H7 version
6MT - Bilstein PSS9 - CSL Diffuser - CSL Trunk - Varrstoen LM - Rogue El Diablo Muffler
RAZ M3 is offline   Reply With Quote
Old 05-10-2013, 06:09 PM   #10
RAZ M3
My Ride: 05 M3
Yes im right you need the Maxx - H7 it has to have 790 crank or the car wont start
