Sponsored by BAVSOUND
Old 05-10-2013, 08:07 PM   #1
buddyz
My Ride: 2003 M3
Dead FM tuner?
2003 M3 with HK/nav. Suddenly lost FM reception about a month ago. Just static. AM works, Ipod works (converted indash CD). Tried replacing antenna, antenna amplifier with no luck. Is it the BM53 radio unit? Options to repair/replace?
buddyz is offline   Reply With Quote
Old 07-12-2013, 04:23 AM   #2
uzz32soarer
My Ride: 2002 E46 M3
Hi from Australia guys,
I have a 2002 E46 M3 coupe and it has no FM radio working. AM seems to be fine, CD stacker works fine, TV works fine. The car has a BMW Business BM 53 unit fitted with Harman Kardon system, TV but no NAV.
When you go to FM on the head unit, you can seek and it will find nothing on FM. Seek on AM and it finds a few stations, not all, but okay. Put the FM station in manually (ie: 91.5) and this can be locked into memory, but no sound at all.
I have removed the C pillar cover and checked connections to the antennae module and nothing appears to be wrong there. I also removed the BM 53 and checked connections there also, but nothing obvious.
The previous owner removed the CD changer and fitted an I Pod control wire which plugged in where the CD stacker is and says that the FM stopped working about two months after he did this.
My car is also fitted with the BM53 unit but unlike the poster above, my car has no Nav.
Any clues? Antennae or radio unit dead?
uzz32soarer is offline   Reply With Quote
Old 07-12-2013, 06:51 AM   #3
Foxtrot_Uniform
My Ride: 325Xi
It is a dead unit. Not sure if you could open it up and reflow some of the solder joints or whether it is a failed part... I just sold my radio to a guy who had the same exact issue and tried everything to fix it. He ended up installing my used radio. They are easy to replace.
Foxtrot_Uniform is offline   Reply With Quote
Old 07-12-2013, 07:36 AM   #4
uzz32soarer
Thanks Rick,
Do you think any BM53 would work in the car or does it have to be specific as I have TV but no NAV system?
Old 07-13-2013, 08:25 AM   #5
Foxtrot_Uniform
My Ride: 325Xi
I would ask anyone that you think has the part to show you a picture of where the plugs plug into the back to make sure you can match it up correctly. That is what I did with my buyer. He wanted to make sure it would fit before he drove out to my house. To make sure... I would take your completely out, snap a picture and use it for comparison.
