Old 05-11-2013, 12:23 AM   #1
David86
My Ride: 323i
Cool Eagle eye LED tail light vs melted wire
I everyone i just bought my new set of EE LED taillight.
So exited to change it cause it say plug and play when a realise the right side of my tail light have melted wire to the metal tail light housing. i do my research to know what the heel is that finally to understand it's a known issue.
My question is simple what i have to do with that?
If a broke the melted wire and directly plug my new tail light it will work like it's nothing(i dont think so).
Thank you very much!!
David86 is offline   Reply With Quote
Old 05-12-2013, 04:16 AM   #2
David86
My Ride: 323i
Help anyone please??
Old 05-17-2013, 09:39 PM   #3
That-Guy
My Ride: '01 330i
call your local dealer to see if the recall applies to you, so you can get it fixed for free. otherwise youll need a bulb holder ($80 i think) new connector and a new terminal to repair the ground.
Certified Master Tech
That-Guy is offline   Reply With Quote
Old 05-18-2013, 05:18 PM   #4
David86
My Ride: 323i
Hey thanks for the answer!!
I'm not sure if i understand clearly i'm not too good in english
But i got my car almost 2 year. The previous owner seeme to fix is taillights
My question is can i detach the fixing stuff on the bulb holder and put my new LED taillights with no problemes
I'm afraid to detach it and my tailight didn't work
Old 05-18-2013, 08:30 PM   #5
That-Guy
My Ride: '01 330i
depends on how he fixed it, i would make sure its repaired like its supposed to be. take a picture of how its repaired and i cant let you know if its fine as is or needs to be redone.
Old 05-19-2013, 06:01 PM   #6
David86
My Ride: 323i
okay picture taken!!
Name:	2013-05-19 17.57.20.jpg
Old 05-19-2013, 06:06 PM   #7
That-Guy
My Ride: '01 330i
thats how i repaired mine. your going to have to remove that extra wire and repair that ground wire by replacing the parts burned. specifically the connector and the wire terminal.
Old 05-19-2013, 06:10 PM   #8
David86
My Ride: 323i
Thank you very much very helpful information. How much it cost to do that??
Old 05-19-2013, 06:25 PM   #9
That-Guy
My Ride: '01 330i
well since you should have a new cover with the led lights you dont need the $80 bulb holder so it should cost around $20 to do both sides, at least here. Not sure if prices are very different where you are.
Here's a parts list
connector: 61138369702
terminal: 61130006626
Old 05-19-2013, 06:32 PM   #10
David86
My Ride: 323i
That no problem i always buy part from States because in my contry it's alway at least 2x more expensive :s Thank you for the info i'm gonna buy these part before going to the garage!
Old 05-19-2013, 07:19 PM   #11
That-Guy
My Ride: '01 330i
no problem
