Looking for some ppl to throw questions at regarding a rebuild. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-11-2013, 10:42 AM   #1
stankins
My Ride: 330i
I started out with a smoke test to find my rough idle at startup which it did, it was disa and valve cover. Next was a compression test. cyl 1-5 were all at 120psi and cyl 6 was high 140's and wet. I purchased the car last year, I have done a complete cooling overhaul, ccv, vanos, alternator, suspension, fuel pump/filter, coils, plugs, waterpump....i could go on a little bit more but you get the idea.
Basically i need a head gasket..my old man is retired car guy and is just pushing me to fix whats broken but this motor has 156k and leaks from every spot i havent touched yet... oil pan, head (obviously) filter housing... mains are probably weeping too.
I think if i just go all the way the car is pretty much up to date. but i have some questions about some internals and could use some foresight in planning. Ive scoured the forums for a couple days now but havent been lucky.
I need some wisdom please pm me!
Thanks in advance
stankins is offline   Reply With Quote
