Old 05-11-2013, 05:18 PM   #1
Wielandgeorg
My Ride: 04 325ci
Help with e46 325ci drive shaft problem
Car: 2004 325ci coupe RWD auto 182k miles
Problem: drive shaft vibrates / shudders shaking center console at 20 to 30mph
Already changed: guibo, center support bearing, trans mounts, driver side cv axle rear, and rear differential bushing, all four brake rotors.
I checked the U-joints on the drive shaft they are smooth not notchy and not hard to move.
Can someone please point me in the right direction to get this annoying issue fixed?
Thanks a lot
Wielandgeorg is offline   Reply With Quote
Old 05-11-2013, 05:37 PM   #2
lszlszx
My Ride: 1.8T, XC70
Sounds like it may not be a driveshaft problem, since you already replaced/checked almost everything in that area. Does the shaking happen in any gear at that speed?
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 05-11-2013, 05:40 PM   #3
Wielandgeorg
My Ride: 04 325ci
Hey thanks for reply well at first before changing guibo but only
The csb it did it every time in first gear at 15/20 mph now after I changed guibo and diff bushings and half shaft and trans mounts it does same crap but at the 2/3 gear change and at 25/30mph
Old 05-11-2013, 07:18 PM   #4
lszlszx
My Ride: 1.8T, XC70
That's in a way good news, because if it happened always in the same gear, it could be an internal transmission problem. Is there any play at the transmission output shaft flange? Sometimes the bolt holes are elongated. Is the driveshaft centered in the tunnel? The driveline can transmit vibration from further away. Have you looked at the differential bushings?
Old 05-11-2013, 07:23 PM   #5
Wielandgeorg
My Ride: 04 325ci
I changed the diff bushing already.
What do you mean by holes elongated?
The output shaft has play about 1 mm in all directions up down left right
And about 2mm in and out play. I saw someone else had way more play without vibrations I don't suspect that to be my issue
Old 05-30-2013, 07:47 PM   #6
swordsman11868
My Ride: 2003 325i
OP-
Any update?
You mentioned the rear diff bushing being changed. Did that include the two smaller bushings also?
Thx
-Dan
It's much easier to PRESERVE an E46 than it is to RESTORE one.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is online now   Reply With Quote
Old 05-30-2013, 07:49 PM   #7
Wielandgeorg
My Ride: 04 325ci
Yes update - my differential was shot got a good used one solved the issue.
Old 09-26-2013, 08:06 PM   #8
Pocket Rocket
My Ride: 1999 323i
How did you diagnose that? I have vibration from about 23 to 25 mph on acceleration only, that can only happen in first or second gear (auto) depending on how much your foot is into it. I did guibo and support bearing with no change. I don't want to just start replacing expensive parts hoping to get lucky!
Pocket Rocket is offline   Reply With Quote
Old 09-26-2013, 08:30 PM   #9
Wielandgeorg
My Ride: 04 325ci
I diagnosed it by my brother laying under rear while on jacks and me driving it in the air and he heard noises coming from diff that weren't normal.
Secondly one of my output shaft on differential was wobbling up and down slightly
And third the diff had 180k on it and never had fluid change likely so that's another thing that makes sense with it being bad because if ur guibo is good and ur csb and ur diff bushings that's one more thing u should check its gotta be the diff.
Old 09-27-2013, 01:24 AM   #10
Pocket Rocket
My Ride: 1999 323i
Wise to have the brother underneath and you driving I'll give it a try. My 323 had 202000 miles so that could be it. Thanks!
Old 09-30-2013, 03:16 PM   #11
Pocket Rocket
My Ride: 1999 323i
Tried that this weekend with daughter driving and me under the car. No luck, couldn't see, hear or feel any vibration Back to the drawing board.
Old 10-01-2013, 01:51 PM   #12
generic
My Ride: 2002 BMW 330ci
how much did you invest on a diff? just curious in case it might be my problem going to check it tomorrow on a lift.
generic is offline   Reply With Quote
