Old 05-11-2013, 09:25 PM   #1
Handsome Kev
My Ride: 328
Steptronic gearshift assembly
Looking for any assistance on how to remove/install steptronic shifter. My main concern is the cable that is attached to the front of the shifter at #1 in the picture. Please help
Handsome Kev is offline   Reply With Quote
Old 05-12-2013, 10:33 AM   #2
Handsome Kev
My Ride: 328
Anyone?
Old 05-16-2013, 09:20 AM   #3
sonnybobiche
My Ride: '99 323i
Isn't that the park lock cable that goes to your steering column? My understanding is that that just kinda pulls out with some effort.
sonnybobiche is offline   Reply With Quote
Old 05-16-2013, 09:25 AM   #4
Handsome Kev
My Ride: 328
Idk, I haven't tried yet. I hope its a simple removal and installation
Old 05-16-2013, 05:34 PM   #5
jjrichar
Modded ///Member
My Ride: 330 CiC, 330i
The cable in question is the one that connects to the side of the transmission. It's the one that moves the manual selector valve inside the TX (as well as a bunch of other things). To remove, get under the car and disconnect nut assembly 8. Very simple. It should be then pulled up with the shifter assembly when removing. I haven't got my TIS with me, but my guess is that you would have to remove the heat insulation between the exhaust and driveshaft so that it can be fed up from below. I'll have a look at the TIS later and let you know.
jjrichar is offline   Reply With Quote
Old 05-18-2013, 02:02 AM   #6
jjrichar
Modded ///Member
Had a look in the TIS and the cable definitely remains attached to the shifter, and is removed with the shifter after being disconnected under the car. It didn't mention anything about the heat shield, so it should just pull through.
Old 05-18-2013, 04:25 AM   #7
Handsome Kev
My Ride: 328
Thanks, I'll give it a go in a few hours
steptronic
