Sponsored by BimmerWorld
Old 05-12-2013, 11:42 AM   #1
Koffinb
My Ride: 04 330xi 6spd
Poly FCABs on XI
Thinking of going Poly FCABs on my XI since they dont make Meyle HD's for the XI versions. What do you guys think? I'd like a firmer, heavier steering response than OE. As opposed to lowering springs etc. to improve handling I thought i'd try this upgrade first.
Koffinb is offline   Reply With Quote
Old 05-12-2013, 07:01 PM   #2
lszlszx
My Ride: 1.8T, XC70
It'll be firmer, but you might feel some vibration through the steering wheel.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 05-12-2013, 07:20 PM   #3
DavidDee
My Ride: 2004 325xi
Can anyone else with an XI add to this? I'm also deciding between oem bushings and Powerflex
"It has a radio and speakers but it's kinda hard to hear over horny bitches moanin in the back when I start it up.."
DavidDee is offline   Reply With Quote
Old 05-12-2013, 07:20 PM   #4
Foxtrot_Uniform
My Ride: 325Xi
I just bought Powerflex bushings for the front and rear... I just need to get around to installing them!
Foxtrot_Uniform is offline   Reply With Quote
Old 05-13-2013, 02:02 AM   #5
Koffinb
what kind of vibrations??
Old 05-15-2013, 12:53 AM   #6
Sh0ty
My Ride: 2001 M3, 2004 330Ci
Any vibration that your lower control arm would experience during operation. This means as your tire rolls over the road, vibration. As you hit a bump, higher frequencies that are damped by rubber bushings will not be with the poly urethane. That said, in my opinion, the NVH increase from poly urethane suspension bushings is minimal / negligible. Engine mounts made of poly urethane are an entirely different story.
Of course, my opinion regarding PU bushings in the suspension is formed from my experience with a MKII Toyota MR2; I have not installed them into my E46. I suppose it all comes down to "what kind of constraint do you want to impose upon your control arms?" A race car utilizes spherical bearings to constrain articulation to a single point, allowing more precise tuning, an enthusiast installs PU for crisper feedback and more predictable suspension kinematics (mostly placebo for an amateur driver in my opinion, if you can feel .03" delta in deflection of your control arm inboard points, you're a CMM) and OEMs utilize rubber bushings to keep NVH low while ensuring more than adequate control of the suspension.
Sh0ty is offline   Reply With Quote
