Old 05-12-2013, 05:30 PM   #1
Lunatic
My Ride: 2007 335i
Unhappy overheating when still
my 328ci has about 190k miles runs smooth manual tranny has vever given me problems but.......my only consern is that when i sit still for more than 15-20 min the temp gose up fast. If i go the temp gose back down. i dont know what could be going wrong, ive noticed a couple things tho like ive only noticed my fan come on maybe 2 times other than that ive never seen it come on, also my in dash temp says -40 f.......ive bin thinking and im wondering that by the car reading -40 on the in dash temp (which my guess is outside temp) the car thinks its freezing outside so it dosent turn on the fan.....idk its a wild guess i need some advice ....thanks
Lunatic is offline   Reply With Quote
Old 05-12-2013, 05:34 PM   #2
jhaurimn
My Ride: 01' 330ci
I think the only thing the car does when the ambient temp sensor isn't reading (the reason it shows -40*) is not allow you to use your ac.
Maybe a possible issue with your fan? Wait for someone else to chime in for sure
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 05-12-2013, 05:48 PM   #3
Lunatic
My Ride: 2007 335i
really?? cuz my a/c dosnt work....would that be why??
Old 05-12-2013, 10:48 PM   #4
Redline
Redline's Avatar
My Ride: ///M3 Vert
Coolant temp sensor in lower hose left side of car going into radiator, there's a sensor on top of hose that fan plugs into. Change it. Also ambient temp sensor needs to be replaced.
k.
///M
Old 05-13-2013, 05:57 AM   #5
jhaurimn
My Ride: 01' 330ci
Yes until you replace your outside temp sensor, you can't use your air conditioning.
The car thinks its negative 40, so yeah it assumes you don't need ac at that point lol. It's in the wheel well in front of the front driver wheel
PAST
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
Old 05-16-2013, 08:40 AM   #6
Lunatic
My Ride: 2007 335i
The coolant temp sensor....is that a sensor that would controls the fan or the in dash temp gauge? Cuz the in dash temp gauge works good it just overheats out of nowhere when still
Old 05-16-2013, 08:42 AM   #7
Lunatic
My Ride: 2007 335i
Thanks I found it and I crossed the wires and it now thinks its 122degrees the sensor is on order and will be fixed soon ��
Old 05-17-2013, 11:36 AM   #8
Lunatic
My Ride: 2007 335i
Fixed the ambient temperature sensor!!! �� Haha worked wonderfuly
