E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 20 votes, 4.40 average. Display Modes
Old 05-13-2013, 11:09 AM   #1
SamDoe1
My Ride: 4cyl of fury
Here's What Suspension to Buy.
I'm sick and tired of seeing thread after thread on suspension so read this first. If there are any changes needed to this guide please let me know.
First statement: RWD suspension is NOT the same. If you read in the general forum that H&R springs are super comfortable or Eibachs will slam your car, that is NOT true for the Xi. Xi models have less suspension travel than the RWD models and therefore have different ride comfort characteristics. This also means that you CAN NOT use parts (none of them so don't ask) from a RWD car on an Xi. They have different suspension geometries and dimensions so please confirm any advice you get in the General E46 forum before you buy stuff as it's likely wrong...or just read this guide. With me so far? Ok, read on.
In general you have three options:
1.) Replace your suspension with an OEM replacement. This will be the most expensive option and will not lower your car at all. Depending on how long it has been since your last suspension replacement, it may even raise your car. This set up will have a very soft ride with quite a bit of body roll but will be able to go over any obstacles that may come your way. It also makes it quite a bit easier to jack your car up since you won't have to drive up on 2x4s to get the jack under your car. Remember that you can replace the shocks/struts with aftermarket components and still use OEM springs if you should desire.
2.) Replace your suspension with aftermarket shocks/struts and springs. This option is the cheapest way to go and will lower your car a moderate to high amount depending on what spring you buy. The shock/strut has very little to do with the ride height so we'll start with springs. There are, in general, two options for springs on the Xi. Eibach springs lower the car a moderate (0.75"-1" ) amount while retaining much of the comfort that OEM springs would give you. This seems to be the best option for many people on the forum because we daily drive our cars. This will be similar ride height to a RWD sport package. If you don't and want more performance, H&R is the next set. H&R springs lower the car a high amount (1.5"-2" ) but substantially degrade the ride comfort that you would get out of your car. This ride height will be similar to a RWD ZHP. This option is good if you autocross/track the car and don't use it for your daily driver or if the roads where you live are flawless (but then you wouldn't have an Xi anyway right?). For shocks/struts you, in general, have two options. Koni shocks/struts are the most expensive choice but they are adjustable and the rear ones tend to be a bit more reliable than the Bilsteins. If adjustability is what you're looking for, look no further than the Konis. I personally have them and love them. Konis are ok for cars lowered a lot to not lowered at all. The second option is Bilsteins. They are cheaper and not adjustable but the rears tend to leak. There are reports that running E36 M3 rear shocks will solve this problem but that increases the cost. (Thread: http://forum.e46fanatics.com/showthread.php?t=830014) Bilstein shocks come in both "Sport" and "HD". The "Sport" models have a shorter stroke and are better for cars that are lowered a lot. The "HD" models have a longer stroke and are better for cars that are moderately lowered or not lowered at all. There are other shock/spring manufacturers out there but I cannot vouch for them nor have they been vetted by the forum. If you are someone who has experience with other manufacturers, please let me know and I will update this.
3.) Replace your suspension with coilovers. If you want to go this route, ensure that you get a kit that is designed specifically for the Xi models. Coilovers provide adjustment in ride height on the fly and also provide the most substantial ride height reduction (yes you can "slam" your car with this). However, they do tend to be uncomfortable and more jarring than any other option and also have a tendency to wear through CV boots quickly causing potential front axle failure. They are more expensive than shocks/springs but cheaper than OEM. Also consider that you might need camber plates and arms to compensate for the drop unless you don't like even tire wear.
Please, please, please, please do NOT buy Raceland coilovers or any other cheap shiity parts you find on eBay. They are cheap for a reason and I really would NOT buy crappy parts when it comes to the only thing that's holding your car up. There have been documented failures on these parts and they pose a substantial safety risk to yourself and others if you install them. That said, if you still feel as though you want to buy and install them after this warning, then it's your car and up to you.
Some people have asked if they can combine aftermarket and OEM components for their suspension and the short answer is that it depends. The long answer is that if you want to replace your springs and run OEM shocks/struts then you'll have issues. The OEM shocks/struts are not valved appropriately for the aftermarket springs and will wear out quickly. If your question is how quickly, I don't know as that depends on a lot of things. If you want to run aftermarket shocks on OEM springs, go for it as long as the stroke of the piston is long enough (Bilstein HD works great).
If you are going to be doing a suspension replacement, ensure that you purchase all new hardware to perform the task you are doing. This includes the upper mounting nuts, lower mounting bolts, etc. Also purchase new upper shock/strut mounts and rubber bushings. You can reuse the bump stops however they will need to be cut approximately 0.75" if you are lowering the car.
For more firsthand ratings on what people think of different options, check this link:
http://forum.e46fanatics.com/showthread.php?t=731343
For DIY Instructions follow this link:
http://www.bmw330ci.net/projects/suspension.php
The car is a RWD car but the method is the same.
Parts you will need if you want to do a complete refresh:
07119900402 - Rear Lower Shock Bolt x2 (Required)
33521136283 - Rear Shock Protector Tube x2 (Optional)
33531094518 - Rear Lower Spring Pad x2 (Optional, replace if yours is damaged)
33531136385 - Rear Upper Spring Pad 5mm x2 (Optional, replace if yours is damaged)
33531094754 - Rear Upper Spring Pad 14.5mm x2 (This is the thicker version of the one right above, pick one or the other - Optional, replace if yours is damaged)
33526772864 - Rear Shock Mount Gasket x2 (Required...unless you like water in your trunk)
33531136395 - Rear Bump Stop x2 (Optional)
33521092362 - Rear Upper Shock Mount x2 (Highly suggested)
07119905374 - Rear Upper Shock Mount Nut x4 (Highly Suggested)
31356778832 - Front Lower Strut Bolt x2 (Required)
31336752735 - Front Upper Strut Mount x2 (Highly suggested)
31331091867 - Front Upper Spring Bushing x2 (Suggested)
31331096664 - Front Lower Spring Bushing x2 (Suggested)
31311139453 - Front Strut Mount Cap x2 (Optional, replace if you lost yours)
31336752832 - Front Bump Stop x2 (Optional)
31316769731 - Front Upper Strut Mount Nut x6 (Highly Suggested)
31106774714 - Front Upper Strut Nut x2 (Suggested)
Koni Part Numbers:
8741-1481RSPORT x1
8741-1481LSPORT x1
8040-1343SPORT x2
Bilstein Part Numbers:
24-024532 x2 (Rear HD E46)
24-024532 x2 (Rear HD E36 M3)
22-052810 (Left HD Strut) x1
22-052827 (Right HD Strut) x1
22-052834 (Left Sport Strut) x1
22-052841 (Right Sport Strut) x1
H&R Part Number:
29383 x1
Eibach Part Number:
2089.140 x1
Thanks to Dreamliner330 for the above list.
Vendors for Suspension parts:
Pelican Parts
ECS Tuning
Tire Rack
Your local dealer
The internet
Disclaimer: This post is simply a set of recommendations on what you do with your car. It is still up to you to make your own choice on what to buy and how to safely install these parts on your car. If performing this level of work is beyond your capabilities, please take your car to a professional who can appropriately install these parts for you. The suspension is one of the most important systems in your car and you should therefore not compromise any safety when it comes to it.
Good luck!
Old 05-13-2013, 11:50 AM   #2
bmwporschefan
My Ride: 2001 330xi
This needs to be a sticky or it will just disappear. Alot of the suspension question threads seem to be started from someone who doesn't like to search much.
'01 330xi
bmwporschefan is offline   Reply With Quote
Old 05-13-2013, 11:53 AM   #3
bmwporschefan
My Ride: 2001 330xi
Oh, and just my experience, I didn't cut any bump stops. The rear e36 m3 shocks came with bump stops installed and I left them as they were. I reused my fronts and had no ill effects from this. I have eibach pro springs and sport bilsteins.
'01 330xi
Old 05-13-2013, 12:46 PM   #4
Koffinb
My Ride: 04 330xi 6spd
ok so since the H&R springs are too harsh for daily driving i'm thinking about the Eibachs..but out of the two which one will provide more of a zhp ride height? I'm not looking to slam just want to fill the fender gap.
Koffinb is offline   Reply With Quote
Old 05-13-2013, 01:05 PM   #5
SamDoe1
Edited OP. ZHP can be had with the H&R's. Eibachs will give you close to a sport package height.
Old 05-13-2013, 01:07 PM   #6
Koffinb
got it, i'd really like the ZHP height though..thats a tough one for me to decide. Next question is since the HD bilsten can handle modest drop would you recommend going with eibachs and HD combo
Old 05-13-2013, 01:10 PM   #7
SamDoe1
Yes.
Old 05-13-2013, 01:17 PM   #8
Koffinb
Yes.
Thanks for this thread.you've made my life so much easier. I'm now debating either bilsten sport fronts and M3 rears or just koni all around
Old 05-13-2013, 04:56 PM   #9
SamDoe1
I submitted a request for it.
Old 05-13-2013, 05:07 PM   #10
DavidDee
My Ride: 2004 325xi
Should be stickied! So much useful information!
"It has a radio and speakers but it's kinda hard to hear over horny bitches moanin in the back when I start it up.."
DavidDee is offline   Reply With Quote
Old 05-13-2013, 09:42 PM   #11
SeattleLSB
My Ride: 2003 330XI, 2003 M3
I'd go with the Koni's they is only a $70 price delta since they are on sale at the moment.
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 05-14-2013, 05:35 PM   #12
SilvaBimma
My Ride: 330Xi
Awesome info.
SilvaBimma is offline   Reply With Quote
Old 05-15-2013, 12:07 PM   #13
Riverbmr3
My Ride: MB E350 & BMW 325i
theyre on back order, where did you get yours?
Riverbmr3 is offline   Reply With Quote
Old 05-16-2013, 01:03 AM   #14
Shadow330xi
My Ride: 2001 Red 330xi
Also looking for a place to purchase Koni's where they are on sale!
Shadow330xi is offline   Reply With Quote
Old 05-16-2013, 07:49 AM   #15
SeattleLSB
There on sale everywhere, Tirerack etc 20% off right now.
Joe
Old 05-16-2013, 08:47 AM   #16
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
hai- can i puts rwd raceland on my xi???!111one
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 05-16-2013, 09:00 AM   #17
SamDoe1
Old 05-16-2013, 09:02 AM   #18
SamDoe1
Please keep this thread clean, discuss that stuff through PM.
Google is your friend, I can't do all the work for you. Please keep this thread clean so the information doesn't get buried under 1000 responses about where Konis are on sale.
Old 05-17-2013, 07:50 AM   #19
Tele
My Ride: E46 330XIT MTech II
Where is the like button!
Tele is offline   Reply With Quote
Old 05-21-2013, 01:51 PM   #20
SamDoe1
Bump to keep this on the top...
