Old 05-13-2013, 07:04 PM   #1
BMARTINW
My Ride: E46 S54 SALOON
BMW P1192 code fix
I have found a way to fix this code that keeps appearing no matter what you do to the car, now it worked for me and passed California smog with no problems.
Well first it started after I had rebuilt my engine, the car ran perfect and I knew all the sensors were good, so I started reading online and I seem that a couple of people were having the same problem after spending thousands on their bmw's, so I got frustrated and this is what I did, the code has never came back after more than a thousand miles of driving and I passed the California smog test and I think that's the hardest state on emissions, so this is what I did.
Locate the Post-catalyst (after the cat o2 sensors) O2 sensor hardness are behind the engine, its easier to get to with the cabin filter housing off, the wires are long so they could hang on top of the engine.
Mark both of the after cat O2 sensors so you won't get them mixed up.
Now start the engine and with the engine running unplug the sensors and mix them up, YES plug the bank one in to the bank two and bank two in to bank one and let the engine run for a little and put them back together and do it again, then reset the code with a scanner, a Peake or an autozone one, I know this sound like you could mess something up, but it worked for me and it might save you a couple of hundred dollars, but only do it if your sure that all your sensors are good and the code just keeps coming back after a couple of miles of driving.
BMARTINW is offline   Reply With Quote
