Old 05-13-2013, 10:03 PM   #1
siava1018
My Ride: 03 330cic
Time for a new buffer...
So the vibrations from the PC are killing my wrist and im starting to do more cars so i think its time upgrade my buffer. What other DA's are you guys using(griots,megs)? Or should i just get a flex?
siava1018 is offline   Reply With Quote
Old 05-14-2013, 06:01 AM   #2
TOGWT
My Ride: Jaguar XKE
How tight a grip you have on the tool will make all the difference; hold vibrating tools as lightly as possible, consistent with safe work practices; allowing the tool do the work. Gloves are available that are designed to exceed the rigorous requirements of the ISO Standard 10819 (ANSI S3.4-2002) for the absorption of vibration due to direct hand contact with vibrating equipment, machinery or hand held tools.
TOGWT is offline   Reply With Quote
Old 05-14-2013, 11:25 AM   #3
Vin Vega
My Ride: 2000 328Ci
Learn how to use a rotary, problem solved.
I'd recommend a makita with soft start.
Vin Vega is offline   Reply With Quote
Old 05-14-2013, 02:01 PM   #4
siava1018
My Ride: 03 330cic
Well i dont wana go rotary or i woulda went out and bought one. So griots or megs?
Old 05-15-2013, 08:47 PM   #5
Active 2
My Ride: 02 E46 m3
Go with a Rupes. Works way better than a flex and there is a far less chance of burning the paint due to its throw. A 15 is great for small cars but a 21 is perfect for really large panels
They're both about the same price but i personally fine rupes to be way easier to use
02 ///M3 Jet Balck/ Imola
AA Headers | AA Exhaust | AA tune | Ground Control | AFE scoops | Apex EC-7
Active 2 is offline   Reply With Quote
Old 05-18-2013, 03:34 PM   #6
SilvaBimma
My Ride: 330Xi
If a PC kills then running a Rupes 15 will reduce the vibration but not eliminate it totally. Rotary would be a choice, although everything on the market is moving to DA work. Flex may work as well. Just be aware all these machines create wear and tear. PC is by far the least weak out of all the mentioned machines.
SilvaBimma is offline   Reply With Quote
Old 05-18-2013, 06:49 PM   #7
scrace
My Ride: 03.5 M3
I would stay away from a rotary, with a high quality DA you can do pretty much anything a rotary can, just with more time but without a chance of damaging the paint. Also, if you're going to be doing paint corrections make sure you pick up a paint thickness guage.
I recommend a flex but keep your PC for spreading waxes and sealants. With any DA it's going to take a lot to damage the paint unlike a rotary.
Griots, Meg's, PC and similar are all free floating spinal assemblies, they all pretty much feel the same. The flex is direct drive gear driven, which allows you to work faster and in larger sections at a time because its a more powerful tool.
2001 Topaz Blue 325Ci 64-120k miles SOLD
2003.5 Silver Gray M3 70k miles
scrace is offline   Reply With Quote
Old 05-19-2013, 06:00 AM   #8
TOGWT
My Ride: Jaguar XKE
With newer materials being used for polishing pads (microfiber, deniu, silk, etc) most professional detailer are no longer using rotary polisher as random orbital's offer many advantages.
Wen I first started detailing (five decades ago) I never thought I would make the above statement, but it's been a couple of years since I've used a rotary (and I own five of them)
