Old 05-14-2013, 09:11 AM   #1
SoloII///M
My Ride: Many
330i intake boot coupler diameter?
Does anyone know the diameter of the intake boot "ring" on a 330i/330Ci? I know the throttle body inlet has a 3" OD and the HFM outlet has a 3.5" OD. Is the coupler between the two intake boot halves 3" or 3.5"?
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 05-14-2013, 10:43 AM   #2
TrippinBimmer
My Ride: Just Fast!
3" if i remember correctly...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 05-14-2013, 10:54 AM   #3
SoloII///M
My Ride: Many
I think you're right. That's what it looks like in pictures.
John V
Old 05-14-2013, 11:12 AM   #4
TrippinBimmer
My Ride: Just Fast!
Transition happens in the second intake tube pipe...
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 05-14-2013, 01:48 PM   #5
SoloII///M
My Ride: Many
Need to figure out how to make all this work with a M50 throttle body from an E36 for a Megasquirt setup which is why I'm asking. The M50 throttle is the same size as a 323i throttle body so maybe a 323i intake pipe is the way to go.
John V
