Old 05-14-2013, 03:13 PM   #1
m_guimont
My Ride: 2000 323i Sedan
E46: 323i, Vibration through Shifter in 1st gear
Hey guys,
So I recently noticed that under heavy acceleration in 1st gear, there is a very audible and noticeable vibration being emitting from the shifter. The shifter has been replaced with an aftermarket unit (no rubber isolator a la OEM).
Conditions:
Any hard/heavy acceleration in 1st gear. Symptom does not appear in any other gear or on deceleration. The vibration also seems to only come through the shifter and not the body or any other components.
The car has seen some heavy use in track circumstances and has roughly 270 000 km (170 000 Miles) on the engine and transmission and drive line components.
Recently Replaced:
2 X engine mounts (with M3 mounts)
2 x trans mounts (with M3 mounts)
Rear Subframe reinforcement kit
Poly subframe bushings
Thoughts:
My 1st impression is it could be a tired bearing or gear inside the tranmission causing 1st gear to misbehave, however that has been no other issues with other gears or any problems wit the car jumping out of gear/grinding.
Could it possibly come down to the driveshaft "guibo" or rubber disc gone bad ? Any insight here is appreciated.
Thanks !
m_guimont is offline   Reply With Quote
