Windshield wipers failure - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-15-2013, 06:27 AM   #1
leblancrene
My Ride: volvo 240 bmwe46 E53
Anyone have experience with wipers seizing.Mine are not moving unless i help them manualy but i can hear wiper motor running even though wipers are not moving
leblancrene is offline   Reply With Quote
Old 05-16-2013, 10:40 AM   #2
Ballistic325
My Ride: slow and steady
Re: Windshield wipers failure
Check the black plastic Dowling at he bottom of the windscreen. Might need replacing as it does stop proper wiper function. Also check to ensure wiper linkages are serviceable and properly connected.
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 05-17-2013, 06:48 AM   #3
leblancrene
Solved
Took assembly out yesterday .The passenger side shaft was seized(salt) i freed it up using pentrating oil, then lubricating it with regular oil.I drilled a hole(1/16) in the outer shaft casing and injected synth grease with a needle grease point
Those who forget history are doomed to repeat it.Ihad same problem with 240 volvo 25 yrs ago and have since been putting a drop of oil at wiper to shaft junction at wiper changes on those.If seal is good oil just stays around, if seal is bad oil goes in and prevents seizure,win win.Will now be doing same to beemer.
PS the beemer is so much easier(3 on1to10) ,On the volvo this all had to be done from under inside dash(9 on1to10),past all the heater hvac ducting,wires rats nest
