E46 Xi Forum
Old 05-15-2013, 11:30 AM   #1
mikee30
My Ride: BMW
Wheels help
Hi,
Would wheels from a non 330xi fit directly on to a 2005 330xi? For example, 18" ZHP wheels, or even the various 17" sport wheels which I believe are ET46?
Wasn't sure if the xi had something special that prevented the use of other wheels from other e46's.
Thanks!
mikee30 is offline   Reply With Quote
Old 05-15-2013, 11:44 AM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
being AWD you dont want to run a staggered setup with different wheel diameter but some have done it and it turned out fine.
I think they will mount.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 05-15-2013, 11:55 AM   #3
mikee30
My Ride: BMW
OK thanks. So I can run ET46 wheels of the same offset?
Old 05-15-2013, 03:30 PM   #4
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Non Xi E46 wheels will fit on the Xi with no issues. You'll want to pay attention to the tire size and keep the rolling radius as close to a match as possible. Due to this need most Xi drivers choose to go with squared wheels and utilizes spacers to flush out everything on all four corners.
Old 05-17-2013, 09:28 PM   #5
mikee30
My Ride: BMW
OK, thanks.
So the stock setup on a XI in 17" format is 205/50/17 right?
Also, should I be running 7Jx17 or 8Jx17 all around?
Thanks!
Mike
Old 05-17-2013, 11:34 PM   #6
My325XI
My Ride: 03 325XI Sprt Prem
Correct. I have stock 17" and they are 205/50/17 rim is a 7Jx17. On an 8in rim, you would most likely run 215 or 225. I'm not sure of the exact range.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 05-20-2013, 11:47 AM   #7
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Originally Posted by mikee30 View Post
OK, thanks.
Thanks!
Mike
I'd suggest a 225/45/17 on a 17x8. For a 17x7 you could also run this tire size as it's at the lower edge of the optimal wheel width range.
