E46 Xi Forum
Old 05-16-2013, 07:17 PM   #1
jonnie325xi
My Ride: 2004 325 XI
Rear Inside Tire Wear
Just took off the rear wheels to clean the insides, good thing !
The inside of the tires are ready to show me the canvas, what causes this?
Im ready for new tires anyway but dont want to wear them out.
What parts do I need to replace?
Car drives great and just had a alignment 5 K ago.
From behind the car looks normal, no crazy camber noticible.
jonnie325xi is offline   Reply With Quote
Old 05-16-2013, 10:29 PM   #2
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
welcome to bmw ownership, stay a while and get some rear adjustable camber arms (or rotate your tires)
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 05-17-2013, 12:32 AM   #3
Kubica
My Ride: 2003 325xi
What kind of tires?
It sounds like you got a bad alignment. Bad RTABS could cause this as well.
Old 05-17-2013, 08:05 AM   #4
jonnie325xi
Originally Posted by Kubica View Post
What kind of tires?
They are continental contipro contact and have about 40 K on them, they are due to be replaced but I noticed ALOT more wear on the insides of the rears.
I'm going to change the rear trailing arm bushings and put some new sneakers on it.
Old 05-17-2013, 08:25 AM   #5
Kubica
My Ride: 2003 325xi
Check the RTABs before you buy them. Do you have the last alignment printout?
Old 05-17-2013, 10:34 AM   #6
jonnie325xi
No I don't have the print out but I can probably get it, Its had a 4 wheel alignment 2 times at the dealer in the past 20,ooo miles due to work I did on the front end, tie rods, and control arms.
What should I look for at the RTAB,s I actually think they are original 165K.
Old 05-17-2013, 11:58 AM   #7
Kubica
My Ride: 2003 325xi
Jack up each rear wheel and shake it to look for worn RTABS.
Old 05-17-2013, 12:46 PM   #8
jonnie325xi
I'll give em a shake, Thanks
