Old 05-16-2013, 10:25 PM   #1
Saintluk2
My Ride: 2000 323i sedan
Disa @ 190k miles
Took it out today and it looks okay. Took it apart as far as the rebuild kit suggests, and put it back together. Only bad thing is it kind of fails the vacuum test. Instead of holding the flap still it slowly returns to closed position. Does that seem like the internal seals are failing ?
Saintluk2 is offline   Reply With Quote
Old 05-18-2013, 04:48 PM   #2
dznuts007
My Ride: 2001 325i Sedan
That's what mine was doing. Everything was nice and clean and actually perfect for having 270k+ miles on it, but it wasn't holding vacuum. It would only hold vacuum if I first plugged the hole, twist the flap and then let go. Diaphragm is probably gone
dznuts007 is offline   Reply With Quote
Old 05-18-2013, 05:03 PM   #3
Saintluk2
yeh that diaphram. I tried to open the plastic cover on it that seems to be held only by two clips, but it wouldn't budge and i didn't want to snap the clips. Car runs fine.
