Sponsored by BAVSOUND
Old 05-17-2013, 01:36 PM   #1
Rich L
My Ride: E46 Compact 320td
Whine on one tweeter after speaker install
One for electrical/audio install experts...
I've replaced the oem speakers in my Compact with some Focals. I've now got a bit of alternator whine, on one (drivers side) tweeter only. No problem on the other tweeter or either woofer. It increases when the side lights are switched on, and increases again when going to headlights.
I've also noticed that I get a buzz from this tweeter with engine OFF (again increasing going from side to head lights) but the lights switched on (again increasing going from side to head lights). I've switched the wiring so that the driver's side speakers are fed by passenger side channel from the head unit - problem stayed with the drivers side. Switching the HU on/off makes no difference to the degree of noise. Twiddling the instrument dimmer has no effect.
My wiring from the crossover (mounted behind glove box) passes pretty close to the light switches (and maybe tie-wrapped to the lighting cabling thinking about it now), and from the above this proximity and consequent induced noise looks likely to be the culprit. I'll trying some re-routing of course, but even then, the tweeter (I've maintained factory location in the mirror sail) is pretty close to the light switch anyway so don't yet know if this will help.
Does anyone know if shielded cabling can sort this, or can the lighting circuit have some sort of suppressor added (or any other possible solutions)?
Rich L is offline   Reply With Quote
Old 05-17-2013, 10:03 PM   #2
ccaudio1
My Ride: 330i
Re: Whine on one tweeter after speaker install
I would pull the crossover away from the wires to see if it fixes the problem. If so relocate the xover
Ride: 2001 330i
Radio: Clarion NX500
Amps: Diamond Audio
Speakers: DLS Audio
Subwoofers: (2) 12" MB Quarts
MODS: Coming Soon
ccaudio1 is offline   Reply With Quote
Old 05-18-2013, 08:56 PM   #3
TnT817
My Ride: 01 330ci
Like you said there are quite a bit of electrical equipment behind the glovebox and can almost guarantee that's your issue. Try to put your crossover out in the open and see if it continues.
TnT817 is offline   Reply With Quote
