Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > New England
New England
MA ME NH RI VT
Old 05-19-2013, 07:26 PM   #1
mg42
My Ride: 2000 323Ci
What part of my cooling system did I break. Thermostat housing?
Radiator hose(I think) let loose and took a chunk of plastic with it. Help a noob figure out what parts I need to order.
mg42 is offline   Reply With Quote
Old 05-20-2013, 07:11 AM   #2
mg42
My Ride: 2000 323Ci
Bump.
Old 05-20-2013, 07:16 AM   #3
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
It did not take a chuck out, rather it is your upper hose that broke.
That is your upper hose. About $25-30 online. BMAParts.com, or RmEuropean.com.
You need to look at your whole cooling system to see if other parts need replacement.
Use BMW coolant with distilled water too.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 05-20-2013, 08:02 AM   #4
trizzuth
My Ride: 231k, 16yr old B3AST
NEGATIVE captain. Upper hose appears to be fine here, what broke off was the large nipple on the expansion tank that the upper hose clamps or rather "snaps" into. And from the looks of it, the reason why it may have cracked is that there is some sort of metal clamp around the hose that is normally not there. That upper hose is a tight compression fit on that large nipple with a black spring clip that you push in to lock the hose on once it's in place. Something sketchy may have gone on here before.
trizzuth is offline   Reply With Quote
Old 05-20-2013, 08:06 AM   #5
04330ciZHP
My Ride: E46 E90
Re: What part of my cooling system did I break. Thermostat housing?
Bmw captain is correct. The upper hose is broken.
04330ciZHP is offline   Reply With Quote
Old 05-20-2013, 08:10 AM   #6
e46jki44
My Ride: e46 325i sedan
Do you not see the entire upper hose is ripped from the connection. That connection is not part of the expansion tank. It is part of the whole upper hose assembly. So captain is correct.
Sent from my SPH-D710 using BimmerApp mobile app
e46jki44 is offline   Reply With Quote
Old 05-20-2013, 08:13 AM   #7
mg42
My Ride: 2000 323Ci
My expansion tank went about this time last year. Had my mechanic replace it as well as the water pump. Did he mess something up? I think there is a warranty on the parts I got as well.
Old 05-20-2013, 08:19 AM   #8
BMWCaptain
You should take a look at the part online and you will see what makes up the upper hose.
Have you EVER taken one off? Probably not!
BMWCaptainE46.com
Old 05-20-2013, 08:31 AM   #9
mg42
My Ride: 2000 323Ci
Ok ordering this part http://www.bmaparts.com/ShopByVehicl...t+Hose&mode=PA Thaks for the help! Looks like a pretty easy fix.
Any idea why this would have happened? I was going through bumper to bumper traffic on the highway for about 3 miles when this happened, 1-2 gear the whole way.
Old 05-20-2013, 08:35 AM   #10
SeanC
My Ride: 330i
You have no idea wtf you're talking about lol!
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
Old 05-20-2013, 09:50 AM   #11
pawelgawel
My Ride: 330CI
^ second that.. upper hose needs replacing
pawelgawel is offline   Reply With Quote
Old 05-20-2013, 08:51 PM   #12
mg42
My Ride: 2000 323Ci
Bump for why my hose blew? Learn as you break it mechanic here.
Old 05-20-2013, 09:19 PM   #13
BMWCaptain
Probably have a problem with your cooling system that caused loss of coolant and then pressure build up.
Need to examine it all.
Check your water pump for proper operation.
Look for any leaks.
BMWCaptainE46.com
Old 05-21-2013, 03:33 PM   #14
Kubica
My Ride: 2003 325xi
Whoa. Wildly incorrect.
Old 05-22-2013, 07:58 AM   #15
trizzuth
Oops, my bad you fvck-faces. I had twisted the picture 90 degrees in my mind, I was thinking it was the metal clip area you can see to the bottom left.
Yes I have replaced cooling systems in their entirety on both my E46's, one of them I had to do the ET twice because the aftermarket POS was a POS.
so yeah, how the F does a hose shear off like that, especially that thick. Unless you had so much pressure in there it blew apart? Is there fluid everywhere? I can't really see it. Do not drive the car like this dude, fix that Asap.
Old 05-22-2013, 07:59 AM   #16
trizzuth
P.S. please make sure you replace the coolant with only OEM BMW blue coolant mixed 50/50 with distilled water. thank you.
Old 05-22-2013, 08:32 AM   #17
BMWCaptain
Trizzuth, you are the FVCK Face.
You are so stupid and your comments hold no water. Both ends of the hose has the connection.
You just can't accept the fact that you don't know what you are talking about.
No one cares about what you say now, you have no credibility fvck face!
BMWCaptainE46.com
Old 05-22-2013, 08:34 AM   #18
BMWCaptain
Oh Yeh, look at it now, we try to make a comment about it.
No one cares what you say now.
We don't need people like you here that act like you do.
BMWCaptainE46.com
Old 05-22-2013, 08:57 AM   #19
trizzuth
Listen Fvck face, have you ever made a mistake? I normally don't but in this particularly rare case, I read the thread quickly, peeked at that picture quick as well and had it turned around 90 degrees in my head, which is why I said what I said. Honest mistake and I owned up to it.
Now, you want to learn Mr Engine Swap? Read the advice I've posted in 4000+ posts and learn yourself something fierce. Noob.
Old 05-22-2013, 09:00 AM   #20
trizzuth
Oh wait, technically, I was partially right, and all of you were wrong.
CLEARLY it is not the upper hose that broke, but the plastic piece that the hose is clamped to from the factory, so YES, while it is part of the hose assembly that you buy, the HOSE ITSELF did not shear off, it was the plastic.
WIN.
