Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > New England
New England
MA ME NH RI VT
Old 05-22-2013, 10:17 AM   #21
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Originally Posted by trizzuth View Post
Oh wait, technically, I was partially right, and all of you were wrong.
CLEARLY it is not the upper hose that broke, but the plastic piece that the hose is clamped to from the factory, so YES, while it is part of the hose assembly that you buy, the HOSE ITSELF did not shear off, it was the plastic.
WIN.
Hey Arse Fvcker, you can't say anything now because you were wrong and your Ho approach sucks.
No one cares!
Ps: FYI you said it was the nipple on the ET.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 05-22-2013, 10:38 AM   #22
trizzuth
My Ride: 228k, 16yr old B3AST
No one cares!
yes, i realize this. when I said "nipple" I was struggling for the proper word choice, as obviously when you think "nipple" you are not thinking about a 2-inch size plastic hole. I was referring to the male piece of plastic that shoves into the female end of the upper radiator hose. Whatever you call that.
At least OP knows what is up now because of the horrible advice I gave him
trizzuth is offline   Reply With Quote
Old 05-22-2013, 02:05 PM   #23
BMWCaptain
Hey Fvck tard, you don't even know the difference between male or female. It is female hose connection that goes on the Exp Tank and Radiator male connection.
Yeh, it looks weird because that is just the metal clamp that goes over the hose. Maybe you havent seen a hose before.
Just give it up Arse Fvcker.
PS: you didn't give the OP any advise, rather all you did was negate the advice I had given, which was correct.
BMWCaptainE46.com
Old 05-22-2013, 09:20 PM   #24
mg42
My Ride: 2000 323Ci
Ok So while y'all are arguing I REALLY dont know what I am doing I just got my upper hose and coolant tonight. Going to try to replace the hose and coolant tomorrow and see what happens. Hopefully that does the trick. Any advice/pointers is greatly appreciated as I have never personally messed with the cooling system. Looking up youtube videos.
Yes the coolant spilled everywhere, went up in a cloud of coolant smoke. I replaced my water pump and expansion tank this time last year so hopefully they are functioning properly.
I got BMW coolant but does it really matter?
mg42 is offline   Reply With Quote
Old 05-22-2013, 11:34 PM   #25
trizzuth
What part of my cooling system did I break. Thermostat housing?
To BMW captain it does not matter, which means it does matter.
Old 05-23-2013, 12:00 AM   #26
E46Snowball
My Ride: 330i
Re: What part of my cooling system did I break. Thermostat housing?
Trololol
Sent from my Droid using BimmerApp mobile app
2003 330i
Imola Red
Zhp Package
6 speed
E46Snowball is offline   Reply With Quote
Old 05-23-2013, 04:41 PM   #27
mg42
My Ride: 2000 323Ci
So I put the new hose in + coolant. Fired her up and everything looked fine. Drove up and down the road and the needle stayed right where it should. Then I decided to drive home, got a 1/4mi down the road and the needle started creeping up again. Pulled over, let the engine cool then drove back to my friends house. Watched the temp and it stayed right where it should. So I have come to the conclusion that either my car does not want to go back home or my thermostat is broken?
Old 05-23-2013, 05:50 PM   #28
7xWDC-MSC
My Ride: 2005 325xi
If your Tstat was broken the needle would move down as you drove, you likely have air still in your system.
Check out mangos cooling thread sticky in the general E46 forum for proper bleeding.
Rubs the roundel on its skin or else it gets the hose again.
7xWDC-MSC is offline   Reply With Quote
Old 06-08-2013, 06:40 PM   #29
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
X2...You need to bleed the air out of the system.
Build Thread | S54 Vanos Thread
-TTFS Engine/SMG Tune- SGT Headers/Sect 1/SCZA- Evolve Eventuri- Sprint Booster V2-
-UltraGauge- Orion V4's- CF Lip/Console/Diffuser- VIS XTS CF Hood- LED Fogs- Valentine One- Turner 15F/12R Spacers-
WOLFN8TR is offline   Reply With Quote
