Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 06-14-2013, 06:57 PM   #21
ti317
My Ride: 02 330ci coupe 5 spd
Any updates?
The only difference between death and taxes is that death doesn't get any worse every time Congress meets. - Will Rogers
ti317 is offline   Reply With Quote
Old 06-14-2013, 10:50 PM   #22
philljones54
My Ride: 03 325xi
Re: High beam problems please help
I downloaded NCS Expert from bmw coders it was part of a package had everything I need except the NCS part is in German so no luck there. I hit up paul180 but he doesn't have the proper program. I was thinking what if I put xenon lights in wouldn't it work then?
Sent from my Torque using BimmerApp mobile app
philljones54 is offline   Reply With Quote
Old 06-15-2013, 10:52 AM   #23
ti317
It will be mostly or all in German but you can still use it if you get enough documentation and proceed carefully.
This manual my help
https://rapidshare.com/#!download|55...8293B9648072B9
Hot some other forums like Bimmerfest or North American motoring for help.
Old 06-15-2013, 06:52 PM   #24
philljones54
My Ride: 03 325xi
Right on ill get into it more when I put the kid to bed. Thanks
Old 08-18-2013, 10:33 AM   #25
philljones54
My Ride: 03 325xi
Update: the program I have is missing the usb.setup.exe so the computer won't read my car and I've had no luck finding a solution to this simple problem
Old 08-30-2013, 06:38 PM   #26
philljones54
My Ride: 03 325xi
So I went to the dealership today and have a diagnosis turns out the LCM got wet due to the drain from the sunroof in the A piller beam being clogged and over flowing down onto the LCM. Which also rusted the airbag (they said its still safe). 1204.20 to fix that also it seems there's more another $4000 in **** that needs fixed.
Old 08-31-2013, 08:37 AM   #27
ti317
Yikes! Run, Forrest, run! Get the estimate in writing, tell them you can't afford it and use that for your parts list. You can probably get a used LCM cheap and do it in an hour or two saving over a grand right there.
Good luck man. Keep us posted.
Old 08-31-2013, 08:40 AM   #28
ti317
$250 to run a piece of weedwhacker line down the drain line and then blow it out with compressed air? Tell them to kiss you. If they're going to f you, they should at least kiss you.
Old 10-29-2013, 05:39 AM   #29
philljones54
My Ride: 03 325xi
Up date I've ordered a used lcm from bimmeroem@gmail.com who is going to program it for me for 130$ shipped
Old 10-29-2013, 07:29 AM   #30
ti317
Much more better solution. Good luck, keep us posted
Old 11-03-2013, 08:53 PM   #31
philljones54
My Ride: 03 325xi
I got the LCM today! And I got some trimmer line ran it through the sun roof drain came out clean. So i took the a pillar trim off and the left upper air duct took out the old LCM and I can't find moisture or any sign of a leak. Maybe the dealer was trying to F me in the A no surprise. But I hooked up the used reprogrammed one I got and MY HIGH BEAMS WORK!! So much happier now..
Old 11-03-2013, 09:40 PM   #32
ti317
Nice!
Old 02-16-2014, 07:50 PM   #33
philljones54
My Ride: 03 325xi
Passed the state inspection finally!
Display Modes
