E46 Xi Forum
Old 05-19-2013, 11:02 PM   #1
autoAER
My Ride: 2005 325i 5MT
new project suggestions?
hey guys, hows everyone doing today?
just curious on opinions here. I've saved up a substantial amount so I can start doing some perfecting on Leila, my 03 325xi. However, i cant afford more than $1000-$1500 in parts. That being said, i already have quite a bit of experience with how expensive these cars are to make serious changes. So, what are the best 'bang for your buck' modifications (aesthetics or engine!) that are do-able on the xi?
thanks!
Past: 2006 330i, 2006 325i 6MT, 2003 325xi
Current: 2008 335i E90 N54, 2005 325i 5MT
autoAER is online now   Reply With Quote
Old 05-20-2013, 06:27 AM   #2
Foxtrot_Uniform
My Ride: 325Xi
A new cooling system.... Well... Someone was going to say it!
Foxtrot_Uniform is offline   Reply With Quote
Old 05-20-2013, 08:18 AM   #3
GSherbs
My Ride: 2002 330 xi
Best bang for the buck in terms of performance modifications has to be suspension upgrades.
For $1500 bucks, if you are willing to DIY, you can put a top-notch suspension on the car without excessively lowering it. Won't make you any faster in a straight line but will definitely make the car feel like its on rails in a corner.
And, FYI, there really isn't any mod outside of force induction that'll make you even the slightest bit faster in a straight line - just forget about it.
GSherbs is offline   Reply With Quote
Old 05-20-2013, 10:07 AM   #4
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
hookers and cocaine in vegas
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 05-20-2013, 10:08 PM   #5
autoAER
+1
I was also interested in a backseat hashish dispenser
With hookah hoses replacing the seatbelts
Fasten up, my friends
Old 05-20-2013, 10:09 PM   #6
autoAER
Thats a great idea! A new cooling system Will forsure improve my cars performance in california heat. However, how might such a modification be in terms of cost?
Old 05-20-2013, 10:18 PM   #7
autoAER
thanks! yeah i figured my xi would neverbe the fastest girl on the block. and i dislike when m and non m owners alike tell me to sell my car and get an m. a bmw is a bmw, m or not. so as far as straight line performance, im not too worried. so a suspension setup is definetly a good suggestion. are there any brands you might reccomend?
Old 05-21-2013, 06:40 AM   #8
jony787
My Ride: 318ti M52tu SWAP
I have gc coilovers with stock shocks and i love them. Pm me for details cheers!!!!
jony787 is offline   Reply With Quote
Old 05-21-2013, 08:20 AM   #9
GSherbs
I've got h&r coil-overs on my car.
For me, they are a love-hate relationship.
The good: car corners like its on rails - almost no hint of body roll or nose dive. Absolutely superb handling, great road feel, and just the right amount of lowering with the coil-overs set to their highest setting.
The bad: given the conditions of the roads up here in Chicago, its just not a practical setup. Its too hard on the car and even a bit too hard on myself at times. My strut towers have mushroomed pretty dramatically and the strut tower mounts wear out very quickly.
If I lived in Cali, the bad would likely be mitigated quite a bit. Your roads out there are in much, much better shape than ours. I would recommend the h&r in your case but there are other options that people love as well...
Check out koni/eibach pairings and bilstein/eibach pairings...
Old 05-21-2013, 06:39 PM   #10
DavidDee
My Ride: 2004 325xi
Ground Control makes XI coilovers?
"It has a radio and speakers but it's kinda hard to hear over horny bitches moanin in the back when I start it up.."
DavidDee is offline   Reply With Quote
Old 05-21-2013, 08:16 PM   #11
jony787
No, used the ones for e46 rwd, rear is the same, front need to be modified but isnt hard. look into the forums i made a post a few months ago
Old 05-21-2013, 11:12 PM   #12
autoAER
Well, ive been looking into coilovers (h&r), but first, just for an insight, has anybody driven both the xi and a comparable i? What is the difference in handling? My guess would be that the xi has more grip, but the extra weight leads to more body roll. (which i have been annoyed by many times......)
My target handling type that i would like to modify my xi into is that of an e36 m3, which i have driven before and also love, but im curious about the rwd e46 handling behavior
The limited slip differential on my car paired with h&r coilovers seems as if it will give me the e36 m3 handling behavior. Any thoughts on this?
Old 05-22-2013, 11:06 AM   #13
redbull 325is
My Ride: 325xit/6
H&R coils, poly front cabs (mine are not offset), and adjustable rear control arms with camber set to 1 degree less than front camber setting will get you close to rwd handling feel. my car will rotate in a turn now, vs just plow like an OE xi,.
Old 05-24-2013, 02:33 PM   #14
autoAER
Well, I've ordered the h&r coil overs. Should be shipping out soon. Just out of curiosity though, I've had a perfect track record with maintenance so far. My xi has been running flawlessly since the day I got it. I know of some mods that eventually lead to maintenance issues. Do coilovers eventually lead to problems?
Old 05-24-2013, 02:38 PM   #15
autoAER
I'm also not sure about the control arms or the camber as well, has anyone done a DIY on this? I will go search for one now
Old 05-24-2013, 02:40 PM   #16
indoafro
My Ride: 325ci
well for 1500$ you can purchase a coilover + exhaust man...
indoafro is offline   Reply With Quote
Old 05-24-2013, 03:46 PM   #17
autoAER
Iffy about the exhaust... Unless there's a real nice one that doesn't sound fart can ish or rice... And the deep exhaust note exhausts with any sort of gain for the car are the most expensive ones :/ ill be sticking with my golf tee mod for now
