Sponsored by BAVSOUND
Old 01-26-2013, 09:13 AM   #1
Gareth-325CI
My Ride: E46 325CI
Been asked a billion times but...
Gents / Ladies,
Ive just picked up a lovely little 325CI Coupe on a 52 plate (2002) & ive been looking at upgarding the woeful stereo system that really lets the car down.
Ive literally searched on hundreds of site's for info on wiring & no one seems to have same system as me!
I have business head unit running bluetooth module & 6 disc changer in turn powering 4channels front & rear with two speakers rear deck at 4ohms (yes have checked these are original!).
Can anyone advise wiring diagram for this set up as nothing else seems to match? in particular the rear polarity at speakers not head unit?
Thanks in advance
Newbie
Gareth-325CI is offline   Reply With Quote
Old 01-26-2013, 09:29 AM   #2
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
send an email to bsw, they know these systems
http://www.bavariansoundwerks.com/contactForm.php
i knew it when i did mine but have since forgotten wire colors and polarity
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 01-26-2013, 09:39 AM   #3
Gareth-325CI
My Ride: E46 325CI
Thanks, ill give me i try!
Old 01-26-2013, 10:46 AM   #4
r3g
My Ride: 04' 325i
if you aren't an audiophile and don't want to do a ton of work I put these in my door and rear and couldn't be happier for the cost/effort put in.
http://www.bestbuy.com/site/Infinity...&skuId=4910842
r3g is offline   Reply With Quote
Old 01-28-2013, 04:12 AM   #5
Gareth-325CI
My Ride: E46 325CI
Thanks guys, i emailed BSW but they couldnt help however after taking car apart on Saturday with a bit of luck & a test meter ive managed to solve issues & even get bluetooth working ( previous owner insisted this option wasnt fitted until i rang him from car!)
For anyone who needs to know:
Remote switching power from stereo is white cable on pin 16
Rear Deck speakers brown common ( Neg )
Blue right Positive
Yellow left Positive
Also dont use OEM battery clamp for earthing create new connection, this will help with background noise which will be created whenever adding an AC (speaker) cuircuit to a car.
(On 2002 Facelift 325CI Coupe None HK)
G
Old 01-28-2013, 04:42 AM   #6
chickenalfredo
My Ride: 2001 325xi
Originally Posted by Gareth-325CI View Post
Gents / Ladies,
Thanks in advance
Newbie
Hmm, I have a business cd module too in my 2001 bmw. I've put one CD in it, does that mean I can put in 5 more?
chickenalfredo is offline   Reply With Quote
Old 01-28-2013, 04:57 AM   #7
Gareth-325CI
My Ride: E46 325CI
Errrh, i wouldnt try it unless you have a changer in boot, although mines badged as BMW i think its an Alpine by looking at it. Good news is you can add / remove stuff. So if you havent got a changer you can add one. Check what plug you have on back of unit. If its the round pin variant its pretty straight forward.
Old 01-28-2013, 08:21 AM   #8
vandyboy
My Ride: 2001 325i
Gareth, I replaced my 6.5 rear deck speakers with InfinitI Kappas. They sound good and work fine. Your best bet for a complete sound overhaul is to replace the head unit. If, like me, you want factory look, then replace all four big speakers and a couple of the small ones and run them off a better amp.
vandyboy is offline   Reply With Quote
Old 01-28-2013, 12:17 PM   #9
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
You only put one cd in the unit. The changer will be located in the trunk if you have one or want to put one in.
HacksawMark is offline   Reply With Quote
Old 01-29-2013, 04:51 AM   #10
Gareth-325CI
My Ride: E46 325CI
Aaaah a proper Audiophile then Vandyboy?
Yeah ive had the Kappa's before but only the 6x9s which where pretty cool & high end was very clear. Did you use aftermarket adaptors? & what size did you fit?
Ive seen several on market but most only give option on 13cm driver. Have fitted cabling in for amps etc & have run high level speaker cables from rear deck.
Anyone out there fitted subs in wheel / floor space between space saver wheel & floor panel? looks big enough for a couple of 8" without loosing tyre but would be a lot of work!
Old 05-21-2013, 11:11 PM   #11
Martialartsblac
My Ride: 2002 325ci
Send a message via Yahoo to Martialartsblac
Did you use adapters for the 6.5 speakers?
Mods: 2002 325ci led tails-yellow hid fogs-Miniture schnauzer in back seat
Martialartsblac is offline   Reply With Quote
