Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 4.50 average. Display Modes
Old 06-14-2013, 03:55 PM   #121
SK330ci
My Ride: 02 330ci w/ 3 Pedals
Originally Posted by Zak@ActiveAutowerke View Post
Missfires are detected by how long it takes the crankshaft to spin. The car knows the "delta time" between each cylinder should be very close to the same on an engine running smoothly. When it senses a delay between the crank position of one cylinder to the other it assumes it missfired. As I was told by RRT the car was never REALLY missfiring just throwing out random codes on all cylinders. Seems the crank sensor was getting a weird signal every once in awhile making the DME believe there was a missfire.
Thank you for coming in.
So when will we see a very good to perfect AFR number while at WOT on this car running your stage 2 kit?
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 06-14-2013, 07:04 PM   #122
JohnBlaze
My Ride: Black Sunshine
Chase,
where's the dyno graph?
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 06-16-2013, 02:36 PM   #123
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Well, misfires seemingly went away... for 250 miles. Then came back on cylinder 1, 3, and two "random misfires". I will need to get RRT to look at it again to see if they think there is anything else from a mechanical standpoint that needs to be done.. but we've gone to the end of the world here on a mechanical side..
Well, I'm sure they will figure it out.. I just guess it has to be remote tuned at this point.. given we've swapped out just about everything else.
For what it's worth, i'm idling (and cruising) around 14.5 AFR (according to the prosport gauge). Does that seem about right?
Originally Posted by JohnBlaze View Post
Chase,
Hasn't been on dyno since it was first installed
The thought was to get rid of all the misfires and ensure that we had everything mechanically flawless prior to running it for an hour plus on the dyno.. trying to help out the motor as much as we can
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 06-16-2013, 06:03 PM   #124
SK330ci
For what it's worth, i'm idling (and cruising) around 14.5 AFR (according to the prosport gauge). Does that seem about right? For idle and cruising, YES that's fine.
This "Problem" is starting to look AA tune related, I can't think of anything else (parts) you could replace.
Edit: I guess you could send all 6 injectors out to RC Fuel Injection for Service/Cleaning. $144 plus shipping, it wouldn't be a bad idea if they've never been cleaned. If there's a problem, they'll tell you.
http://www.rceng.com/
Old 06-16-2013, 09:34 PM   #125
2000_328CI
2000_328CI's Avatar
RRT Racing : An Active (Autowerke) Approach To 400 Horsepower In A 328Ci
The injectors are all new from active
Old 06-16-2013, 09:59 PM   #126
SK330ci
Ops, forgot about that.
Old 06-17-2013, 08:33 PM   #127
BobbyC
My Ride: 2000 328I
Fuel pump changed yet??? Fuel feeds 6,5,4,3,2,1 from the pump. Are you still running the meth?
BobbyC is offline   Reply With Quote
Old 06-24-2013, 11:33 AM   #128
JohnBlaze
Zak and or anyone at Active, why don't you fly up and get this mans car running as it is supposed to be?
Old 06-24-2013, 12:10 PM   #129
BoostedZHP
My Ride: ZHP
Re: RRT Racing : An Active (Autowerke) Approach To 400 Horsepower In A 328Ci
Not a bad idea
Sent from my Nexus 4 using BimmerApp mobile app
BoostedZHP is offline   Reply With Quote
Old 06-26-2013, 02:19 PM   #130
2000_328CI
2000_328CI's Avatar
The pressure from the pump "seems" fine based on pressure readouts... the strange part is that these misfires aren't occurring at higher rpms (where fuel pump could become more of an issue).. they are between 1800-2300 RPMs... at which the OEM pump should be more than adequate.
Would LOVE that.
Originally Posted by BoostedZHP View Post
Not a bad idea
Doubt it will happen.
Old 06-26-2013, 02:53 PM   #131
BoostedZHP
My Ride: ZHP
Would LOVE that.
Chase,
What does your timing and vanos look like?
Old 06-26-2013, 02:56 PM   #132
2000_328CI
2000_328CI's Avatar
Chase,
Would have to ask RRT and relay their 2 cents.. I don't even have a penny on the topic
Old 06-27-2013, 11:17 AM   #133
BMW_Knight
My Ride: STG2 ZHP,E70 X5(DD)
Send a message via ICQ to BMW_Knight Send a message via AIM to BMW_Knight
Take it to Frank......
Thanks to: www.getbmwparts.com www.aatuning.com www.toyotires.com
Eurowerkz Mid-Atlantic Regional Director
Join the Eurowerkz Facebook Fan Site : Click Here
Need your car coded with Euro Options? (Remote Windows up, Corner delete, DRL off, etc.) PM Me
BMW_Knight is offline   Reply With Quote
Old 06-28-2013, 10:26 AM   #134
2000_328CI
2000_328CI's Avatar
Beautiful drive to work this morning.. took a little sound clip as I have been asked for more by a couple people on here
Old 06-28-2013, 11:42 AM   #135
JohnBlaze
400 hp huh, can you post your latest Dyno sheet. Would like to see...
Old 06-28-2013, 01:03 PM   #136
2000_328CI
2000_328CI's Avatar
more catchy youtube title. I gotta make those mad monies off youtube hits
And the 400 estimate is crank. But we shall see soon enough
Old 06-28-2013, 01:25 PM   #137
JohnBlaze
No doubt you can attain that number on the dyno when the tune is fixed. Guess Active won't appropriately be stepping up to the plate, good thing you're close to Frank Smith so he can get you straight...
Old 07-08-2013, 07:19 PM   #138
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Bump for update.
Has it been to the dyno, if so what are the new AFR numbers ?
SUMMIT POINT WV 1:24:229 SCCA
Old 07-13-2013, 06:47 PM   #139
2000_328CI
2000_328CI's Avatar
Originally Posted by Rob43 View Post
Bump for update.
Not on the dyno yet. SES has disappeared and not come back though despite 300+ miles driven.
Car is at RRT for new tires, Vorshlag camber plates, lowering, and then hopefully dyno tune.
Will be at Bimmerfest and RRT will be on hand to answer any questions.
Old 07-13-2013, 09:05 PM   #140
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
Are you ready to show us a coupe is faster than a touring?
/_________\
O==[][]==O
