Old 05-20-2013, 06:35 PM   #1
dbarton62
My Ride: 04Z4R VF 12PSI
AFR sensor installation
I am having trouble determining where I should be tapping in a sensor for an Air Fuel Ratio gauge.
I have read that #6 cylinder runs richest but I have also read that #6 runs leanest.
I understand that you want to get the signal from the leanest cylinder.
My questions are
1)can you remove one of the factory O2 sensors per-cat and screw in the wide band sensor or do you need to install a new bung?
2)if I need to weld in a new bung where should it go?
I have stock manifolds.
Dave
dbarton62 is offline   Reply With Quote
Old 05-20-2013, 07:14 PM   #2
SK330ci
My Ride: 02 330ci w/ 3 Pedals
Weld in new bung, Refer to picture for bung hole location.
I had to, I had to say Bung Hole.
Anyway, that's where I'd put.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 05-20-2013, 07:29 PM   #3
dbarton62
Love Bevis and Butthead.
Thanks for the reply, would prefer not to remove the manifolds but if it's the only way so be it
Dave
Old 05-20-2013, 07:57 PM   #4
SK330ci
Dave
Let this play out for another day or so and get a few more opinions, they're many smart people on this forum. But that's the way I'd do it.
PS, remember to disconnect the battery before you weld anything; your ECU with thank you upon start up.
Old 05-20-2013, 08:28 PM   #5
dbarton62
No worries will do.
Good to be informed
Old 05-22-2013, 04:39 PM   #6
dbarton62
Anyone else have any insight into this?
Can,t believe with all the FI E46 out there, there isn,t anyone who has installed an AFR gauge and sensor.
Dave
