E46 Xi Forum
Old 05-21-2013, 08:15 PM   #1
Iggy27
My Ride: 2003 330xi
Help car won't start
I tried to start my car and thing happens. I tried to jump it and still nothing. I can hear the pppff noise from the fuel pump. Is it the starter you think? The last couple weeks when it starts it takes a couple seconds for it to start. I was about to change my battery but I don't think that is the problem.
Iggy27 is offline   Reply With Quote
Old 05-21-2013, 08:22 PM   #2
DavidDee
My Ride: 2004 325xi
When you put the key in and turn it (not starting it) do you hear the fuel pump prime?
"It has a radio and speakers but it's kinda hard to hear over horny bitches moanin in the back when I start it up.."
DavidDee is offline   Reply With Quote
Old 05-21-2013, 08:35 PM   #3
Iggy27
My Ride: 2003 330xi
Yea I can here the hmm noise from it. And when I turn the key to roll it nothing happens no clicks nothing. It acts as if its fully dead but very the g has power and I've tried to jump it and same happens
Old 05-21-2013, 10:06 PM   #4
Shadow330xi
My Ride: 2001 Red 330xi
when you turn the key to the 1 position, do the dash lights come on, along with the radio?
Also, have you had any problems in the past with it not starting on the first try?
Shadow330xi is offline   Reply With Quote
Old 05-21-2013, 10:09 PM   #5
Iggy27
My Ride: 2003 330xi
No everything turns on right. And it been starting rough. It has to be my starter my car has 138k
Old 05-21-2013, 11:13 PM   #6
Iggy27
My Ride: 2003 330xi
What the easiest way to change a starter? And for anyone have a website to get a good priced one?
Old 05-22-2013, 12:13 PM   #7
891CARLOS
My Ride: 2003 E46 325XI
Have you done any work involving your electrical system? I would start with the easy and inexpensive steps by testing the battery(just to make sure), alternator(can be done without removal) and checking your belts. Maybe checking your ignition(coils,plugs). When it started rough, was your starter hesitating? does it "click" when you try to start your car?
Try this:
locate the starter, have someone start the car (careful with moving parts) and if you feel a click the solenoid is trying to engage and the starter may be jammed, if there is no click its probably the solenoid. If starter is jammed, try hitting it while someone tries to start the car.
891CARLOS is offline   Reply With Quote
Old 05-22-2013, 03:26 PM   #8
Foxtrot_Uniform
My Ride: 325Xi
I'm with Carlos... Start on the cheap stuff and eliminate it. When was the last time you measured the battery voltage?
I would go get a battery terminal cleaner...
Take your terminals off... Clean the posts and the terminals... Check the voltage and get back to us.
Foxtrot_Uniform is offline   Reply With Quote
Old 05-22-2013, 05:20 PM   #9
Iggy27
My Ride: 2003 330xi
No click or sound from the engine. The lights don't dim when I engage to start. I will get the car lifted and see if someone can feel moving parts in the starter
Old 05-22-2013, 06:37 PM   #10
891CARLOS
Have you check for blown fuses? Check your engine control fuse, this may be preventing you from starting the car.
Old 05-22-2013, 06:51 PM   #11
Iggy27
My Ride: 2003 330xi
I checked the fuses buy the ecu. I guess I'll check the ones in the glove box too
Old 05-22-2013, 07:11 PM   #12
891CARLOS
Check fuse #30 engine control fuse at engine fuse box.
Old 05-22-2013, 07:30 PM   #13
Iggy27
My Ride: 2003 330xi
The one under the black box in the engine bay?
Old 05-22-2013, 07:36 PM   #14
891CARLOS
Yeah, look at #30
Old 05-22-2013, 07:42 PM   #15
Foxtrot_Uniform
My Ride: 325Xi
All this work and talk and you still haven't measured the voltage at the battery?
Old 05-22-2013, 08:06 PM   #16
Iggy27
My Ride: 2003 330xi
Like the battery or the cables the run to the starter?
Old 05-22-2013, 09:15 PM   #17
wangus
My Ride: 325ix
Sounds like my car.... Car was starting slow for a week, like a weak battery. One day it just clicked like a loose connection and then just stopped making any noise.
Checked all fuses, voltages...I could feel the solenoid and verified it was getting voltage...
Ended up being the starter... Got a brand new Bosch from advance auto parts for $150
Replaced it from the top....a real pain in the butt.... Took like 6 hours. There are a few threads that detail it too. Being am XI it's a bit different.... Good luck, it's a real bear of a job.
wangus is offline   Reply With Quote
Old 05-22-2013, 10:46 PM   #18
joebox
My Ride: 2001 325i
I had a coin get in the gearshift and keep it from hitting park/neutral switch and that would not allow starter to spin.
Did you turn the key and hold it then the starter took a couple of seconds before taking off (ews communication problem)try both keys
or did it drag/spin slow right away check for 12volts to starter when trying to start.
have continuous power need starter check starter conection point past where voltage was read first
joebox is offline   Reply With Quote
Old 05-22-2013, 11:19 PM   #19
Iggy27
My Ride: 2003 330xi
Yea Iam sure it's the starter too and I have a lift do you think it could be easier from the bottom?
You really got a new one for only 150? I've been looking around and I can only did rebuilt for around 170
Old 05-22-2013, 11:21 PM   #20
Iggy27
My Ride: 2003 330xi
I hold the key to turn it on and no noise comes from the starter at all. Iam taking it to a buddies house. He ha a lift we might try hitting the starter and see what happens
