Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 05-22-2013, 08:25 PM   #1
Commanderwiggin
My Ride: 900rwhp Turbo M3
E46 M3 Ultimate Fuel System
Some specs from start to finish:
-Intank Walbro 255 Fuel Pump
-Radium Multi-Pump Fuel Surge Tank
-Two Walbro 400 E85 Fuel Pumps
- -6,-8 AN PTFE Fuel Lines
- Various Anodized Fittings/Bulkheads
- Fuel Lab Fuel Filter (E85 Compatible)
- Fuel Lab Fuel Pressure Regulator w/ Radium Fuel Pressure Gauge
- Radium Fuel Rail with Pulse Dampener
- ID2000 Injectors
This setup won't work with Nav/CD pack equipped cars as the surge tank is mounted where these items are. I have a Dynavin unit which is better than the OEM nav system (IMO) so that is an alternative. Could probably move things around to "make" it fit but regardless I never had that in the first place so plenty of room was available. There is also a notched section for the fuel lines to go through which is paper thin from the factor and reinforced with thicker plate.
The goal was to keep all the trunk space and have everything hidden along with having more fuel than I would ever need...goal was achieved. I had fuel starvation issues at the road course over a year ago and have held off from track events since then because of it...so do I feel that this was a necessary upgrade for me? Yes and it provides peace of mind knowing I can do a WOT pull with under a 1/4 tank of fuel or take a long sweeping corner and mash the gas without going lean.
Keep in mind there is the added safety risk of having fuel system components mounted in the trunk area with this setup, there is no doubt on this and I accept that. We also used several 90' fittings for the best install of this setup. Yes there are pipe flow losses when using bends in any pipe system (Bernoulli's Principle - Basic Flow Dynamics) however my fuel system is over sized and the regulator is mounted close to the rail so there is no worries in regards to having a few 90' fittings...not to mention the flow losses are almost completely negligible when comparing a similar system which has no 90' bends but for the sake of argument yes there are losses but in this case it's not a problem...if you have an undersized pumping solution then yes it would be a problem.
Another awesome feature of these new Walbro 400 E85 fuel pumps is that they are extremely quiet...I cannot hear them turn on which if you've ever heard a loud fuel pump setup you will know how annoying that can be. Just look up a youtube video with the HPF track/drag car with their surge tank/fuel cell setups...so loud.
Check this website for an unbiased comparison of several in-demand fuel pumps: http://radiumauto.com/media/techarti...l-Pump-Test-87
While this setup may not be for everyone (which it isn't)...it was custom made for my requirements and I am more than pleased with the outcome.
I think pictures speak better than words:
And this was what we made with the new system yesterday:
(Fuel system had plenty more left in it FYI)
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 05-22-2013, 08:35 PM   #2
Estoril-E46
My Ride: M3
90 degree fittings aren't that big of a deal, even 1000hp fuel systems are pretty low flow. Hose size is often over emphasized too, the place it's critical is on the return line as changes in pressure there can make for some interesting quirks in pressure.
The quick but slow car:
www.Precision-Sport.com
Estoril-E46 is offline   Reply With Quote
Old 05-22-2013, 08:46 PM   #3
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Originally Posted by Commanderwiggin View Post
Dat Fuel System!
Old 05-22-2013, 08:49 PM   #4
dallasberry
My Ride: ///M3
Just when we thought you couldn't do any more to make this car better, you go and blow the lid off of any limits that were previously there. Nice work!
Custom Turbo Build By Lab22
815whp @ 625wtq 27psi E98
dallasberry is offline   Reply With Quote
Old 05-22-2013, 10:00 PM   #5
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Very nice.
I'm curious how the pumps are wired, and if the return from the FPR goes to the surge tank or main fuel tank.
Old 05-22-2013, 10:52 PM   #6
SexiPYm3
My Ride: 03 M3
Niiiiiiiice... You have done some incredible things with your car. I can't imagine how much money you have spent thus far
SexiPYm3 is offline   Reply With Quote
Old 05-22-2013, 11:23 PM   #7
Sound Performance
Past Site Sponsor
Location: Well, Dick, here's the deal: I'm the best there is, plain and simple. I mean, I wake up in the morning and I piss excellence. You know, nobody can hang with my stuff.
My Ride: Is very FAST
Very nice!!
Sound Performance is offline   Reply With Quote
Old 05-23-2013, 12:42 AM   #8
Commanderwiggin
Very nice.
Wired internally you mean? Return from the FPR goes to the Surge tank. There is also a return from the surge tank to the main fuel tank as well.
Old 05-23-2013, 12:42 AM   #9
Commanderwiggin
Perfection isn't cheap...almost there lol.
Old 05-23-2013, 01:33 AM   #10
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
now thats some serious usable power and torque... hang on tight thats all I can say...
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 05-23-2013, 01:44 AM   #11
Commanderwiggin
I forgot to post low boost graphs...lol. There was a plug change after this as the plugs I had in there before were exactly a year old. One plug the threads broke apart
The plug that broke was an IXU01-27...my new/old plugs are IXU-27's I had as spares. New set of plugs will be thrown in before I head back home.
Old 05-23-2013, 02:34 AM   #12
leletyM3
My Ride: 05 M3
Lovely set up!!! Low boost still a monster!!!
05 BMW ///M3 SMG - Jet Black/Gray
HPF Stg2 Turbo 640rwhp, Eisenmann Race 83mmx4, Volk TE37 TA, Toyo T1R, Brembo BBK 380mm 6pots & 345, 6k HID, 6K HID Fogs, Depo Smoked Corners, Strassentech Front Lip, V-CSL Bootlid, V-CSL Diffuser
leletyM3 is offline   Reply With Quote
Old 05-23-2013, 03:32 AM   #13
mike@maximumpsi
My Ride: 02M3T
Looking great!
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 05-24-2013, 12:00 AM   #14
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
Looks like a solid, stout setup without worries of meth leaks and failures causing motor damage!
MSpired is offline   Reply With Quote
Old 05-24-2013, 04:14 AM   #15
Twin_Turbo_S54
My Ride: M3
Kenton,
The location is dangerous. In case of a side collision fuel will leak, and once it happens it will leak on hot exhaust. FIRE.
You can remove the tank and place between two rear struts. Will not look as clean as it is now but much much safer.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 05-24-2013, 04:44 AM   #16
mkodama
mkodama's Avatar
Wait, so you
1. cut a notch creating a huge stress riser in a structural part of your chassis that protects you from a rearward accident on your street driven car without a cage,
2. then you routed fuel lines inside of this notch so that if you get any impact on the side or end of that rail, it collapse at the huge stress riser and will chop all those fuel lines,
3. and you haven't bothered to follow basic safety practices and seal off your fuel system from your cabin?
It's like 1:40am for me so I'm kinda tired, but am I missing something or was there a huge oversight in safety here?
Old 05-24-2013, 05:30 AM   #17
Commanderwiggin
Originally Posted by Twin_Turbo_S54 View Post
Kenton,
I stated in the original post my reasoning and risk analysis; I have gauged the risk as being highly unlikely...on a side note no more risk of meth catching on fire in the engine bay.
Wait, so you
The notch was cut in a non-structural, paper thin portion of the rear that was reinforced with 1/4 plate around the seams. Regardless as stated in the original post I am fine with the added risk and strongly believe that in a side impact or rear impact there would be no loss of containment.
I do see where you are going with this however; you are not wrong to say there is added risk by any means...so for all intensive purposes to your argument yes you are correct in your logic.
Old 05-24-2013, 06:05 AM   #18
Twin_Turbo_S54
My Ride: M3
Wait, so you
you are % 100 correct but sometimes we all strive for more power and dont put emphasis on safety.
Old 05-24-2013, 06:09 AM   #19
Commanderwiggin
Mert you perform 60-130 testing quite actively on public roads. Safety is not in your dictionary.
Old 05-24-2013, 06:38 AM   #20
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
This is just my own opinion, but I think any time you deviate from OEM, you are likely to progress deeper into a risk matrix. The OEM's, especially the German ones, are pretty paranoid about potential risk, more so than actual risk.
Personally, in a crash, I think that 1/4" steel notch structure is going to be the only thing that survives! And the radium surge tank would probably just be pushed around. While on the other side of the chassis, I've seen a few dry sump tanks (Mounted where our battery is on the E46) take quite a hit in road race cars, and they simply seem to be pushed around or broken free of their mounting point from rear-end collisions.
I kind of have a similar thing going on, but with meth.
