Old 06-08-2013, 08:54 PM   #81
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Tom's SP built 1071 RWHP Video
Regarding the high pitched wine u r hearing , I get that when I put the opposite sex in the back and step on the gas. I think that's normal
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 06-09-2013, 10:23 PM   #82
323tom
My Ride: 2 turbo e46's
Dyno jet update:
Car span the tires with me and a buddy in the trunk at 33 psi with 67% ethanol content it made 930whp and you could clearly feel the tires roasting on the dyno lol
Spoke with Larry and he said he had a tough time with my car on the dyno, apparently 600lb is needed and possibly even VHT!
Also the car does still run out of gas a notch past 1/4 tank, looks like I will need a similar setup to Kenton's
323tom is offline   Reply With Quote
Old 06-09-2013, 10:31 PM   #83
Sound Performance
Past Site Sponsor
Location: Well, Dick, here's the deal: I'm the best there is, plain and simple. I mean, I wake up in the morning and I piss excellence. You know, nobody can hang with my stuff.
My Ride: Is very FAST
I don't think that the computer will let you get to 33 psi with only 67% E. I will say that your car is one of the hardest I have ever had to get to stick on the dyno. The aggressive gearing and torque it makes just usually roasts the tires above 900 on my dyno and my rollers are bigger than a DJ. I had to put two LARGE guys in the hatch and some VHT on the tires to get it to hook.
Sound Performance is offline   Reply With Quote
Old 06-09-2013, 10:52 PM   #84
323tom
The dyno operator has a picture of it at 33 psi with E67, I was surprised myself when he showed me expected around 27-30 psi
Old 06-09-2013, 11:26 PM   #85
Commanderwiggin
My Ride: 900rwhp Turbo M3
Pull a log of it
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Commanderwiggin is online now   Reply With Quote
Old 06-10-2013, 01:37 AM   #86
Saad @ Saad Racing
Past Site Sponsor
My Ride: S600
You need to make sure that your siphon system is working properly and that your base fuel pressure is set to 73.5 psi for it to work properly. Kenton's set up could not handle your power level and is not safe for the street. But if you want to try it you should, mainly because it will help me prove my point about his setup
Originally Posted by 323tom View Post
Dyno jet update:
Saad @ Saad Racing is offline   Reply With Quote
Old 06-10-2013, 02:06 AM   #87
Commanderwiggin
Originally Posted by Saad @ Saad Racing View Post
Kenton's set up could not handle your power level.
Care to share your reasoning? I would prefer if you went into a direct comparison along with flow capacities, etc...
Old 06-10-2013, 02:11 AM   #88
Twin_Turbo_S54
My Ride: M3
Dyno jet update:
Tom,
these are all good news.
how is traction? Do you hook in 3rd gear on the road?
waiting for your 60-130 times
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 06-10-2013, 02:12 AM   #89
dallasberry
My Ride: ///M3
Not sure why you are being a dick.
Custom Turbo Build By Lab22
815whp @ 625wtq 27psi E98
dallasberry is offline   Reply With Quote
Old 06-10-2013, 02:41 AM   #90
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Cool thing about the Radium Multi-Pump Fuel Surge Tank is you get to choose the pumps. So if you want to do 1200rwhp with Kenton's setup you just change the fuel pumps to your liking, be that three Bosch's or three Walbro 400's, etc..
Old 06-10-2013, 02:56 AM   #91
Properstyle
My Ride: 2002 SMG M3
This build makes it hard for me to keep my M3 stock and stick to my z32 for power mods.... Just wow I'm really stoked about these numbers, not usable for what I like to do but just nasty non the less.
My Build..............................................AGT Diffuser group buy
Prince-B
Properstyle is offline   Reply With Quote
Old 06-10-2013, 10:09 AM   #92
Sound Performance
Past Site Sponsor
Saad, Tom's fuel pressure is somewhere in the 60s I believe. The car has 2150cc injectors in it and with the fuel pressure where it is now, drivability on pump gas suffers. It would only be worse at 73.5 psi. You should add as an option a different siphon set up that would work at normal fuel pressures like 45 psi so that the large injector cars will run properly on pump gas. Dave Jusko gave me the part numbers for the siphon out of the Lexus GS which would work at the lower pressures and you could easily incorporate into your fuel kits as an option. Let me know if you want the part number.
Old 06-10-2013, 10:12 AM   #93
bluewater87
My Ride: won racewarz
Dyno jet update:
Vid I made of Tom on the dyno
02 M3 E46 Vert Phoenix Yellow 6MT (21k miles), VF Stage 2, Evolve tuned 486whp 328wtq (SAE), Evosport Headers, CPI RT, RE El Diablo & SSK & Racebrace, TCK S/A & LCAs, H&R Sways, Vorshlag CPs, Mirror Gauges, Stoptech bbk, RAC RG63, Michelin PS3 255/40/18 285/35/18
06 M3 E46 ZCP Silver Grey 6MT, Evolve tuned 305whp 244wtq (SAE), TCK D/A & CPs, RE SSK, RB BBK, ARC-8 18x9.5 et35, PSS 265/35, 13.2@104 1.94 60' (stock 285whp)
bluewater87 is offline   Reply With Quote
Old 06-10-2013, 10:39 AM   #94
Sound Performance
Past Site Sponsor
That dyno has the old small rollers, I doubt that you will ever get it to hook up on it! The tires let go at about 900 RWHP each time and the car is instantly on the rev limiter as evident by how short the power pull is!
Old 06-10-2013, 11:57 AM   #95
bluewater87
Would the dyno graphs not look less consistent if the wheels were in fact spinning?
The three (well two ad a half) runs are all within a dozen or so whp/wtq of each other...
Old 06-10-2013, 02:12 PM   #96
being3
Modded ///Member
being3's Avatar
Tires sure looked like they spun from the video with all the black rubber in the air.... yea ha that's some Instant ON within the power band
Old 06-10-2013, 09:40 PM   #97
Saad @ Saad Racing
Past Site Sponsor
My Ride: S600
Ya, that's a great idea, send it over. The point I was trying to make though was that if you keep the car at a stock fuel pressure the factory siphon will work properly and you would have no need for a surge can that can and will endanger passengers in an accident situation. I do understand that his injectors are larger but not many guys need to run around on 2150cc inj.
Old 07-13-2013, 03:11 PM   #98
323tom
Had a lean issue pop up and my local mechanic was on vaca for almost 2 weeks but they got back this week and the car is running great again, replaced the inovate 3737 universal wideband sensor and lean issue is gone also I am bringing the car in to get rewrapped matte military green within 2 weeks, will post pics soon
Old 07-13-2013, 03:27 PM   #99
Commanderwiggin
Glad to hear it was the O2 Sensor. Pics!
Old 07-13-2013, 05:34 PM   #100
323tom
Ya I'm really glad it was a cheap fix, funny thing is the local partsource in town was trying to charge me 277+tax for the part and I paid 72$ shipped on eBay lol, if the mechs weren't on vacay I would have paid the inflated price but it worked out in the end, I spoke with Larry to see if this is a common issue and he said out of 500 pro efi units he's sold maybe 3 customers wideband sensor crapped out so I shouldn't need to keep a spare wideband sensor on hand, I will post pics in the showroom in about 2 weeks, I'm also going to get my ccws refinished as the anodized gold finish is starting to fade, going to powdercoat this time around and most likely get the lips polished too
