E46 Convertible
Old 05-26-2013, 10:36 AM   #1
SMUUUUUV
My Ride: 330CiC X5 4.4-MBS550
ECS tuning sent me an email so I said what the hell...digital vent gauge..
Had to remove the vent, take out the bottom two vent slats, drill a hole through the bottom of the vent for the wire. Didnt want to run it through the adjustable flap. Didnt want any melting of the wires in the winter while the heat was on so I decided to bypass the flap. They do come pre-installed in the vent but I just bought the item itself. It would have been alot easier pre-installed tho.... p3cars.com is where it originated from but ECSTuning was free shipping...Does battery level, boost level, throttle position, 0-60 times, digital speedo, rpm's etc. Plugs right into the OBD port..
SMUUUUUV is offline   Reply With Quote
Old 05-26-2013, 10:43 AM   #2
johnrando
My Ride: '06 330 CIC ZHP
Oh wow, sweet! I REALLY want one of these but I really can't justify it. Nice get, looks good.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 05-26-2013, 10:46 AM   #3
SMUUUUUV
I fought with it too John but I just said fvck it....Looks pretty cool tho...also clears codes, 0-60 times etc...
Old 05-26-2013, 10:48 AM   #4
johnrando
I'm still fighting, you're a better man than me. It definitely looks good.
Southern California
Old 05-26-2013, 11:04 AM   #5
rguti153
My Ride: 2004 zhp / 2000 323i
Daaaaammmmmmnnnnn nice
rguti153 is offline   Reply With Quote
Old 05-26-2013, 11:11 AM   #6
Japanrot_325i
My Ride: 03 325i
Got the same email lol. Looks really awesome I'm surprised it does all the things you listed.
Japanrot_325i is offline   Reply With Quote
Old 05-26-2013, 11:25 AM   #7
rguti153
Vid ?
Old 05-26-2013, 11:30 AM   #8
SMUUUUUV
Originally Posted by rguti153 View Post
Vid ?
Heres a vid from p3cars.com..
Old 05-26-2013, 12:21 PM   #9
The Thomas J
My Ride: 2002 325Cic
Does it have to go in the vent? $400 is kind of steep.
The Thomas J is offline   Reply With Quote
Old 05-26-2013, 12:27 PM   #10
SMUUUUUV
Its made for the vent but you can put it anywhere. Its not flat on the back of it though so some cutting would be involved.
Old 05-26-2013, 12:31 PM   #11
The Thomas J
Is it touch screen? are there buttons on it? I wonder if it would fit in the blank spot on the instrument cluster where the gear selctor would be for automatics.
Or if not there the ashtray. Cut the cover to make it fit.
Old 05-26-2013, 12:35 PM   #12
SMUUUUUV
Not touchscreen. There are 2 buttons for navigation. It should fit in the ashtray but the vent is a more appropriate place. You will have to get an extension to the OBD port if you put it in the ashtray.
Old 05-26-2013, 04:45 PM   #13
rguti153
I would like on the ashtray
Old 05-27-2013, 06:01 PM   #14
XKR
My Ride: 2001 M3 Convertible
Nice I really like that. Do you recommend installing it yourself or buying it preinstalled?
XKR is offline   Reply With Quote
Old 05-27-2013, 07:41 PM   #15
rguti153
Does it read codes / then u can reset them or only resets what ever comes up n u need to go get a obd2 reader to read them n then delete with this
Old 05-27-2013, 08:37 PM   #16
SMUUUUUV
yes, preinstalled....
It reads, give you the actual code and you can clear them. I havent had to do it because I dont have any codes but thats whats advertised.
Old 05-27-2013, 09:25 PM   #17
rguti153
Sweet like candy crush
Old 05-27-2013, 11:33 PM   #18
johnrando
You tired of that mod yet SMUUUUUV? If so, send it my way.
Southern California
Old 05-28-2013, 04:37 PM   #19
SMUUUUUV
Negative John.... just do it. After you buy it you'll forget about the cost, believe me. You did just about everything else, soooooo.....
shameless plug:
Old 05-28-2013, 06:15 PM   #20
linom3
My Ride: M3
my next mod.
linom3 is offline   Reply With Quote
