Old 05-26-2013, 11:10 AM   #1
InDiGlOM3
My Ride: HPF M3 stg 2.5
mysterious knocking
So ive had this cold start knocking for AWHILE now. I just figured it was the vanos and Id get to it when I get to it.
This weekend I completly rebuilt my vanos and my brother inlaws vanos, both had a noise but different. I rebuilt spline gears, put in new drilled pump disks, rebuilt the vanos and new bolts in the bro's car, mine already had new bolts.
His noise went away, mine is still there. So now im lost and im thinking it might be the oil pump chain tensioner. any other ideas?
is its the oil chain tensioner I wonder if I can reach this thru the bottom with just taking the pan off?
rethinking that....I dont know what the hell that chain would even knock against.
The noise completly goes away after warm.
Old 05-26-2013, 01:08 PM   #2
BaDiNfLuEnCe
My Ride: 04 m3, 06 jeep srt8
I have the same noise..hoping someone could solve this
shes finally here
[/IMG][/URL]
BaDiNfLuEnCe is offline   Reply With Quote
Old 05-26-2013, 01:17 PM   #3
InDiGlOM3
Ive never looked for it thinking it was the vanos, but now time to get to the bottom of it. Going to make video now and listen to other possibilities with stethoscope
Old 05-26-2013, 01:33 PM   #4
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
I had the same problem. I exchanged vanos units and had the same knock afterwords.
For some reason since I had the front taken apart I decided to look at my WP. I took out my water pump and saw that it made noise when I turned it. I exchanged the water pump out for a new one and the knock went away. This was a new water pump about six months old with very little miles on it.
Take your serpentine belt off and see if you still have the noise.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 05-26-2013, 01:37 PM   #5
InDiGlOM3
Ill check water pump, manual as i heard a very very slight knock coming from it with the stethoscope but I think its my oil pump, with the stethoscope on the front of the pan its very loud. No its not a rod bearing because ive had the noise for years.
Old 05-26-2013, 01:41 PM   #6
InDiGlOM3
Did your noise go away once operating temp?
Old 05-26-2013, 01:47 PM   #7
BMWCaptain
Yes, know was there when cold and went away when warm.
BMWCaptainE46.com
Old 05-26-2013, 01:51 PM   #8
BMWCaptain
I thought mine was the vanos because that was the area I thought I was hearing the knock. BMWs can be temperental and give you a false indicator.
BMWCaptainE46.com
Old 05-26-2013, 03:32 PM   #9
BaDiNfLuEnCe
I had the waterpump knock already, just changed my water pump a few months ago. I doubt its that.. The noise is lower and goes away when warmed.. And this noise is pretty new.. Dint remeber hearing this last year
shes finally here
[/IMG][/URL]
Old 05-26-2013, 10:59 PM   #10
BMWCaptain
Changing the WP solved my knock. And my water pump was new too.
BMWCaptainE46.com
Old 05-26-2013, 11:11 PM   #11
InDiGlOM3
link to video/sound clip.
mind the wind from fan there are some good spots you hear the noise very good.
Old 05-26-2013, 11:24 PM   #12
always-there
My Ride: 2002 BMW 330I
mysterious knocking
Interconnect piping leaking/loose? Sounds something exhaust related, too..., something's loose.
Old 05-26-2013, 11:24 PM   #13
always-there
mysterious knocking
Intercooler*
Old 05-27-2013, 12:18 AM   #14
InDiGlOM3
its a knocking coming from inside front of pan "oil pump" so chain....chain tensioner, bearing bolt, maybe chain is stretched or just plain ol bad oil pump. Thing is it goes away once car is operating temp. and oil pressure is always good at all RPM's
Old 05-27-2013, 12:48 AM   #15
BrokenM3
My Ride: E46 Coupe
Could it be the rod bearings? Maybe time for an oil analysis...
BrokenM3 is offline   Reply With Quote
Old 05-27-2013, 05:29 AM   #16
InDiGlOM3
No it cannot be rod bearings, the noise has been present for years.
Sent from my EVO using Bimmer App
Old 05-27-2013, 06:34 AM   #17
bimer21
My Ride: stick 325i
mysterious knocking
Well i got same problem here from a time around 6 months, some expert told me could be a lifter from valves, that when it load up it stop knocking or making its clicking noise, but mine today decide to get stuck my engine doesn't want to spin, so i recommend you to to look at you oil because it could be something down there, i hope you don't pass for what im going now.
My car was perfectly running yesterday at 11:30pm but with that start knocking, and today at 5am it was stuck, like blown, be careful and start checking
bimer21 is offline   Reply With Quote
Old 05-27-2013, 09:13 AM   #18
InDiGlOM3
If your engine is locked up and had a knock then bearing knock is very likely what you had. Once bearing knocking starts you don't have long until your motor will lock up. That's how I know its not a bearing. Its been this way for years. Also its not in a head. If you read entire thread you'll see I've used a stethoscope to zero in on noise location.
Also bearing knock doesn't just go away when warm. Its something to so with oil pump, chain, tensioner.
Old 05-27-2013, 09:18 AM   #19
bimer21
My Ride: stick 325i
mysterious knocking
Ohhh i understand biw, maybe my eurogirl is oil pump or something else, i hope you find the cure for yours
Old 05-28-2013, 09:47 PM   #20
InDiGlOM3
Nobody else? Anyone think the pump itself could make this noise? I'm thinkin chain and tensioner still. And this so called "bearing bolt"
