Old 05-28-2013, 10:49 PM   #21
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Dont think it is your chain tensioner. All it is is a plastic guide pushed agsinst the chain.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 05-29-2013, 07:00 AM   #22
InDiGlOM3
My Ride: HPF M3 stg 2.5
Its got a bearing bolt. If its worn down? Then as car is running oil gets on it and noose goes away... Idk just ideas. Ill just have to get in there one of these weekends
Sent from my EVO using Bimmer App
Old 05-29-2013, 08:40 AM   #23
JamaicanBlueE46M3
My Ride: E46 M3
piston slap? I doubt it but just a thought.
JamaicanBlueE46M3 is offline   Reply With Quote
Old 05-29-2013, 12:06 PM   #24
Ravij
My Ride: 3.5 IR vert M3
I have the same knock. Only present during cold start up. Noticed it 5k miles ago..
Ravij is offline   Reply With Quote
Old 05-29-2013, 12:11 PM   #25
Ravij
Maybe rocker arm or worn down cam?
Old 05-29-2013, 12:49 PM   #26
InDiGlOM3
No its not coming from head. Diffently the block. Its 99 percent positive its something to do with oil pump and its components.
Old 05-29-2013, 01:03 PM   #27
InDiGlOM3
Ive personally had this noise for years and about 30k miles.
Its not bearings as motor and crank would be toast by now. Its not vanos because its all been rebuilt. Not cam or rocker. Those would cause driving problems and wouldn't go away. Its not piston slap because that wouldnt go away after warm. My oil pressure has never been a problem and i don't see a pump noise going away after warm either. Its not water pump ac or steering gear timing vales or anything
In the head. Stethoscope points directly to oil pump/chain area.
Unlike the timing chain the oil pump chain is single, I've seen single timing change stretch before on other cars. And they tighten up when they get hot enough to make any noise they made go away. Oil is not fed to the oil pump chain tension bearing bolt. Its get it from gravity from oil in head falling down. Timing chain area. If my car is all the way hot and I turn it off for thirty minutes and start it, the noise is there again for a few minutes even thou its already operating temp. So whatever oil is on tension bearing bolt has run off I'm thinking. Of course is worse when car is all the way cold.
Old 06-11-2013, 11:05 AM   #28
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
mysterious knocking
Just an idea and long shot... Idle control valve "rocking back and forth??? I think that would effect ur idle rpm so if that's ok now it's probably something else... Maybe belt tensioner ???.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 06-11-2013, 01:08 PM   #29
bimer21
My Ride: stick 325i
mysterious knocking
I take my ride today to my dads shop and in my case it looks like lifter are the one with problem, i order then already to see if i fix it! Also went to dealer and they said lifter on our car is a common failing part and could make a noise at start in different areas and make you think is something else.
If you have misfiring code at start, you should give a look to this too. Good luck
bimer21 is offline   Reply With Quote
Old 06-11-2013, 01:18 PM   #30
InDiGlOM3
I'll check them for the hell of it but my idle is perfect now and i dont misfire etc. Hard to fool me with a stethoscope for where noise is coming from, its what I do everyday when dynoing engines
Old 06-11-2013, 01:36 PM   #31
bimer21
My Ride: stick 325i
mysterious knocking
Yes i did have to take it because mines did it before every time i start it i got that noise with misfiring and after 10sec i goes away, and one day i put seafoam in my engine and i did went away for around 3 weeks, so i though my problem was done but it came back around 2 weeks already and i did take it to see what was it, and we discover this, once at dealer told me could be my oil pump, but it wasn't, its my lifter that are not keeping the oil
Old 06-11-2013, 04:02 PM   #32
Minnoe07
My Ride: 2004 BMW 330Ci
mysterious knocking
From what I have been told, the noise may be the lifters upon cold start and considered normal operating conditions. Especially with the hydraulic lifters on the m5x engines. The lifters take a short time to prime and make noise until fully primed. Once the engine is stopped, they start losing the prime and will make noise upon startup until primed again.
The only solution is to replace lifters and even then it may not fix the noise.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 06-11-2013, 06:53 PM   #33
InDiGlOM3
Re: mysterious knocking
Yeah its completly different for the s54. No hydro lifters
Sent from my EVO using BimmerApp mobile app
Old 06-14-2013, 09:24 AM   #34
InDiGlOM3
Car is up and pan coming off after work, wonder what ill find.
Old 06-14-2013, 10:34 AM   #35
STORMER
My Ride: AA SC 98 M3
mysterious knocking
Keep us posted
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
Old 06-14-2013, 11:00 AM   #36
BDUB328I
My Ride: bmw 328i S54 sedan (
rocker arm is all that I can think of, I've had this problem with other vehicles. when cold it you will get a slight knock. but when they get warmed up they start working properly and knock goes away.
I see you already dismissed that because of the stethoscope, good luck finding the problem and please post the solution when you find it.
BDUB328I is offline   Reply With Quote
Old 06-14-2013, 08:43 PM   #37
InDiGlOM3
Well I found the problem. as I though. chain is really loose. tensioner is crap, so when its cold is when its the most loose and no oil on it really and its hitting one of the hard lines to the pump, pretty good gouge growing on it. Ill take pictures soon and a little video to show how bad it is. What's BS I had this problem before my motor got built. I forgot to mention it and they put it back together like this, something easily noticed. or should of been.
I also found a broken oil sprayer in my pan. I have not looked to see if one is missing. might of been from when my motor first went boom.
Old 06-14-2013, 10:50 PM   #38
being3
Modded ///Member
being3's Avatar
mysterious knocking
So was this the timing chain and guide? If so how many miles on chain?
Old 06-15-2013, 01:39 AM   #39
InDiGlOM3
No just oil pump chain. its a small single chain that's just for the oil pump
Old 06-15-2013, 01:20 PM   #40
Commanderwiggin
My Ride: 900rwhp Turbo M3
Ah this was a problem with the earlier version of built engines...iirc piston design and oil squirters were revised a long time ago. As for the chain...normal wear you figure? I know they put a new chain in with my built engine.
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
