Old 05-26-2013, 12:10 PM   #1
theta
My Ride: '03 325i
Failed emissions - P0171 & P0174
I have a 2003 325i and my emissions failed yesterday with codes P0171 & p0174. I'm trying to figure out why and have a couple of questions.
I know there's some issues with the electrical system as I have warning lights on my dash (rear taillight, airbag, water, Service Engine Soon). I know about the tail light recall and have had the dealership fix the wiring, warning lights all went away, but then came back soon after. I haven't been back again, so there's still something going on there.
If the Service Engine Soon light is on, is that enough to trigger the P0171 & p0174 codes? Or does it have to be something mechanical to trigger that?
What are all the possibilities that could cause those codes? I've been reading about replacing the fuel pump, but not sure what I should diagnose or start with first.
theta is offline   Reply With Quote
Old 05-26-2013, 12:17 PM   #2
2003 325i
My Ride: '03 Orient Blue 325i
ask your daddy who bought you the car.
j/k yes the SES light indicates a problem, take it to a trusted mechanic as you don't seem to have the expertise needed to repair this yourself.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 05-26-2013, 12:20 PM   #3
jdstrickland
My Ride: '94 325iC & '00 323i
SERVICE ENGINE SOON is not the reason the codes are up, it is on BECAUSE the codes are up. The codes triggered the light, not the other way around, which is the question you asked.
You should find out what the codes mean before you start buying stuff.
Old 05-26-2013, 12:24 PM   #4
VishTheFish
My Ride: Ex M54B30 ZHP
A SES light doesn't always mean something mechanical is going wrong. P0171+P0174 are extremely common codes for e46 owners, usually the first place to start would be to check for any vacuum leaks. It could be a multitude of things or just one thing- intake hoses, DISA valve etc.
I believe there is a member who has a thread on it all, the link is in his signature... i believe its member jfoj
VishTheFish is offline   Reply With Quote
Old 05-26-2013, 12:29 PM   #5
theta
My Ride: '03 325i
OK, that's just what I was wondering. I wouldn't even have asked if it weren't for all the other warning lights/electrical problems I've had.
I know what the codes mean and have started to search around. Just wanted to get this one question out of the way.
And you're right - just because I'm not a mechanic means I'm a kid whose dad bought him a car. You're exactly right. I guess that means all these threads from people asking questions are all from overprivileged, ignorant kids.
Old 05-26-2013, 12:29 PM   #6
theta
My Ride: '03 325i
thanks umpersav.
Old 05-26-2013, 12:32 PM   #7
Brinkley
My Ride: 99 328i, 07 z4 3.0
My two cents for dealing with these codes is a smoke test. You'll find the leaks very easily and fix them.
Brinkley is offline   Reply With Quote
Old 05-26-2013, 12:41 PM   #8
dmitrofed
My Ride: Red 2001 330xi
the most common problem for those two codes is definitely a vacuum leak. and typically that happens on the intake boots/hoses, they crack along the ribs in the tube and are hard to see unless you stretch the hoses a bit to see, I'd start there
dmitrofed is offline   Reply With Quote
Old 05-26-2013, 01:01 PM   #9
2003 325i
Or people who think the "Search" button is too difficult to operate
Old 05-26-2013, 01:07 PM   #10
jfoj
My Ride: 330CiC, M5, X5, E93
First link below in my signature covers most everything you need to resolve the P0171/P0174 codes.
You will not be able to pass an Emission test with the CEL on.
You should also purchase a scan tool or software that can read and display real time data if you want to be able to resolve your own issues. You will save the cost of the scan tool or software the first time you use it.
Suggest you read this link - http://forum.e46fanatics.com/showthread.php?t=967204
Old 05-26-2013, 01:24 PM   #11
theta
My Ride: '03 325i
Thanks for the info jfoj, I've had you're pages up for the last hour reading all through it. Lot of info to take in. It's kind of overwhelming and don't know where to start.
Old 05-26-2013, 01:41 PM   #12
jfoj
DISA O-ring, lower intake boot and CCV lower oil return hose are the most common issue.
Old 05-26-2013, 01:41 PM   #13
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Don't need to do a smoke test!
Just pull off your air filter and intake boots. Look for cracks in boots, and CVV hoses. The hose going from the CVV to the dipstick tube is usually cracked. Take a look.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 05-26-2013, 03:29 PM   #14
jdstrickland
I said nothing about overprivileged or ignorant kids. I only said that you should find out what the codes mean before you start buying parts -- you said you were gonna buy a fuel pump, or something.
P0171 and P0174 mean FUEL TRIM BANK1 & BANK2, respectively, are lean. Lean means there is too much air. Well, it could mean there is too little gas, but on your BMW, it normally means too much air. Air enters the engine by passing through the MAF (mass air flow) sensor. The MAF reports that there is X-amount of air (whatever the value of X is), and the computer runs through computations to figure out how much gas is needed for the amount of air to give an air/fuel ratio of 14.7:1.
The O2 sensors analyze the exhaust and tell the computer that the fuel is correct, too much, or not enough. The computer trims the fuel delivery schedule as needed to make the amount of fuel in the exhaust to be the correct amount. You have codes that say, "we told you to add more gas but you cannot add enough."
The main reason to need more gas than the MAF says is needed is because there is a hole in the intake someplace after the MAF, but before the exhaust. The term used to describe this condition is, vacuum leak.
Old 06-07-2013, 02:48 PM   #15
t3kn0
My Ride: 03 325xi
had my cel on...p0171,p0174.....and p1083,p1085....took air intake apart...faulty DISA....plastic clip broke...got one from wrecking yard(400 at dealer...screw them)....fixed problem
t3kn0 is offline   Reply With Quote
