Sponsored by BimmerWorld
Old 05-28-2013, 11:12 AM   #1
cbuniva
My Ride: 2002 330XI
ABS Speed Sensor
I have a 2002 330XI and recently my DSC, brake and ABS warning lights came on and have remained on. I took the car to my local indie repair shop who scanned the car and said my right front ABS sensor was bad. i replaced that this weekend and have since driven the car about 30 miles. The lights are still on so my question is will they eventually turn off on their own or do I need to have the repair shop re-set the codes etc? Thanks for the help.
cbuniva is offline   Reply With Quote
Old 05-28-2013, 11:17 AM   #2
benzedid
My Ride: 2001 BMW E46 318i
You need to clear the codes.
benzedid is offline   Reply With Quote
Old 05-28-2013, 11:27 AM   #3
cbuniva
My Ride: 2002 330XI
Thanks for the help!
Old 05-28-2013, 12:27 PM   #4
trj
My Ride: 325Ci
Most of the times, if all three lights are ON(ABS, DSC and Brake) it is the sensor. You already changed the faulty one.
The lights should go away after a bit of driving(around 50 miles). No need to clear the codes.
However, these lights can be caused by a lot of other things.
Is your car aligned properly? I would get the alignment checked.
Is your car battery good? get the battery tested.
Is your wheel speed sensors in working order? Get them out and check it, clean it and put them back.
Is your steering angle sensor calibrated? Get an alignment and re-calibrate the steering angle sensor(LEW sensor).
Stop going to indy for checking the codes and buy a bmw scanner 1.4. That will pay for itself the first time you use it. Search for a thread on where to buy it and what you can do with it.
Old 05-28-2013, 12:42 PM   #5
cbuniva
My Ride: 2002 330XI
Thanks for the great information TRJ
Old 07-03-2013, 04:15 PM   #6
MR2NoVA
My Ride: 2003 330i
bump
I've got the same issue after cleaning all 4 thoroughly... Any way to know without throwing more money at it?
MR2NoVA is offline   Reply With Quote
Old 07-03-2013, 04:17 PM   #7
benzedid
Did you try the things that trj mentioned?
Old 07-03-2013, 04:23 PM   #8
MR2NoVA
My Ride: 2003 330i
I haven't but wanted some input before I started to. Do the codes need to be cleared? OR should I begin checking things that TRJ mentioned.
@cbuniva, where are you on this issue?
Old 07-08-2013, 09:18 AM   #9
cbuniva
My Ride: 2002 330XI
Turns out my issue was not the ABS speed sensor. One of the connector wires from the car had a hairline crack in it that just developed overtime. Repaired that and immediately the lights all went out and the car has been fine ever since.
Old 07-09-2013, 09:48 PM   #10
ElVic
My Ride: 02 bmw 330i
Re: ABS Speed Sensor
I have a 02 bmw 330i.
the following lights are on all the times.
parking brake, abs & dsc.. what do i need to do? clean all 4 sensors?
i recently repaired the ac by changing the blower resistor .
Sent from my ADR6425LVW using BimmerApp mobile app
ElVic is offline   Reply With Quote
