Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 07-07-2014, 02:23 PM   #21
SK330ci
My Ride: 02 330ci w/ 3 Pedals
So here's an update, my electric use was half or slightly better than half compared to the previous year month after month while using the window a/c's. All I'll say is this experiment was really a success, my home stayed cool enough that everyone was happy. One runs 24/7, the other runs as needed, or about half the time.
I would recommend this to anyone that wants to save big on your electric bill, the fam thought i was crazy at first untill the bills started to roll in, then they had a change of mind.
Mods: Header, CAI, Shark, Koni Sport Struts, Special Lowering Springs, Rob43 9 Way Shocks, 3.38 Diff, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 07-07-2014, 02:31 PM   #22
rdhamill
My Ride: 2005 330i
The mini split units such as this one seem to be becoming very popular.
http://www.lennox.com/products/mini-split-systems/MS8C/
rdhamill is offline   Reply With Quote
Old 07-07-2014, 02:58 PM   #23
SK330ci
Ya, those look real nice, i just went cheap with the Costco units.
Old 07-29-2014, 08:14 PM   #24
Maniac
My Ride: platinum ecoboost R6
Originally Posted by emmm_three View Post
My house is pre-wired for central A/C but was always too cheap to get one..this summer I'm fed up with sweating my balls off so I'm looking to get one installed...what should I expect to pay for a decent one with dual zone climate control? The home is about 1600 sq ft, two stories. Also I'd like to see if they can reroute the wires as the unit would be right under a window outside of the dining room.
Dual climate control for a single unit needs to be done at construction stage or unfinished basement stage for a 2 floor house.
It's not really any more efficient because basically you run individual trucks of supply air per zone you want to control usually each floor and have a bypass in the mech. Room to get rid of the extra air. It's onlygood to maintain a more even temp throughout the house not for efficiency.
Cost will vary greatly depending on how many seer you want (efficiency)
<img src=http://i194.photobucket.com/albums/z76/E46Maniac/signumber2.jpg border=0 alt= />
Originally Posted by 46_coupe View Post
Attractive and stable works for me...I'd rather help wifey program the stove clock than wonder if she purposely left the gas on :eek:
grey green metallic-gone
platinum ecoboost on 35 toyo MTs
Maniac is offline   Reply With Quote
Old 08-03-2014, 08:23 AM   #25
Vinnie Vega
My Ride: 0032870Vette70Velle
I'm doing a reverse of this test with my house, seeing as I bought it with no working HVAC. I'll be installing a new 2 ton unit shortly, but right now I'm using 2 small window units, 1 8000btu, the other 5000btu. I'm covering about 600SQFT with these units and my bill right now is so cheap that I don't even want to get a new whole house unit, there is no way it will be any cheaper than it is right now. I'll probably end up using these units every summer.
"I'm like Swayze mixed with Sajack"
Vinnie Vega is offline   Reply With Quote
Old 08-25-2015, 01:28 AM   #26
SK330ci
2015 Update.
This year I only re-installed 1 6K A/C unit in my central location, my other a/c unit is sitting peacefully in my basement collecting dust. My July through August 29 day total electric bill was $130.60, needless to say i am very happy with this price point. I don't remember when in May i turned on my a/c, but its been running 24/7 ever since with no interruptions. I find that 90 degrees is what i consider the tipping point, below that my house is perfectly comfortable, above it and things get slightly warmer.
Old 09-02-2015, 05:54 AM   #27
Wraisil
My Ride: 2010 Infiniti G37
Originally Posted by SK330ci View Post
2015 Update.
Are you saying 90 degrees is what you set your a/c at??
Wraisil is offline   Reply With Quote
Old 09-03-2015, 12:08 PM   #28
ryanwhite74115
My Ride: 2013 Infiniti G37S
I have a 2100 sq foot 2 story house in the hottest part of NC. 90's to 100's all the time in the summer. My house stays at 73-74 degrees. My bill averages $200 a month. I'll take the $70 hit over a 89 degree house. My wife and kids would be sweating their asses off.
ryanwhite74115 is offline   Reply With Quote
Old 09-13-2015, 10:59 PM   #29
SK330ci
You guys apparently didn't read the whole thread, the 90 degree tipping point is the outside temp. My home is usually between 74 and 78 degrees depending on the time of day.
Old 09-30-2015, 02:23 PM   #30
Wraisil
At 78 degrees outside I'm debating if it's too warm to bother playing golf...
Old 10-03-2015, 09:02 AM   #31
SK330ci
Made me laugh.
Old 10-25-2015, 10:22 PM   #32
SK330ci
A/C unit has been removed and put into storage until next year.
Old 12-08-2016, 03:33 PM   #33
robbiedean
My Ride: Ford Fiesta
Hi there,
What is your electric bill for the month?
Kind thanks
Robbie
Let JD Renovators Ltd help you build the kitchen of your dreams.
robbiedean is offline   Reply With Quote
