Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > UK
UK
Have you seen another BMW while driving around in your area? Find other members from your area in the E46Fanatics Garage HERE
Old 05-30-2013, 05:44 AM   #1
ryanfinn76
My Ride: E46 ///M Touring
Question Hard Brake pedal
Hi there, i have an 03plate 318i sport touring, i recently replaced the front pads, and since then my brake pedal does 1 press then it goes hard i practically have to put 2 feet on pedal to stop, i then got all discs, pads & shoes replaced but still same problem, (i'll add that before i changed the front pads the 1'st time the brakes where fine except worn!!) anybody any ideas on what i could do DIY ? ive had a quick look at all hoses and they look fine,
ryanfinn76 is offline   Reply With Quote
Old 05-30-2013, 06:17 AM   #2
Shaun1970
My Ride: 318i SE 2000
Send a message via MSN to Shaun1970
Hey Ryan, I believe when all changed they will be relatively firm under braking as they are new, and need to be bedded in! Have they been bled correctly too is some thing to check!
Shaun1970 is offline   Reply With Quote
Old 05-30-2013, 06:53 AM   #3
Hektik
My Ride: BMW 318ci
Shuan is right, I know this on any car it's the same, new pads.... you press the pedal and it barely moves but barely brakes well at all either! takes around 2weeks to fully bedd in and trust me they will be ok....
Couple of tips.... Dont ever try slamming on your brakes at this stage, brake gradually and gently to slowly bedd them in, new pads if pressed in solid can aparrently damage or warp your discs.
Just keep gradually braking (even when you dont need to) i.e 30mph road, do 40, slowly and gently press brake down to 30mph and keept doing it, in a couple weeks they'll feel right as rain.
Only other thing it could be is the fluid but its surely them new pads mate!! Hope this has helped
Hektik is offline   Reply With Quote
brake, hard, pedal
