E46 Xi Forum
Old 05-30-2013, 09:09 AM   #1
Kgoncalves
My Ride: BMW 325xi
2003 BMW 325 xi complications.
I bought It Monday an seen it had a check engine light. It threw a code that said cylinder 2 had fuel cut, so I figured it needed a tune up. I started the tune up an all sorts of **** started happening I bought ngk plugs that I gaped to 0.32 an used intermotor coil( don't ever use these coils 3/7 were bad) finally got the car running went to a friends now the engine won't turn over
Kgoncalves is offline   Reply With Quote
Old 05-30-2013, 09:11 AM   #2
jdny516
My Ride: Oxford Green M5
We need way more information to help you. Provide the codes, mileage, any recent maintenance done etc
spark plugs: NGKBKR6EQUP
National Capital Chapter #465420
2000 ///M5 ///M Registry
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Frank Smith Tune
TTFS Alpha N
SuperSprint Headers
SuperSprint X-Pipe
DINAN Front Strut Brace
Storm Motorwerks Products
2003 BMW X5 4.6iS | Black Sapphire Metallic | Black Sport | Titan Trim
2000 323Ci | TiAg | Gray | 5MT | SOLD My Progress Thread
jdny516 is offline   Reply With Quote
Old 05-30-2013, 09:11 AM   #3
orb
orb's Avatar
My Ride: 325Ci
The recommended NGK plugs come pre-gapped.
orb is offline   Reply With Quote
Old 05-30-2013, 09:12 AM   #4
Kgoncalves
My Ride: BMW 325xi
Also I can turn the key all the way to start it but nothing, an after that it will stop half way. Could this be the starter?
Old 05-30-2013, 09:14 AM   #5
Kgoncalves
My Ride: BMW 325xi
Ok. I'm new to bmws but I can try.
I turned the key to start the car the lights an radio were working, but it wouldn't turn over. Then I tried again and it seemed like something was cutting me short from turning the key all the way.
Old 05-30-2013, 09:16 AM   #6
Kgoncalves
My Ride: BMW 325xi
I have NGK G-power plugs in it.
Old 05-30-2013, 09:21 AM   #7
Kgoncalves
My Ride: BMW 325xi
The pre- gap was 0.32 after the tune up I ran the car for about 2 hours an it was fine. 8 hours later the thing isn't starting an its throwing a code, idk what the code is because I can't drive the car it's at my friends place an I don't have an obd2
Old 05-30-2013, 09:25 AM   #8
WDE46
My Ride: '13 128i, '04 330Ci
Get the code.
Did you disconnect any electrics other than the coil connectors when you did this?
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 05-30-2013, 09:37 AM   #9
Kgoncalves
My Ride: BMW 325xi
No. I disconnected the battery a couple times to reset the computer.
Old 05-30-2013, 09:43 AM   #10
choxor
My Ride: JDM
Is your battery dead.
Old 05-30-2013, 09:52 AM   #11
Kgoncalves
My Ride: BMW 325xi
I don't think it's the battery, the lights an radio is working.
Old 05-30-2013, 09:53 AM   #12
jfoj
My Ride: 330CiC, M5, X5, E93
Make sure your battery is good, you can check the battery Voltage right on the dash via the OBC. See the 4th link below in my signature.
Also make sure to try with the trans in neutral if an automatic or pump the clutch pedal if a manual trans.
The one thing I hate to tell you is if you have a 2003/2004 these cars seem to have a lot of starter issues that just all the sudden quit starting without warning. On the xi, you might as well pull the intake and replace the starter from the top as there is very little room under the car for a starter replacement if you need to replace it.
Hopefully it is not the starter, usually what happens is the batteries are usually old and when you decide to do a lot of work on the car, either the door is left open and/or the radio is played while working on the car and the battery is discharged to the point the car will not crank.
Verify battery first, try neutral or pumping the clutch, search about the ignition switches and hope your starter is not the problem.
Old 05-30-2013, 10:01 AM   #13
choxor
My Ride: JDM
Does not mean it has enough juice to actually start the car.
Old 05-30-2013, 10:06 AM   #14
jfoj
Kgoncalves you will not be able to see my signature using a mobile app, you will need to use a computer.
But in case you really have good eyes - http://forum.e46fanatics.com/showthread.php?t=239619
Old 05-30-2013, 10:53 AM   #15
Kgoncalves
My Ride: BMW 325xi
I got the car started now,
Old 05-30-2013, 11:00 AM   #16
WDE46
What did you do?
Old 05-30-2013, 02:20 PM   #17
SK330ci
My Ride: 02 330ci w/ 3 Pedals
OP,
How do you expect to put a turbo in it if doesn't run right?
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 05-30-2013, 02:36 PM   #18
boostedisbetter
boostedisbetter's Avatar
My Ride: NiNe tHoUsAnD!!!
** Political sig removed **
boostedisbetter is offline   Reply With Quote
Old 05-30-2013, 03:19 PM   #19
choxor
My Ride: JDM
So what was the problem.
Old 05-30-2013, 09:42 PM   #20
Kgoncalves
My Ride: BMW 325xi
I jiggled the steering wheel, an pushed the brake to the floor, also tried changing it from park to drive to reverse an back into park. Idk what's wrong with it. But doing all of that seems to work..... Kinda lol.
