Old 05-30-2013, 04:30 PM   #1
StatureSteez
My Ride: has 3 peds
Quick Angel Eye Question
So I installed my LED Khoalty angel eyes about 8 months ago and every thing has been working perfect. Just had a quick question. If I wanted to unplug them under the hood or unplug one on each side would that cause any sort of an electrical problem if the wires were still spliced into the running wire and the interior lights wire?
This is the spot I wanted to unplug...
StatureSteez is offline   Reply With Quote
Old 06-01-2013, 11:01 AM   #2
sillieidiot
My Ride: '06 AW 330ci
if you want to disable all of them. just pull the fuse. it'll still come on with your interior lights though, unless your wiring has a fuse for that too. or you can pull the relay which would disable everything.
if you want to unplug 1 ring from each side, then you have to do it with the individual ring wires.
if you unplug it from the area you are showing, the whole side (both rings on that side) will turn off. and when you unplug it in that picture, you're going to need to tape it up, since the red wire will still have power.
Old 06-22-2013, 03:38 PM   #3
StatureSteez
My Ride: has 3 peds
so the only way to turn one angel eye off on each side is to cut the wire?
Old 06-23-2013, 02:26 AM   #4
sillieidiot
no, like i said. follow the wires on the ring you want to turn off. there should be a plug at the end. just unplug that. unless someone cut them off and made it a permanent thing
Old 06-27-2013, 10:33 AM   #5
StatureSteez
My Ride: has 3 peds
ah I got it thank you
