Old 05-30-2013, 05:22 PM   #1
Dave@Bimmer_Speed
My Ride: 2003 BMW 325i
Question A/C Question for the AC Gurus
2003 BMW 325i
My AC only blew warm air so I used a vacuum pump to drain the system and then I checked if the system held pressure (No leaks). I used one of those tools that connect to both the Low and High pressure ports (No that walmart crap) to put in the freon. I've successfully done this on other cars before by the way. But after putting freon into the system ONLY Cool Air blows and not Cold air. The AC Compressor works and there aren't any leaks.
Does anyone have an idea of what could be going on? One of the tubes clogged maybe?
Dave@Bimmer_Speed is offline   Reply With Quote
Old 05-30-2013, 06:39 PM   #2
vandyboy
My Ride: 2001 325i
Is the center vent moved to blue instead of red? Did you overfill or underfill?
I don't know your process for adding refrigerant, but this is how I was taught. Hook your high and low side hoses and r134 back up and get someone to sit in the car. Turn the car on and put the A/C on max with the fan on high. Have the person keep RPMs at 2000 while you measure how much refrigerant is in the system. Either let some out or add some more until the person in the car tells you when the A/C gets cold
vandyboy is offline   Reply With Quote
Old 05-30-2013, 07:01 PM   #3
David McMahon
My Ride: '99 E38 740iL
In the A/C DIY thread it mentions changing the drier when the system is exposed to the atmosphere, so I wonder if you need a new one of those (i.e did you system lose vacuum and allow air to get in)
David McMahon is offline   Reply With Quote
Old 05-30-2013, 07:14 PM   #4
Foxtrot_Uniform
My Ride: 325Xi
Unless you used the proper gauges... You'll never really know how much R34a is in your system. If it was totally flat... You may have lost the oil charge... As was mentioned... The Dryer could be shot too.
I'd take it to a place that can recover what is in there... Draw a vacuum and then install all the right stuff in the correct amounts. It doesn't cost much if you find the right place.... As long as they don't have to replace the dryer for you or something like that.
Foxtrot_Uniform is offline   Reply With Quote
Old 05-30-2013, 07:40 PM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
A professional recharging might cost $75. Getting your compressor fixed because you over or underfilled it would be $$$...over a thousand at most shops.
Take it to a professional. You'll note that r134a capacity is under the hood...given in lbs. 1.86 +/- .05 lbs. on mine. You can't get that by measuring only pressure. A shop has a machine that will fill by weight and you'll know it's right. Not worth it. afaik, if you make a sizeable mistake with 134a levels you can damage a compressor.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 05-31-2013, 09:08 AM   #6
Dave@Bimmer_Speed
What do you mean by a lost oil charge?
Old 05-31-2013, 09:30 AM   #7
Yewzer B Lewzer
My Ride: 2003 325i
The compressor has oil in it, and about 10% of that oil flows in the refrigerant through the system. Leaking systems will eventually run the compressor low on oil.
^^Blue Ridge Parkway^^ '03 325i. '74 Jeep CJ-5. '93 Sailfish 170XL. '12 Westside SS Longboard. One of these four are sure to be running at any given point in time.
Yewzer B Lewzer is offline   Reply With Quote
Old 06-07-2013, 04:30 PM   #8
TEAMAFLCON
My Ride: 2003 325i
Originally Posted by Dave@Bimmer_Speed View Post
2003 BMW 325i
This is EXACTLY what is happening to mine.
2003 325I with 94K miles.
Compressor is working, but a guy at Autozone told me that it had too much refrigerant. He told me this when he tried to recharge it using those $40 deals at Autozone. He was trying to fill it up but it wouldn't let him. The gauge showed that it was full (way in the red using that little gauge).
TEAMAFLCON is offline   Reply With Quote
