Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 78 votes, 5.00 average.
Old 06-28-2013, 09:27 AM   #241
Bimmersoul
My Ride: 330i
I just bought my 5150 today...
Does EONON actually issues BIOS or software updates?
I read freezing software errors but only while using the nav...
any errors/freezing while streaming with Bluetooth or while using the radio?
Is anyone using the nav/maps issued by EONON?
If so, any software errors?
I did not read anything on the iPhone screen emulator. Is anyone using it?
I would think that this will solve software errors... using everything on the iPhone and just emulate the screen... anyone?
Bimmersoul is offline   Reply With Quote
Old 06-28-2013, 10:07 AM   #242
The Thomas J
My Ride: 2002 325Cic
Re: Just ordered a Eonon D5150! (New version of Eonon D5113/Enco B146)
Negative on updates.
Sent from my SGH-T889 using BimmerApp mobile app
The Thomas J is offline   Reply With Quote
Old 06-28-2013, 10:24 AM   #243
esberelias
My Ride: '03 325i
We should talk to Eonon about that one.... maybe with the newer decks they will have some sort of updates...
Check out my ride
esberelias is offline   Reply With Quote
Old 06-28-2013, 12:27 PM   #244
knightrider5000
My Ride: 1999 BMW 323i 4 door
Send a message via Yahoo to knightrider5000
No freeze ups on there map, they say its the best for there say deleate everything not needed Im still bugging my stuff out.
knightrider5000 is offline   Reply With Quote
Old 06-28-2013, 05:22 PM   #245
valenti
My Ride: Rated M
anyone use an android device and have a normal phonebook display ? mines still in all random orders , went from stock rom to aosp, no luck.
valenti is offline   Reply With Quote
Old 06-28-2013, 05:54 PM   #246
tnhl1989
My Ride: 02 330xi(RIP),03 ZHP
Updated the post - Canbus fix and illumination fix. Now everything seems to be working perfectly. I will have full diy, photos, and videos once I get the chance to.
tnhl1989 is offline   Reply With Quote
Old 06-28-2013, 09:43 PM   #247
limpiabota809
My Ride: 330 XI
Do you think this will resolve the issue for the older one as well?
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 06-28-2013, 09:51 PM   #248
tnhl1989
Does your headunit does the random start up too? I would assume that it would also fix the older ones as well as long as the symptoms are similar.
Old 06-28-2013, 10:05 PM   #249
limpiabota809
My Ride: 330 XI
I don't have either head unit but there are other members that have the older headunit with the canbus issue, I was just inquiring for them
Old 06-28-2013, 11:44 PM   #250
bcw448
My Ride: 2000 BMW 323ci coupe
Well done tnhl1989!! Will this mod disable/delay the backup camera? Because I think that the backup camera signal is controlled by the Canbus.
bcw448 is offline   Reply With Quote
Old 06-29-2013, 03:02 AM   #251
tnhl1989
I don't have a backup camera so I haven't tried. I'm still considering on which one to get at the moment.
Old 06-29-2013, 03:42 AM   #252
esberelias
My Ride: '03 325i
Awesome! Glad someone get a DIY for that relay now!
Check out my ride
Old 06-29-2013, 03:44 AM   #253
Mightymorff
My Ride: E46 316
It says I don't have permission to view the thread?
could you copy and post it here?
Mightymorff is offline   Reply With Quote
Old 06-29-2013, 03:56 AM   #254
Zakk92
My Ride: 2001 BMW 325i E46
Shout to anyone out there with a pre '02 BMW who've bought this (with reversing camera) want to make an instruction video? connecting the harness and dealing with the trim is fine, but getting the right wiring for the camera/dvd player and sorting out the canbus is proving tricky
Zakk92 is offline   Reply With Quote
Old 06-29-2013, 04:03 AM   #255
asdetail
My Ride: 2002 325ci coupe
yes it will disable the backup cam on the d5150 until the canbus adaptor is powered up,the backup signal on the d5150 is received through the canbus,however this will not affect the cam signal on the older d5113 as it uses a direct 12v feed from reverse circuit to the h/u.
asdetail is offline   Reply With Quote
Old 06-29-2013, 01:02 PM   #256
bcw448
Thanks.
I think I can live with that 20sec. Canbus startup delay, just purchased one relay from flea bay and should received it by next week, will install and see how it workout.
Old 06-29-2013, 07:58 PM   #257
tnhl1989
Well don't most people normally let their cars warm up for like 30s?
Also 20s isn't that long anyways. That is about as long as a full start-up of the head unit.
I feel that it's probably possible to reroute the wires to run the rear view camera without the canbus.
Just a few thoughts.
Old 06-29-2013, 09:20 PM   #258
knightrider5000
video I made of my system hooked up
Old 06-30-2013, 09:27 AM   #259
Mightymorff
My Ride: E46 316
The adapter you have there is for later models with what I think is a FAKRA plug. Now, I have had my unit out again to attach the dimmer wire and while I was there I played with the aerial some more.
With the aerial adapter only connected I get ok/poor reception, when I attach it to the BMW aerial lead the reception doesn't seem to improve.
How does the BMW aerial amplifier get power?
Does it need a separate power supply?
I don't think mine is being turned on, can it be checked?
Old 06-30-2013, 01:20 PM   #260
knightrider5000
I think 99-2002 have old amps which gets power from the radios, the newer ones must get power from the other plugs connected, so you don't need to run power from the radio with the newer amp which you may need to get, look on ebay for one, must have same frequency as yours, its in this thread.
Rate This Thread
