Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 78 votes, 5.00 average.
Old 08-22-2013, 09:39 AM   #561
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
So far all is good. I ditched the Kudos maps for IGo Primo 2.4 which is much better.
Build Thread - S54 Vanos Thread
TTFS Engine/SMG Tune - SGT Headers/Sect 1/SCZA - Evolve Eventuri - Sprint Booster V2
UltraGauge - Orion V4's - CF Lip/Console/Diffuser - VIS XTS CF Hood - CSL Trunk - Valentine One - Turner 15F/12R Spacers
WOLFN8TR is offline   Reply With Quote
Old 08-22-2013, 12:04 PM   #562
grapaslingo
My Ride: 2000 328Ci
About to pull the trigger...
Hi guys,
I'm new to the forum, having just purchased a 2000 328Ci. I've been following the thread and picking up on all the vernacular as best I can. I've reread every post a couple of times...I hope those of you with more experience will forgive my ignorance--it's difficult to filter through all of it to be certain you're getting the required equipment.
I've included a picture of my setup. I have the OEM Navigation unit with HK. There was a post awhile back that said that you *can't* install with this setup, but then a later post which said you can, as long as you have a 17pin or 40pin adapter. I think I also need an antenna adapter.
If I'm not mistaken, the only things I need to purchase to install are these:
  1. BMW Wired Cable 17 Pin 5 Meters Extension
  2. An antenna adapter cable, like this one: http://www.amazon.com/gp/product/B00...X31MTAV6E4VEQX
+ a Backup camera if I want one.
Can someone who had the OEM Navigation confirm this is correct?
Thanks!_nr_
grapaslingo is offline   Reply With Quote
Old 08-22-2013, 11:40 PM   #563
Rezist09
My Ride: 325i sedan
Bump where to order?
Rezist09 is offline   Reply With Quote
Old 08-23-2013, 08:39 AM   #564
limpiabota809
My Ride: 330 XI
Can anyone post a link from where they purchased the 90 degree antenna adapter and the correct iPod adapter to use, I find a lot but don't know which one would be the one
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 08-23-2013, 02:19 PM   #565
MathewM3
My Ride: BMW M3 E46
So, does everybody that orders the 5150 now get the new V2 canbus with updated wiring harness?
MathewM3 is offline   Reply With Quote
Old 08-23-2013, 02:32 PM   #566
limpiabota809
My Ride: 330 XI
^ if you order from them directly yes
Old 08-23-2013, 04:58 PM   #567
E46BlackSedan
My Ride: N/A
I can confirm that you are getting the V2 canbus if you order from 88hk on eBay. Ordered a second 5150 from them and it has the V2 canbus. Seems like every problem is solved.
As for the rearview camera, they now added an orange wire to the wiring harness that goes into the back of the unit. This needs to be connected to the reverse light 12v feed.
I will try this tomorrow..
E46BlackSedan is offline   Reply With Quote
Old 08-23-2013, 05:08 PM   #568
E46BlackSedan
My Ride: N/A
Originally Posted by grapaslingo View Post
Hi guys,
Thanks!_nr_
The antenna adapter is supplied so you don't have to order one. If that cable you are talking about converts the OEM nav plug into the BMW 17 pin plug then it should work.
Old 08-23-2013, 05:08 PM   #569
brodaiga
My Ride: 330ci
I ordered and got a v1 canbus, no resolution
brodaiga is offline   Reply With Quote
Old 08-23-2013, 05:12 PM   #570
E46BlackSedan
My Ride: N/A
When did you order one?
Old 08-23-2013, 05:21 PM   #571
E46BlackSedan
My Ride: N/A
Originally Posted by Scooby24 View Post
Yeah, he's right, sorry....I didn't read closely enough. The screen will dim, the buttons don't....but it's really not noticeable.
The buttons do dim with the new V2 canbus Finally!
Old 08-23-2013, 07:23 PM   #572
Rezist09
My Ride: 325i sedan
What. eBay seller to purchase from? Go direct?how do I know what can bus it's coming with?
Old 08-23-2013, 07:37 PM   #573
limpiabota809
My Ride: 330 XI
Buy direct rezist and you should receive v2 canbus
Old 08-24-2013, 12:11 PM   #574
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
The buttons and the screen? Sweet ...
Old 08-24-2013, 12:41 PM   #575
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
You can get them on Amazon or eBay. I found eBay was cheaper.
8 Pin Mini Din iPod cable with 90 degree plugs on both ends.
http://www.amazon.com/Hosa-CCD-103-1...=I7X6OBUQXX95H
You will need a 8 Pin Mini Din Coupler also.
http://www.ebay.com/itm/370868321736...84.m1438.l2649
90 degree antenna adapter.
http://www.amazon.com/Metra-44-EC6R-...=IECTHSWWL8KCG
http://cgi.ebay.com/ws/eBayISAPI.dll...m=290963890140
More flexible antenna cable.
http://www.ebay.com/itm/300928242681...84.m1438.l2649
http://www.ebay.com/itm/251294150712...84.m1438.l2649
Antenna cable that came with the Eonon 5150
http://www.ebay.com/itm/300889101259...84.m1438.l2649
GPS Antenna that came with the Eonon 5150
http://www.ebay.com/itm/150841348899...84.m1438.l2649
So far the only 90 degree iPod cable I've found only turns to the left (drivers side). It is real close to the antenna cable. You can trim some of the ribs off the cable to make more room for the antenna plug, which should work good with the more flexible straight antenna cable.
I'm still waiting for my Can Bus V2 to get here before I take my 5150 out to try these cables.
Old 08-24-2013, 12:44 PM   #576
limpiabota809
My Ride: 330 XI
The iPod cable is a 8 Pin Mini Din with 90 degree plugs on both ends. You will need a 8 Pin Mini Din Coupler also.
So far the only 90 degree cable I've found only turns to the left (drivers side). It is real close to the antenna cable. I'm still waiting for my Can Bus V2 to get here before I take my 5150 out to try these cables.
Thnx brother
Old 08-24-2013, 12:52 PM   #577
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Thnx brother
Sure... I will post links above for ya in a minute.
Old 08-24-2013, 01:19 PM   #578
limpiabota809
My Ride: 330 XI
Thnx again
Old 08-24-2013, 04:43 PM   #579
lrlima
My Ride: 2001 M3 Convertible
Can anyone recommend a good place to download this? Curious if one link is better than others, looks like a lot of spam when I search.
Also, I have the v2 can bus when ordering on eBay from hk88. So far everything works, except the damn radio reception lol. Dimming, steering wheel buttons work well. Fast shipping too
lrlima is offline   Reply With Quote
Old 08-24-2013, 04:48 PM   #580
brodaiga
My Ride: 330ci
hk88 sent me the old canbus, I am waiting for update
Rate This Thread
