Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 78 votes, 5.00 average.
Old 09-13-2013, 09:27 PM   #661
Rezist09
My Ride: 325i sedan
Bump what other navi can I get for the eonon? Looking at tomtom or garmin maps?????
Rezist09 is offline   Reply With Quote
Old 09-13-2013, 10:42 PM   #662
gy2202
My Ride: 2001 E46 330I
Did anyone use the subwoofer output? Where is the remote wire (trigger wire) for an external amplifier?
gy2202 is offline   Reply With Quote
Old 09-15-2013, 03:51 AM   #663
Paul2708
My Ride: E46 318ci M sport
Hi , I have installed Primo 2.4, much better than Kudos software that came Pre installed n the sd card. I'm having trouble increasing the volume of the spoken instructions in Igo. The sliders in the settings section are all at max but the slider bars in the top left of the main menu don't go above 1 bar. The volume is not so bad at slow speed but over 30mph you can hardly hear a thing. Has anyone had this same issue ?
Paul2708 is offline   Reply With Quote
Old 09-15-2013, 06:34 AM   #664
carbon2t2
My Ride: 2006 M3 Vert
DIY for cars with OEM NAV
Hello everybody and thanks in advance for any help provided.
I have a few questions before I pull the trigger on one of these units.
I have a 2006 M3 vert with OEM NAV and HK.
1. Has anyone made a DIY for vehicles with OEM nav?
2. Does anyone know of a particular ebay vendor that is providing the CANBUS V2 from the beginning without having to request a replacement.
3. Does anyone know a good source for the 5 meter extension cord needed for cars with OEM NAV. preferable one that doesnt need to be spliced to fit the EONON harness.
I'm deployed right now and would love to order this and be ready to install it on my R&R when I get home.
Thanks again.
carbon2t2 is offline   Reply With Quote
Old 09-15-2013, 12:42 PM   #665
WOLFN8TR
My Ride: 05 SMG M3
Go into "System Settings" on the 5150 and set the Mix proportion to 8 and Enable GPS mix. The Mix proportion basically is the Volume of the GPS voice directions compared to the music level.
Thanks again.
All of the newer units are shipping with the new Can Bus V2. FYI the eBay units only come with a 1 year warranty and the units directly from Eonon or the Group Buy come with a 2 year warranty. So I would buy one thru the Group Buy.
Group Buy Thread
http://forum.e46fanatics.com/showthread.php?t=1001983
Eonon's Group Buy Link
http://www.eonon.com/Car-GPS/Specifi...MW/D5150T.html
Build Thread <:> S54 Vanos Thread
-TTFS Engine/SMG Tune- SGT Headers/Sect 1/SCZA- Evolve Eventuri- Sprint Booster V2-
-UltraGauge- Orion V4's- CF Lip/Console/Diffuser- VIS XTS CF Hood- LED Fogs- Valentine One- Turner 15F/12R Spacers-
WOLFN8TR is offline   Reply With Quote
Old 09-15-2013, 01:15 PM   #666
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
My Ride: 328i, M3, 525iT
Thanks again.
They mentioned here that you need an "extended wire harness" if you have OEM nav:
http://forum.e46fanatics.com/showpos...2&postcount=70
ddaniel1 is offline   Reply With Quote
Old 09-15-2013, 01:34 PM   #667
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
Here it is, yikes, 55 dollars:
http://www.ebay.com/itm/BMW-Wired-Ca...81099081826%26
Old 09-15-2013, 01:49 PM   #668
carbon2t2
I think that's what Dynavin is charging for it as well. Also thats the 17 pin cable for 2001 or older cars. Mine is a 2006 and requires the 40 pin cable.
I think I may just wait untill they offer a unit with the correct cable included. I dont really want to do any splicing.
Old 09-15-2013, 05:46 PM   #669
gy2202
I have the 2001 330i with OEM NAV and CD stacker and you definitely need the following:
1. 5M extension cable ( 17pin or 40pin depending on your car )..what i did on mine is extend the length of the cable rather than buy a new one for $55.
http://www.ebay.com.au/itm/171041552...ht_2731wt_1016
2. Metra cable
http://www.ebay.com.au/itm/290906068...84.m1439.l2649
3. 5M Antenna cable
http://www.ebay.com.au/itm/400276364...84.m1439.l2649
4. 5M RCA cable ( if you decide to connect a subwoofer )
5. 5M extra wire as remote/trigger wire for the amplifier to run the subwoofer ( i connected it to the blue antenna wire) - and it works.
Hope this helps
Old 09-16-2013, 03:53 AM   #670
carbon2t2
2. Metra cable
3. 5M Antenna cable
5. 5M extra wire ( trigger/remote wire for the Amplifier ) - I'm tapping the blue antenna wire - hopefully this will work.
Hope this helps
Thanks.
Old 09-16-2013, 05:57 PM   #671
ron53
My Ride: 2001 E46
No power
Pulled the trigger and ordered D5150.
Still waiting on correct radio mount to relocate climate control, but while waiting went for a trial install. Had to purchase antenna adapter (2001 old HU with 2 antenna connectors) 5150 only comes with newer adapter.
Plugged it all up and no power !
Tried it twice and tested dash connector with old radio, no problem.
Harness looks correct and connected securely.
Still waiting on support answer.
Any suggestions ?
Could not seem to find a video install, seems so simple did not think I would need one.
ron53 is offline   Reply With Quote
Old 09-16-2013, 06:42 PM   #672
ron53
My Ride: 2001 E46
No power D5150
Decent reviews D5150 thought I would give it a try.
Did a dry install while waiting for climate control relocation radio mount. No power!
Checked harness at radio connection according to diagram correct 12 volts, fuse good.
Anything I missed or just a bad unit ?
Thanks,
Murphy;s cousin
Old 09-16-2013, 06:52 PM   #673
THECLEANERBEAMER
My Ride: 2002 325i
Once you install the oem harness to the harness adapter that comes with the unit and then into the back of the unit you should have power
Instagram:thecleanerbeamer
THECLEANERBEAMER is offline   Reply With Quote
Old 09-17-2013, 12:12 AM   #674
Rezist09
My Ride: 325i sedan
Is any body else having trouble with warrenty site keeps asking me for eBay item number and eBay name yet I did not order from there??? I alrdy email them keeps giving the same answer
Old 09-17-2013, 02:33 PM   #675
DrZoom
My Ride: 2004 330i ZHP
PM Carlos from Eonon who is a sponsor on this site and he should be able to help you out.
DrZoom is offline   Reply With Quote
Old 09-17-2013, 08:05 PM   #676
MathewM3
My Ride: BMW M3 E46
So, has any body used an aftermarket amplifier?
If so, which wire did you use for pwr amplifier control?
It shows that pin nr 3 from the head unit is the pwr amplifier control but it goes to the can bus?
MathewM3 is offline   Reply With Quote
Old 09-17-2013, 08:53 PM   #677
MathewM3
My Ride: BMW M3 E46
I think I have figured it out but feel free to correct me if I am wrong.
http://forum.e46fanatics.com/showthread.php?t=245914
Pin 10 on the gray connector to the OEM amp should work. I will try it out tomorrow.
Old 09-18-2013, 06:41 AM   #678
ron53
My Ride: 2001 E46
NOTE anyone interested in purchasing new unit please read the following
Researched this unit and purchased from eBay vendor ukcarhifishop before finding this thread. Unit arrived from Hong Kong and was DOA. Traced our from my harness, their adapter, to the unit, checked and swapped fuse no power.
Contacted vendor who agreed to evaluate the unit once I shipped it back to them. Shipping costs for original box USPS On line $76.71. Head Unit alone $59.95. currently I am waiting for the usual 24-hour turnaround e-mail response to attempt to get them to send a prepaid label.
Also note the unit does not come with an antenna adapter for older radios, granted you can pick one up for approximately 5 dollars
Carlos, if we purchase from your group buy how will our warranty be handled ?
Old 09-18-2013, 05:11 PM   #679
MathewM3
My Ride: BMW M3 E46
Aftermarket Amplifier
Pin number 10 on the grey OEM amplifier connector works great as "power amplifier control" for after market amplifier.
Old 09-20-2013, 10:45 PM   #680
becks!
My Ride: e46 330ci
hi guys,
i have a 2000 e46 and my connector in the boot looks like this:
other people are buying this, but can someone explain how that plugs into what I have? (I'm assuming they have the same connection to replace as me)
http://www.ebay.com.au/itm/171041552622_nr_
becks! is offline   Reply With Quote
Rate This Thread
