Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 78 votes, 5.00 average.
Old 11-05-2013, 06:26 PM   #961
pyro225
My Ride: 328ci
thanks mate whats sol? surely they are rgb leds its just software?
pyro225 is offline   Reply With Quote
Old 11-05-2013, 08:08 PM   #962
wicked_ink
My Ride: 2002 325i
SOL = sh1t outta luck
wicked_ink is offline   Reply With Quote
Old 11-05-2013, 09:40 PM   #963
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
LOL...
Build Thread - S54 Vanos Thread
TTFS Engine/SMG Tune - SGT Headers/Sect 1/SCZA - Evolve Eventuri - Sprint Booster V2
UltraGauge - Orion V4's - CF Lip/Console/Diffuser - VIS XTS CF Hood - CSL Trunk - Valentine One - Turner 15F/12R Spacers
WOLFN8TR is offline   Reply With Quote
Old 11-07-2013, 01:43 AM   #964
esberelias
My Ride: '03 325i
I'm very surprised that they cant give us ORANGE with software/firmware update.... The LED's are RGB in there already....
Check out my ride
esberelias is offline   Reply With Quote
Old 11-07-2013, 07:00 AM   #965
pyro225
My Ride: 328ci
Me too... I also have interference occasionally when listening to music that goes up and down with the volume.. I notice it more on ipod I think because radio always has interference . Any ideas how to fix as said its intermittent?
Old 11-07-2013, 10:20 AM   #966
Thekingarthur
My Ride: 2002 M3 SMG Vert
I agree. Any color should be possible.
Thekingarthur is offline   Reply With Quote
Old 11-08-2013, 05:16 AM   #967
asdetail
My Ride: 2002 325ci coupe
+1 on that
asdetail is offline   Reply With Quote
Old 11-09-2013, 02:26 AM   #968
DavesE46
My Ride: E46 328i
Just got my d5150 in the mail it's a beast only hooked it up to play with a minute but so far so good the orange is a bit off not enough to take from it made a call from Bluetooth my girl said I was clear so that checks out on start up when I put in a cd for some reason it was full blast and I wasn't to happy about that speakers for a bmw aren't cheap but never less I plan to install tomorrow can give a better review then I'm just not to sure about the steering wheel hook up any input helps by the way it seems they fixed the power ant wire got full sound
DavesE46 is offline   Reply With Quote
Old 11-09-2013, 02:29 AM   #969
Linx
My Ride: '02 BMW 325iT
Can you tell me if you had a choice of both orange and red with th. LED selection?
Linx is offline   Reply With Quote
Old 11-09-2013, 12:39 PM   #970
DavesE46
My Ride: E46 328i
To answer your question yes there is a red and orange option as to which nether are 100% match but no reason to turn away and it came with 90 degree iPod hook up will do full review later although it does have a hard cut off
Old 11-09-2013, 01:29 PM   #971
chaos11624
My Ride: e46 M3
Something to try for us orange guys would be to hook it up dim the panel and see what the voltage is on one of the leds then add a resistor to drop it to that voltage when car light panel isn't dimmed cause the dimmed orange looks spot on , may be more trouble than it's worth or may be something they can tone down through sotware, if my wasn't installed I'd try it maybe when I pull it back out to do the external mic , cause even drilled out my mic is not useable , just lots of what? What? Hello? When I call people
chaos11624 is offline   Reply With Quote
Old 11-09-2013, 07:08 PM   #972
knightrider5000
My Ride: 1999 BMW 323i 4 door
Send a message via Yahoo to knightrider5000
Pyro, I have a 99 bmw 323i and the cam don't work on mine either in reverse. I had he v1 canbus. Eonon is sending me the new power cable to go with the new v2 canbus they had exchanged me for the v1, I will let you now if it fixes the camera issue. My cam does work also in the aux mode only.
knightrider5000 is offline   Reply With Quote
Old 11-09-2013, 10:09 PM   #973
Thekingarthur
Just posted this in the other Eonon thread. Here it is again:
The orange color being correct really depends on what you compare it to, because technically there are two hues of orange used in the BMW dash. There is a yellow-orange used in the speedometer and a red-orange used in the clock/odometer, A/C, and stock radio.
The Eonon orange looks to match the yellow-orange hue of the speedometer but is slightly brighter. (Same hue, just a bit brighter). It doesn't quite match the red-orange used in the A/C unfortunately, which is what it sits closer to. Here's an image which should better demonstrate what I'm trying to describe. It looks slightly different to your eyes then to my camera, but this should get the point across.
Old 11-09-2013, 10:11 PM   #974
Thekingarthur
I agree. I think the majority of the perceived color mismatch is due to the fact that the Eonon unit LEDs are brighter than the BMW dash LEDs. Dim them down a bit and they look a lot closer to OEM.
Old 11-10-2013, 04:58 PM   #975
pyro225
My Ride: 328ci
Silly question... but where are the Eonon reps now all these questions are here?
Old 11-10-2013, 05:34 PM   #976
pyro225
My Ride: 328ci
also what video formats work on the sd? reverse cam still not working
Old 11-10-2013, 07:31 PM   #977
wicked_ink
My Ride: 2002 325i
I'd like to know this as well. Tried several .avi files loaded on SD and kept getting Codec not supported errors. Sound would play but no picture.
Old 11-11-2013, 03:47 AM   #978
daki_bmw
My Ride: 330Ci
People, be VERY carefull with this company! You have my story in my sig. http://forum.e46fanatics.com/showthread.php?t=1013257
They are busy asking people's credit card numbers and bank statements.
daki_bmw is offline   Reply With Quote
Old 11-11-2013, 04:21 AM   #979
wicked_ink
My Ride: 2002 325i
Sorry to hear about your situation daki but most of us have had good experience with Eonon. Granted, most probably used PayPal as did I and had no issues. Got my unit 3 days after I placed my order.
Old 11-11-2013, 05:04 PM   #980
pyro225
My Ride: 328ci
Ok, anyone able to help with this... when I turn my lights on the Eonon unit doesn't go into night mode even though in the settings it says it should?
also still got my reverse camera fault not working.
I have another problem - ever since I put this unit in my ABS/ASC/Fuel Gauge haven't been acting correctly - I wouldn't have thought anything of it but I am getting a Signal CAN ASC Fault. - I believe the CAN emulator has caused problems so could this be related?
Rate This Thread
