Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 78 votes, 5.00 average.
Old 02-19-2014, 12:44 PM   #1181
blade0925
My Ride: BMW 325i
After I press the reset button on my D5150U the screen went black and now it wont turn on at all. What did you guys tell me to do!! lol. Any suggestions?
blade0925 is offline   Reply With Quote
Old 02-19-2014, 12:46 PM   #1182
blade0925
My Ride: BMW 325i
Where did you get the old D5150U software? I would like to reinstall this software until they come out with a fix.
Old 02-19-2014, 08:12 PM   #1183
arvinny
My Ride: 2003 330i sport pkge
I got the launch.exe in Chinese. I held the reset for 3 seconds and after that held the home button until the home screen came on. No error message since then
arvinny is offline   Reply With Quote
Old 02-19-2014, 09:02 PM   #1184
wacuna
My Ride: BMW 323i
Press it again... sometimes it get stuck...
wacuna is offline   Reply With Quote
Old 02-20-2014, 12:20 AM   #1185
trentcdrums
My Ride: BMW 323i Sedan
Hi trentcdrums,
Good day
I am sorry for the error code of your Eonon GM5150.
if you have tried disconnected the car battery and re-connected it again and reset the head unit but the error code still there.
I suggest you update the head unit with the following software. Thanks
http://www.sbo2.com/cs_serial//BMW_A...146-131209.rar
Old 02-20-2014, 12:07 PM   #1186
alameda61
My Ride: 2004 325I
arvinny.......where is the reset button on the D5150...I have the same message.....can you help?
Thanks.
alameda61 is offline   Reply With Quote
Old 02-20-2014, 12:20 PM   #1187
alameda61
My Ride: 2004 325I
I did that but no luck.......how long did you wait pressing the home button?
Old 02-20-2014, 12:53 PM   #1188
arvinny
Right side on the left side of gps card
Old 02-20-2014, 12:54 PM   #1189
arvinny
Try it again. It will reset
Old 02-26-2014, 09:40 AM   #1190
E46iT
My Ride: 2004 325i Touring
is there a rear view camera function on this HU??
E46iT is offline   Reply With Quote
Old 03-14-2014, 08:51 PM   #1191
arvinny
Just ordered a Eonon D5150! (New version of Eonon D5113/Enco B146)
Yes there is. I ordered one from eBay for $20.00 which fits in the license plate light opening and it works great.
Sent from iPhone 5s
Old 03-18-2014, 07:54 AM   #1192
timb551
My Ride: 320d Touring
I have now read the entire thread, took a while
I cannot see any confirmed mention of the install with the Harmon Karden option.
does it make a difference?
regards
tim
timb551 is offline   Reply With Quote
Old 03-18-2014, 11:18 AM   #1193
SheckMastaFlex
My Ride: 2004 E46 M3 Vert
Originally Posted by trentcdrums View Post
Hi trentcdrums,
Good day
Has anyone tried this version out yet? I get the "launch.exe" error every morning, but turning it off and letting it reset usually fixes it. It's not a huge deal, but it would be nice not to have to mess with it.
Thanks!
SheckMastaFlex is offline   Reply With Quote
Old 03-18-2014, 05:38 PM   #1194
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
I cannot see any confirmed mention of the install with the Harmon Karden option. Does it make a difference?
Yes I did and it's a nice upgrade, system sounds much better.
That is the firmware I'm running an NO Launch.exe errors.
"Firmware updates"
There are two different ones to choose from:
This is the one my GM5150 is running, the firmware it came with.
BMW_APP_TW_4049-405F-0709-L146-131209
This is the latest firmware Carlos sent me to address the Launch.exe error.
BMW_APP_TW_4049-405F-0709-L146-140219
Originally Posted by northwestsupra View Post
Firmware updates
Instructions:
1. Copy the folder of files to the SD card.
2. Turned key to position one and turned on head unit
3. Inserted SD card and left the Eonon head unit on.
Turned key off, waited 10 seconds, turned key back to position one and head unit powered back on and read the SD card.
4. It goes through about four steps, then restarts, please calibrate the touch screen per the instructions.
5. Remove the SD card and hit reset. If you forget to take out the SD card, it reloads again.
"More Detailed"
1.Copy the NWD_703 folder in the firmware update to your GPS SD card (make a backup of your current GPS software and maps) So now the only thing on you SD card should be the NWD_703 folder.
2. Turn unit on without sd card till it fully boots (dont worry if you are getting a launch.exe error right after starting your unit, this doesnt seem to effect it)
3. Turn the unit off but turning your key to the off position for 10 seconds
4. Place your sd card into the gps card slot and turn the key to the acc position. You should see a Eonon logo and the unit should start auto updating itself.
5. Once completed the unit will have you re-calibrate
6. After calibration go to settings and select the option just under GPS and select your language (settings wont look set until you hit the home button)
7. After confirming you have the correct language set, then turn your key to the off position again and take out the sd card (if you forget it will just do the process all over again)
8. Turn key back to the acc position and let the unit start fully.
9. Once the unit has started, find a sharp object and hit the restart button above the GPS card slot to further confirm no issues.
10. Load all your GPS software back onto the sd card and remove the NWD_703 folder.
Build Thread <:> S54 Vanos Thread
-TTFS Engine/SMG Tune- SGT Headers/Sect 1/SCZA- Evolve Eventuri- Sprint Booster V2-
-UltraGauge- Orion V4's- CF Lip/Console/Diffuser- VIS XTS CF Hood- LED Fogs- Valentine One- Turner 15F/12R Spacers-
WOLFN8TR is offline   Reply With Quote
Old 03-19-2014, 10:44 AM   #1195
SheckMastaFlex
Thanks, WOLF!!! I was just getting ready to start searching for instructions on how to upgrade. This morning, I had to reset my unit about 30 times before the Launch.exe error went away.
Old 03-19-2014, 07:52 PM   #1196
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Welcome...
Old 03-20-2014, 07:10 AM   #1197
mile_end
My Ride: e46
touchscreen of my eonon is completly dead or is living on his own now....
******** width="640" height="360" src="//www.youtube.com/embed/8KrvbzDeO2E?rel=0" frameborder="0" allowfullscreen>*********>
but I got good contact with Carlos, and today send it back to Hong kong, waiting for the repair
mile_end is offline   Reply With Quote
Old 03-21-2014, 01:17 AM   #1198
EononCarDVD
EononCarDVD's Avatar
My Ride: BMW E46
Hi mile_end, don't worry, we will help you out.
Top-notch Eonon Android Car Stereo. Change, why wait.
Welcome to check our latest GA6150 BMW E46 Android Car GPS with 5.1 OS & new Subwoofer Volume Control feature, more intelligent than ever!
14 Rounds of Group Buy have been arranged till now! PM me anytime if you'd like to join and save!
EononCarDVD is offline   Reply With Quote
Old 03-21-2014, 10:58 AM   #1199
IggyBcool
My Ride: 05 IR M3
I'm not sure what I did/didn't do, but I can not gain access to the steering wheel buttons on my unit. When I go to the car tab on the HU, its ghosted and wont let me click on anything.
IggyBcool is offline   Reply With Quote
Old 03-23-2014, 09:29 PM   #1200
Rezist09
My Ride: 325i sedan
where to get primo 2.4 download???
Rezist09 is offline   Reply With Quote
Rate This Thread
