Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 06-03-2013, 11:38 AM   #1
trj
My Ride: 325Ci
Pirate ship creak
I know this belongs to suspension sub forum, but throwing it out here for more audience.
Yesterday, I noticed my car making the famous pirate ship (creaking) noises from the front while turning at slow speeds(parking lot). Mainly does it when turning to the right and back. Sounds like spring binding, but not sure if thats the right word.
Havent got down under to check it out but I have done a ton of suspension work recently and had everything checked out.
History(within last two months):
New Meyle HD FCABs
New Meyle HD RTABs with limiters
coilovers all around(but is not slammed, just a little lower than the stock sports suspension height).
New sumitomo htr z iii on stock style 44s.
New endlinks.
New RSMs.
New tie rod boots.
New rear wheel bearing.
The only thing I have not replaced are Front strut mounts. Would that be the culprit?
I have read a couple of threads on the similar noise and the reason behind the noise seems to vary.
What would be the first thing to check? I will not have time to check it till weekend, but I would like to get more info on it before I dig into the suspension again.
Old 06-03-2013, 12:00 PM   #2
Serega91
My Ride: 03' WRX, 07' S2K
Do you get these noises upon hard acceleration in first/2nd gear?
ball joints not lubricated?
Serega91 is offline   Reply With Quote
Old 06-03-2013, 01:59 PM   #3
cvx5832
My Ride: 325Ci, 325Cic, C300
New Meyle HD FCABs
New endlinks.
New RSMs.
New tie rod boots.
The ones who have reported back after fixing this issue reported it as a bad outer CA ball joint. Since I don't see that on your list that's where I would look first.
cvx5832 is offline   Reply With Quote
Old 06-03-2013, 04:50 PM   #4
trj
My Ride: 325Ci
No, it doesnt depend on acceleration.
I can hear it only when turning the wheel.
I am sure it makes noise in higher speeds but is covered with engine/wind/road noise.
However, its noticeable in parking lot speeds.
Yah, I was thinking about it too but it looked fine a couple of weeks ago when I had it on the lift.
But since I have OEM Control arms, I will have to get the whole new arm.
I think I will go with meyle HDs if I have to get new arms and ball joints.
Old 06-03-2013, 06:05 PM   #5
Ballistic325
My Ride: slow and steady
Re: Pirate ship creak
I'll put my money on the front strut mounts.
Ball joints will have a different noise and feel sloppy, perhaps some clunking.
If the noise is felt to be heard higher up on the strut than lower, I would go with the FSM.
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 06-03-2013, 06:39 PM   #6
E46BAV90
My Ride: 330ci & 325xi
New Meyle HD FCABs
New endlinks.
New RSMs.
New tie rod boots.
Hey trj, I have the same issue and I took mine to Absolute Motor Works today. And after they looked at it (for free) the found out the pirate noise was coming from the ball joint of my lower control arm. I installed Meyle HD front control arms maybe a year ago and they need to be replaced. Mine was only creaking when I turned the wheel at low speeds as well. But talk to Dan he's the owner, or Pete.
E46BAV90 is offline   Reply With Quote
Old 06-03-2013, 07:02 PM   #7
shovelit
My Ride: 03 325xi and 04 330x
My money is on a ball joint as well. They can check fine (no play) but still make that noise.
You could pierce the boot and shoot some lube in there and see if the noise goes away but it will still need replaced.
shovelit is offline   Reply With Quote
Old 06-04-2013, 01:20 PM   #8
trj
My Ride: 325Ci
Hey long time man, how have you been?
Thanks for the heads up on Absolute motor works. I might stop by before the weekend.
For some reason, I feel it is from the Shock mounts. But I will get them checked as well.
Will get everything checked.
But this suspension overhaul is costing me a lot
Old 06-04-2013, 05:43 PM   #9
e46fanatics.44663
My Ride: 325
Hi trj,
Have you solved your oil consumption issue from 2012? Thanks
e46fanatics.44663 is offline   Reply With Quote
Old 06-05-2013, 03:00 AM   #10
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
My pirate ship creak was the front strut mounts so that's where my money is too. The top of my spring retainer was coming into contact with the rubber on the front strut mount. A little pricey but adjustable camber plates fixed my issue. The top spring perch was integrated into the camber plate.
/// MODS
Old 06-05-2013, 11:01 AM   #11
trj
My Ride: 325Ci
Pirate ship creak
Originally Posted by e46fanatics.44663 View Post
Hi trj,
I can say its considerably less now.
After new CCV, OFHG and VCG I am losing around a quart at about 1200 miles, which i have read is normal. So it's much better than before. I do see a small leak at the VCG, so I am going to take care of it soon and see if that helps to stop or reduce the consumption.
Old 06-05-2013, 11:03 AM   #12
trj
My Ride: 325Ci
Pirate ship creak
Thanks for your input but if I have to get new mounts I am going to get the OEMs. I don't track the car or have it stances so the camber plates would be useless for me.
But I checked today and power steering fluid was low. I wonder if the power steering fluid being low would have caused that noise.
Anyway I got a quart of ATF from autozone just now. May be in the evening once I get home from work flush the system out and see if the noise disappears.
Old 06-06-2013, 03:53 AM   #13
sunsetcoast
My Ride: '99 323i & '00 323iT
Not related to the pirate ship noise, but how do you like the HTR IIIs? I've been considering them as a value performance tire and hear that they are reasonably comfortable riding, as well.
sunsetcoast is offline   Reply With Quote
Old 06-06-2013, 06:10 AM   #14
asdetail
My Ride: 2002 325ci coupe
exactly how does anyone here know what a creaking pirate ship sounds like?
asdetail is offline   Reply With Quote
Old 06-06-2013, 06:13 AM   #15
asdetail
aaarrrrgghh me heartys,shiver me timbers,me pirate ship be creaking right proper bad she be
Old 06-06-2013, 06:49 AM   #16
trj
My Ride: 325Ci
Pirate ship creak
I like the HTR IIIs a lot. Real good dry grip and quieter than my continental contipro contacts. In terms of comfort, they are not bad at all. In comparison to my old contitentals which were run flats, these are much more comfortable. Plus I am running 225 45 17.
Old 06-06-2013, 06:51 AM   #17
trj
My Ride: 325Ci
Pirate ship creak
Well I will try to record it and post it.
It does sound like am old ship that creaks on the waves.
Will top up the ATF in the power steering reservoir and see if it makes any difference today.
Old 06-06-2013, 07:53 AM   #18
Barbaros
My Ride: 02 TIAG M5
do that and post the video so we could tell.
Barbaros is offline   Reply With Quote
Old 06-06-2013, 08:05 AM   #19
Leezy321
My Ride: 2001 bmw 325i
Pirate ship creak
Check your sway bar links... That's where mine was making the noise. They looked fine, but all the grease inside of the rubber boots had dried up causing a god awful and LOUD creaking noise.
Leezy321 is offline   Reply With Quote
Old 06-10-2013, 12:12 PM   #20
trj
My Ride: 325Ci
Here is the video of the noise from the driver's seat.
