Old 06-03-2013, 05:30 PM   #1
COBYATCH
My Ride: 03 325i
Mechanical fan replacement options (Electrical fan swap?)
Hey guys,
I recently had the mechanical fan connected to the engine explode on me, and in return it put a hole into my radiator. I'm considering my options for replacing it, and it looks like there are 2 options. I can replace it with another mechanical fan, or buy the new electrical fan and at the same time remove the aux fan in the front. Is there any benefit to doing this? What option should I go with? I know for sure I have to replace the radiator, but I haven't looked to closely at what else needs to be fixed. I'll keep you all updated on what else needs to be replaced.
-Coby
COBYATCH is offline   Reply With Quote
Old 06-03-2013, 05:32 PM   #2
WDE46
My Ride: '13 128i, '04 330Ci
Benefits = fan won't blow up again
engine idle smoother and revs quicker
EASY removal for future work.
cons = costs a little more
I did it and I would never go back. The peace of mind I have when the engine gets revved near redline is nice.
BTW, bought the Bosch fan from BMAParts.com. Bosch was obviously the OEM b/c there are multiple BMW logos that have been ground off the part I received.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 06-03-2013, 05:54 PM   #3
Foxtrot_Uniform
My Ride: 325Xi
It costs a little more but here are a few benefits...
If you need to remove the fan later to work on the engine it comes out VERY easily. (In seconds!)
It is quieter
You'll add another 2MPG to your gas mileage!
Foxtrot_Uniform is offline   Reply With Quote
Old 06-03-2013, 05:56 PM   #4
COBYATCH
My Ride: 03 325i
Re: Mechanical fan replacement options (Electrical fan swap?)
Oh for sure, thanks! Definitely sounds like I'll be doing the swap.
I just looked at the car right now and it appears I just need that fan and radiator. The foam cover on the hood did get chewed up a bit so I'll probably replace that as well. Other than that, looks like a pretty easy job.
Sent from my One using BimmerApp mobile app
Old 06-03-2013, 06:02 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Click on the electric fan swap in my sig. Do it
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 06-03-2013, 06:05 PM   #6
WDE46
I did not record any sort of MPG improvement, but maybe that's just been my driving lately. Also, I added the easy removal point to my post. Forgot about that one. It takes about 30 seconds now :-D
Old 06-03-2013, 06:07 PM   #7
cvx5832
My Ride: 325Ci, 325Cic, C300
Originally Posted by COBYATCH View Post
Hey guys,
-Coby
How many miles on the clutch/fan that blew apart?
cvx5832 is offline   Reply With Quote
Old 06-03-2013, 06:28 PM   #8
NumbaOneNewb
My Ride: 2003 330CI Silver
Dont bother replacing foam part to hood. Its expensive and not worth it. I did electric fan swap too. You should free up a tiny amount of hp and weight reduction.
Sent from my SPH-L710 using BimmerApp mobile app
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 06-03-2013, 07:05 PM   #9
Press22
My Ride: 01 325ci
Sorry to hear your mishap. I had a cooling issue the other day too where my bleeder screw gave out and popped.
I'll probably be doing the electric aux fan soon for more peace of mind.
Press22 is offline   Reply With Quote
Old 06-03-2013, 07:46 PM   #10
COBYATCH
My Ride: 03 325i
Thanks! Definitely gonna follow it when I do the swap.
Not sure. If the previous owner has never replaced it before, then around 129K miles.
Sounds good! Not sure when I would need to take it out, but at least it helps when that time comes.
Sorry to hear about that man. Sucks for me too because I just replaced the radiator (and other stuff) in December. I'll keep everyone updated on the swap so you know how easy/difficult it is to do.
Old 06-03-2013, 08:14 PM   #11
Joan Lynn
My Ride: 2000 323i
I had a mechanical fan installed on my 2000 323i only because my original electrical fan quit while I was moving cross country from California to Florida, this was only done because the Dealer in Baton Rouge did not have an electric one in stock and I needed to get back on the road. I ran the fan for two years only because it took me that long to find a reasonably priced replacement. The drawbacks with a mechanical fan are less hp because the engine has to drive the additional load, louder fan noise coming from a mechanically driven fan, and also the A/C will not work adequately at low speeds or when stopped in traffic. Go with an electric fan by all means, also not having an electric fan on a car that came with one also messed up the engine computer, was told by the dealer that my engine warning light would most likely come on by not having the electric fan hooked up.
Joan Lynn is offline   Reply With Quote
Old 06-03-2013, 08:16 PM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
Old 06-03-2013, 08:22 PM   #13
FenderGuy05
My Ride: 2002 BMW 325i
Sorry to hear that man, my fan did the same thing in March, and I just had my hood redone to take care of the dents put in my hood by the fan. No pierced radiator for me, luckily.
http://forum.e46fanatics.com/showthread.php?t=975731
Definitely worth the swap, I did some work afterward, and it was SO easy!
FenderGuy05 is offline   Reply With Quote
Old 06-03-2013, 08:40 PM   #14
SeattleLSB
My Ride: 2003 330XI, 2003 M3
get the fan from BMA Parts, Use Code Spece30 and get it for a great price! That is where I got mine!
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 06-03-2013, 09:34 PM   #15
COBYATCH
My Ride: 03 325i
Can't seem to find the fan on BMAparts. Can someone give me the link for them?
Old 06-03-2013, 09:46 PM   #16
Solidjake
Zero. Leaks.
Solidjake's Avatar
BMA doesn't have them.
Prices did go up a bit, cheapest I see so far is on ECS
http://www.ecstuning.com/Search/17117561757/ES2568886/
Old 06-03-2013, 10:12 PM   #17
WDE46
That's weird because I bought one from there less than a month ago.
Old 06-03-2013, 11:51 PM   #18
rudycoop
My Ride: 3 pedal 330i
Try and find one through salvage/second hand.
Just a Jersey guy lost in NorCal
rudycoop is offline   Reply With Quote
