Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Lighting & Mobile Electronics (I.C.E.)
Xenon lighting, HID kits, fog lights, BMW head units, navigation, speakers, subwoofers, In Car Electronics (I.C.E.), carputers, DDEs, angle eyes, halos, LED tail lights, interior lighting, etc.
Old 06-04-2013, 06:16 AM   #1
clemsone46
My Ride: 2014 DCSB, 2005 ZHP
ZKW Burnt Headlight Bowl Replacements!
Hey all,
I have been plagued with the same issue that plagues every plastic bowl ZKW HID headlights for E46's. Because you cannot buy replacement bowls alone, the solutions currently for burnt bowls are either living with dim lights or retrofitting projectors. The retrofit is a good solution but involves cutting and irreversible modifications to the headlight housings. After much research and connections through work, I have found a solution.
I have acquired some extra bowls for testing and as is the common case, they are yellowed, cracked, and lack the "mirror finish" plating. The bowls are plastic welded to repair the crack damage and then re-plated correctly using the same methods to plate them from the manufacturers. Below is a series of pictures documenting and comparing the before and after. The results yielded the increased output of a brand new set of headlights.
Bowls before:
Bowls after:
Headlight output before:
Passenger side bowl replaced, drivers side original (notice light output increase and depth of beam):
Both bowls replaced:
Before and after:
I am going to be providing this service for any individuals interested. However, the lead time is lengthy if I don't have any completed so it will be just 2 or 3 individuals at a time. There will be an included core charge of $30 that will be refunded upon receiving your old bowls (this alleviates individuals having downtime on their cars). Bowls can be sent with or without the auto-leveling motors and shades, new bowls will be sent as requested with or without the shades (shades are an additional $15). The total price will be $240 + $30 core charge + shipping, $270 + shipping if no core provided. Shipping will be done using USPS flat rate boxing in the US ($12 + $3 insurance).
Please let me know if you have any questions.
Additionally, if someone cares to post this on ZHPmafia that would be great.
I HAVE 1 SET OF FINISHED BOWLS READY FOR SHIPMENT
Max
clemsone46 is offline   Reply With Quote
Old 06-04-2013, 11:41 AM   #2
Adamo99
My Ride: 2016 Wrangler 75thAE
This might sound like a stupid question, and hate to potentially crap on your thread- but if already going to the trouble of removing these bowls and sending them over to you, why wouldn't one just buy Hella Evox-R projectors as replacements, which are superior to the OEM items in every way, bolt right in, come with new bowls, and clear lenses- for $150/pair?
http://www.theretrofitsource.com/pro...products_id=92
Adamo99 is offline   Reply With Quote
Old 06-04-2013, 12:24 PM   #3
DOT.
My Ride: '04 ZHP Sedan
^ I don't think Hella EvoX-R bolts right in....
OP, so you're plastic plating the bowls? So does the burn bowls eventually come back?
DOT. is offline   Reply With Quote
Old 06-04-2013, 12:26 PM   #4
Adamo99
Direct drop-in replacement for most Euro applications.
Old 06-04-2013, 01:32 PM   #5
vtn86
My Ride: E46 M3
I would confirm that before making the statement that they drop right in. If it were that easy, it makes me wonder why a bunch of people haven't done this
OP,
Looks like a good solution for people who don't care to retrofit. Good work!
Can you provide some output pictures at a distance? Disclosure: I'm not interested in this, but it would be beneficial to see actual output before and after.
Modify your car for a function and purpose, not just to follow the crowd.
vtn86 is offline   Reply With Quote
Old 06-04-2013, 07:19 PM   #6
clemsone46
I have not come across anything stating a direct bolt-in retrofit for this. I could be wrong though. I'm with others in saying that this wouldn't be such an issue if there was such an inexpensive direct bolt-in solution. That being said, I'm not trying to market a retrofit, I'm marketing an OEM solution that I know to work.
Yes, the original bowls are being stripped and plated. It can be said that the bowls will eventually become burnt again. However, the top coat is urethane as opposed to a lacquer which is what is seen on the OEM coating. The urethane will make this a more robust solution.
Thanks for the questions thus far. I know this is new and I will answer any and all questions.
Max
Old 06-04-2013, 07:21 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Did you take those pics without the RV shield installed?
Old 06-04-2013, 07:22 PM   #8
clemsone46
OP,
I will get some pictures at a distance of the new bowls, however I cannot get "before" pictures at the same location and same distance as I don't have any burnt bowls installed. I was under the impression that the close-up shots showed a drastic enough difference.
Max
Old 06-04-2013, 07:26 PM   #9
clemsone46
No, that is fully reassembled, RV shield included.
Max
Old 06-04-2013, 09:08 PM   #10
vtn86
My Ride: E46 M3
Max
That'll work too. I think a lot of us know what burnt bowls look like, it would just be interesting to see before and after. Thanks for your response.
Old 06-04-2013, 09:12 PM   #11
Chrsb5
My Ride: 2004 330i
Are the Hella Evox-R a new product ?
Chrsb5 is offline   Reply With Quote
Old 06-04-2013, 09:22 PM   #12
vtn86
My Ride: E46 M3
No.
Old 06-05-2013, 01:27 PM   #13
Adamo99
Me too - these are the same bolt locations as OEM Hella projectors- they drop right into the same mounting location and holes.
Old 06-05-2013, 01:30 PM   #14
clemsone46
Please take this conversation elsewhere. You have already littered this with unnecessary comments.
Old 06-05-2013, 04:20 PM   #15
jack.chris328
My Ride: is a truck.
You are answering your own question here.... Those are "Hella" replacements. These bowls are for ZKW lights. The mounting points are not the same.
OP - Great job. Those turned out nicely.
jack.chris328 is offline   Reply With Quote
Old 06-06-2013, 09:19 AM   #16
clemsone46
Thank you for the comments
Max
Old 06-06-2013, 10:12 AM   #17
Adamo99
OP, my apologies- EVOX-R does not bolt right into the e46 projectors. I also have an e39, and it bolts right into those, but not the e46.
That being said, you can buy a RetroQuick kit from TRS, just the projectors and brackets specifically machined for the e46, for $165.
http://www.theretrofitsource.com/pro...roducts_id=254
Old 06-06-2013, 10:28 AM   #18
vtn86
My Ride: E46 M3
The OP is offering a fix for the OEM application. Essentially, it's the same amount of work as the RetroQuick kit you're advertising (for some reason on his sale thread), however, the OEM projectors will function better...unless they burn again. Those Morimoto projectors are pretty disappointing.
Old 06-06-2013, 02:49 PM   #19
dirtypinguin
My Ride: 330i ZHP Sedan
That retroquick kit of which you speak of, it looks like it comes with the Hella EvoX-r projectors if you select the E46 variant of the kit.
dirtypinguin is offline   Reply With Quote
Old 06-06-2013, 03:56 PM   #20
Adamo99
Yup. The extra $15 is for the brackets to mount to the e46 headlight assembly.
